A/V Problems Ag Ipod.
Discussion in 'Hardware' started by Visualaid, 26 Jan 2004.
  1. Visualaid
    Visualaid What's a Dremel?
    15 Apr 2003
    Hi guys.
    MY friend has an ipod but it doesnt work all it shows is a screen with a folder on it and thats all it will do.I just bought this reconditioned ipod a couple of weeks ago from the states and all it does is show a folder picture on the screen.
    Anyone got any ideas???
  2. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Its the folder of doom! Try downloading a firmware update of the apple website and formating the pod. If that dosnt work the pod is fecked unless you send it back to Apple ;)
  3. Visualaid
    15 Apr 2003
    should i buy it of him for £15 and try and fix?
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    worth a try, yes.
    Try the ipodlounge forums.
  5. Tau
    Tau Sharingan!
    17 Nov 2002
    Heh, at £15 is a bargain, the hard drive in it is worth more than that alone
  6. Visualaid
    15 Apr 2003
    he found this out and wants £60.............................
    i'll just get a new 10gb for £170
