Case Mod - In Progress Prodigy Casemod : Final 08-21-2013
Discussion in 'Project Logs' started by saxovtsmike, 18 Sep 2012.
  1. Zoubiey
    Zoubiey What's a Dremel?
    2 Mar 2012
    Do you know it it's possible to keep the harddrive rack in the bottom with the pump ontop and use the same radiator setup? But except for the 140mm it will be a 120mm.
    Right know I have a 240x47mm radiator home but I might have to buy a slim to get everything in, what you do think? Will also use DDC pump with EK-DDC X-Res 100 CSQ.
  2. Chanc3
    Chanc3 What's a Dremel?
    22 Jun 2010
    Looking great! used to have a prodigy myself but ending up selling it due to moving :(
  3. saxovtsmike
    saxovtsmike Minimodder
    12 Aug 2008
    It even fits with my slim 140 rad. Tried it but made no picture.
    It´s not helping as its too junky and would take too much place. As I´m only using 2.5" drives (2x ssd, 1xhdd) it doesnt matter..
    Played with my cam a bit and made some pics of my stuff..
    I hope you enjoy ...
  4. Zoubiey
    2 Mar 2012
    I don't any 2.5" drives so I have to stick with the hdd cage. But thanks, now I know that I can order my stuff and get my rig watercooled! :)
  5. saxovtsmike
    12 Aug 2008
    Workin 10h a day doesn´t leave much time for modding when you have a Child too, but at least a little update.
    First custom Cable done, easy start with the 8 Pin CPU
    Changed the Plug to a connected 4+4, as the original Asus one was just two 4 pin plugs
  6. saxovtsmike
    12 Aug 2008
    As I don´t wanna start the 24Pin yet (it scares the Sh*** out of me because of the double Wires and the 2 plug mess) I started playing around with an optional front
    [​IMG] [​IMG]
    Some more details on the front chapter, last things for tonight
  7. saxovtsmike
    12 Aug 2008
    Sadly not much of a progress on this build, RL and work keeps me buisy, so there´s not so much hope to get any big progress in the before march...
    But some final parts came 2day.
    XSPC Raystorm CPU Block and a couple bottles of DP Ulra in Blue arrived.
  8. saxovtsmike
    12 Aug 2008
    Little update done to the build:
    I mounted the Raystorm, gladly its backplate fits like a glove and no contact to the mainboard tray.
    Drilled holes in the top for the offset mounted Radiator
    Added the needed Breakthough´s for the 2 Bitspower bulkheadconnectors to got to the external radiator via Kollance VL3n with G1/4 connectors.
    I also made use of a spare powe/reset Button array of a V351 which will be mounted on the backside of the case left of the psu
    So I can finally ditch the original io bracket of the Prodigy in the sidepanel.
    Fluidwhise the decision was done too, I got myself 3 bottles of DP-Ultra in blue
    Pics to follow.
  9. saxovtsmike
    12 Aug 2008
    Forgot to do all the needed holes in the top :grr:
    Modded Back :
    And the raystorm @ it´s new home
  10. saxovtsmike
    12 Aug 2008
    8pin + 24pin shortening and recrimping is done... My fingers still hurt
    GPu Power is next. Blame me for the Boxed cooler, but as long I´m not finished with the modifications on the case, it won´t see water.
    The front is allready de-riveted and rotated, but at it doesn´t clear enought, I need to rebuild the front complete to fit the Aquabay Res and AE5
  11. saxovtsmike
    12 Aug 2008
    After lots of pain swearing and other not so nice words I finally finished the replacement plug for the power switch & stuff to connect to the mainboard to be used with the buttons showed in #29 (lili V351 stuff)
  12. saxovtsmike
    12 Aug 2008
    After I got some crimps I could do the 2x6pin GPU power.
    Came out not that bad, but I feel not the satisfaction I would like to.
    When you look closer you will see where the new cables for the power switch will be routed.
    Quite some space left in the case to add a waterloop..
  13. saxovtsmike
    12 Aug 2008
    while playin with my stuff , I stumbled across this layout...
  14. saxovtsmike
    12 Aug 2008
    still w.i.p status but we´r getting there
  15. Pliqu3011
    Pliqu3011 all flowers in time bend towards the sun
    8 Aug 2009
    Looks great. Very minimalistic. Can't wait for the final result. :thumb:
  16. saxovtsmike
    12 Aug 2008
    First drafts of Custom Sidepanels.
    Will be mounted on the original points were the "bars" where mounted.
    No Clue how to close the big window, ether full size perspex or a mix of venting slots or only slots...
  17. saxovtsmike
    12 Aug 2008
    Sidepanel fits :D :D :D
    Now it can go into production, Next step => Window
  18. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Now that is some serious weight saving. Should defenitely add some FPS ;)
  19. saxovtsmike
    12 Aug 2008
    Getting hot air out of the case will be a task
    I´ve really no big clue what fans I could use, so at the moment It´s a mix out of Gentle Typhoons for the 240 Rad Blowing fresh air inside and Noisblocker 140mm Fan for the same task on the bottom mounted slim Rad.
    Rear Exhaust could be a 140mm Fan (undecided) and in the front I can fit a 120mm fan to get heat out of the case.
    At the moment I´m quite lost as there is no real chance to get good silend fans ether Black or White to fit the theme AND beeing avaliable in 120 and 140mm fitment.
    Equal choices would have been the new bionic Fans from Noisblocker, but therse don´t exist in 140mm fitment, and of course Corsairs Interchangeable color Ring Fans.
    For 120mm they would even offer the Static Power ones for RAdiators and the Airflow ones as Exhaustfans, but sadly no Static Pressure one in 140mm fitment avaliable.
    Well the Rad fan is hidden so only the rear exhaust would be visible, so nearly "corsair only" would be possible.
    Anyone with a discont coupon from Corsair online ???
    Final Sidebladedesign is done and went off to the lasercutter 2day, and I allready got a quote for both sidewindows. These alone will set me back for about 80€´s damn...
    Will be in a color called 7C83, its Gray and light shines through, might come out quite nicely.
    Some Prevew pics from the CAD proggy ...
    That where the Windows...
    To get the Front side done I had to think a bit but ended in a 3 Layer setup
    Base Layer mounts to the Prodigy Front, and holds the Bayres and the Exhaust Fan
    Middle Layer could be optional Perspex/clear acryl and could be treatenend with a led
    Top layer is Cover with matching vents to the sideblade.
    I could even Mesh them, well I´ll see
    And a final pic of how it could look like when it´s done...
  20. Hukkel
    20 Dec 2012
    How about the Enermax Cluster fans?
    Or noiseblocker eloops? Or are they only in 120mm?
    And otherwise you will have to grab your spraygun :)
