Windows Problems installing windows server 2000
Discussion in 'Software' started by Brooxy, 18 Feb 2007.
  1. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    Hey
    The time has come for me to do my IVA practical at college which basically involves setting up a network. A very small one, with a windows 2003 server and xp client.
    Well basically, the computer being used as the server should be running 2k server because the specs are a little too low to even look at 2k3 (I've had 2k running on there without a hitch before), and apparently the changes between 2k and 2k3 aren't exactly going to be a problem...
    However we have a problem. I'm trying to install the OS right now. It completes the blue screen section without a hitch, and then moves onto the graphical install. After this is all done, it decides to reboot, and start the graphical section all over again. Basically I need this installed to iron out any problems with my practical and it's really starting to hack me off why it won't install properly...
    Any ideas?
  2. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    wipe the disk totally, i had this issue once before and a totally clean hard disk seemed to solve it.
  3. Brooxy
    20 Apr 2006
    Hmmmm just found the prob...which leads me to another question...
    Problem was solved by unplugging the ethernet card...it's a PCI thing, but i'm just curious to know why it would cause that problem.
    Just seems a tad weird...
    Oh and buzzons, it wouldn't suprise me if the HDD was dying. the one i'm installing to is only 13gb, and it's getting on a bit now...
