Problems with LG GDR-8161B DVD ROM
Discussion in 'Hardware' started by semaj, 16 Jan 2005.
  1. semaj
    semaj What's a Dremel?
    10 Jan 2005
    I have been haveing problems with my LG DVD-ROM DRIVE. It is about 3 years and takes about 5 minutes to load a game. the model number is GDR-8161B, i have taken the ide cable out in put it in again, re-wired the rest but it still dosnt work, i am running ZP so no drivers are needed, anyone got any ideas?
  2. quack
    quack Minimodder
    6 Mar 2002
    Have you tried updating the firmware to see if that makes any difference?
  3. semaj
    10 Jan 2005
    hAVE LOOKED FOR FIRMWARE BUT CANT FIND AND, THE LG WEBSITE'S LINK IS BROKEN ALSO IT USETO WORK, IT SEEMS 2 HAVE JUST STOPED WWORKING
  4. Go4t
    Go4t i
    13 Dec 2003
    capslock broken?
  5. semaj
    10 Jan 2005
    sorry, could'nt be botherd 2 re-write it all
  6. quack
    quack Minimodder
    6 Mar 2002
  7. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Have the 8160B and its managed to break itself.. the power reg is nackered or summit, it just overheats after about 10 minutues use then crashes the pc... Bro had the same drive and that seems to have gone a similar way.... very strange tbh.... Have a feel at the rear of the drive, where the molex is, is it hot? If so its probably the same fault... There doesnt seem to be a solution...
  8. semaj
    10 Jan 2005
    thanks, i will see if i can take it down 2 novatech and get them 2 give me a new 1, it is out of warenty but they replaced my cd-rwwhen that shatterd my disc!
