Build Advice Problems with new build
Discussion in 'Hardware' started by shaleenh, 16 Dec 2009.
  1. LithiumDesign
    LithiumDesign 3dsMax User
    23 Jul 2009
    Copy my sig. :D
  2. adam_bagpuss
    24 Apr 2009
    ooo good price Barndoor i think thats about as good as it gets for a i7 maybe shave a few pounds but id rather buy from one supplier that loads of different ones.
  3. shaleenh
    shaleenh What's a Dremel?
    31 Jul 2009
    Many thanks everyone.
    I've decided to go with the following configuration:
    That works out to £795.07. I know it's over my initial budget, but I did not want to compromise.
    Many thanks for all of your help.
    I'll be finalising my order before the day is over, and would appreciate any last minute inputs you may have.
  4. Fazed
    Fazed Minimodder
    5 Jul 2009
  5. bagman
    bagman Minimodder
    18 Apr 2009
    why the extra sata cable? you get all that you need with the mobo
  6. shaleenh
    31 Jul 2009
    Thanks for the suggestion. Implemented.
    I've also added an internal card reader
    http://www.scan.co.uk/Products/Akas...lti-Card-Reader-Incl-M2-Micro-SD-and-USB-port
    http://www.ebuyer.com/product/144154
    I'd better finish the order before I go further off budget.
    Many thanks everyone for all the help. If any of you live around London, I'd love to treat you to a beer. Post/PM if you're interested.
  7. Fazed
    Fazed Minimodder
    5 Jul 2009
  8. shaleenh
    31 Jul 2009
    Thanks for the suggestion, but I think I'll stick with the current one. I kinda like having it built in. I also really like the ability to read M2 sticks without an adaptor.
    EDIT: Apparently, I'm eligible for free delivery on scan, so that brings the total back down to below 800. Yay! (793.85)
  9. Fazed
    Fazed Minimodder
    5 Jul 2009
    Tidy:thumb:
  10. shaleenh
    31 Jul 2009
    Ok people, I've assembled this, but it isn't working.
    The fans (including 2 on case + psu + gfx card + titan) all run fine, but nothing appears on the screen. Could this be because I'm using a DVI->VGA convertor? (It came with the Gfx card)
    Any suggestions? I'm at my wits end.
