problems with flash drive and external hard drive
Discussion in 'Tech Support' started by malikdrako, 20 May 2007.
  1. malikdrako
    malikdrako What's a Dremel?
    27 Sep 2006
    recently, my flash drive (1GB Cruzer Titanium) has stopped working. when I plug it in, the light flashes once and my computer would say the drive malfunctioned, but now it doesnt even detect it. is there any way I can save the data on the drive?
    I also have a 15GB iPod hard drive in an external case, and when I plug it in, it takes up to 2 minutes to mount it. it still has whatever file system the iPod has, I did not format it. would formatting the drive decrease the time to mount, or is there anything else I can do to speed it up?
  2. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    U sure it's not a driver or mobo going bad??
  3. malikdrako
    27 Sep 2006
    i've tested each on multiple computers, they both do the same thing on every computer
  4. DougEdey
    5 Jul 2005
    If it can't detect it then it's very unlikely you'll be able to get data off, check no pins are bent and does it make Windows XP's "chime" when it's plugged in and out?
  5. malikdrako
    27 Sep 2006
    no, the light just flashes and thats it
    and what about the hard drive?
  6. DougEdey
    5 Jul 2005
    Is it a drive that's not got any data? I believe that iPods use a specific apple filesystem.
  7. st00dent
    st00dent Minimodder
    27 Sep 2004
    I had the same problem with my flash drives and ext hdd - i found a slightly random fix... unplug pc from mains and plug it back in! Sounds silly, but it worked!
  8. malikdrako
    27 Sep 2006
    the hard drive has about 9GB of data on it
    the file system reads as FAT32
    could the file system be slowing it down?
  9. DougEdey
    5 Jul 2005
    Get the data off it then reformat it, I think it's because the superblocks are in odd positions and it takes Windows a while to find it
