Modding Professional PC painting edit pics added
Discussion in 'Modding' started by BobbyMParr, 21 Sep 2005.
  1. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
    Hello Fellow Bit-Techers, what's up?
    I'm fixing to start doing automotive finishes on pc cases or anything people want painted - sounds good, right?
    Well the down side is, the cost for "primer, paint, clearcoat, sealant, hardener, and compound" runs about $70-90.
    So say its $70 and I charge $20 for labor, that's $90 - would anyone pay that much plus shipping to have their case painted the color they want with a auto/mirror finish case?
  2. ModMonkey
    ModMonkey Size 11 Carbon footprint
    22 Sep 2003
    Probably no, But would the price be the same for a full tower and a sff?
    Presumably a case 75% smaller would cost less??
  3. funkymunky
    funkymunky Guest
    thats pretty expensive.. and of course its going to cost more if were in the uk.
  4. JamesM
    JamesM What's a Dremel?
    8 May 2005
    I'd rather do it myself for about half the price, or even take it into a body repair shop and have them do it for less.
  5. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Is this just a plain colour, or is this for patterns and pictures? If it were patterns or such, people would more likely pay $90 (about £50 or so).
    (I had to restart firefox here, the text started going back to front!?!
  6. atanum141
    22 Jul 2004
    i wouldnt mind painting for the $90 price range...but im sure the bloody shipping will bump it up alot more....
    can you do the whole case...i.e. ouside pannels and internal case aswell??
    also do you have any sample pics of previous cases done??
  7. BobbyMParr
    18 Jun 2004
    as i posted just to get the stuff for the case would be 70 and no u cant get a auto guy to do it cheaper i doubt only thing is u woulnt have to pay shipping i could do some minor designs "stripes and stuff like that for now but later when i get more setup i could do flames and such
  8. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    You probably have to start thinking of buying in bulk. Something in the area of 25 gallon tanks of primer, paint, and so on to reduce cost.
  9. MrWillyWonka
    25 Jul 2004
    Pretty much so, and where are you gonna put gallons of paint?
    Then theres advertising to think of, not sure if you'll be allowed to "advertise" your "business" on these forums as its against the rules.
  10. BobbyMParr
    18 Jun 2004
    im not advertising im just asking a question
    oh ya and i can do a FULL case including inside chassis and such possibly even cd/dvd drive covers and such
  11. mattthegamer463
    26 Nov 2004
    could i mod a case, then send it to you for painting, that way my modding wont ruin the finish?
  12. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    matt the gamer, most people paint last so I don't see how it would be a problem. I had some stuff painted by the local body shops for less then that but if you specialize in computer and such it would be worth the premium. Now I take it to my local community college and just use their guns, paint hoods and such for free.
  13. BobbyMParr
    18 Jun 2004
    Yes matt after you are COMPLETELY finished modding that would be the right time
    as for price i would need to know the color then go check at the local paint store for their price
  14. Rimmer
    Rimmer What's a Dremel?
    16 Aug 2004
  15. BobbyMParr
    18 Jun 2004
    Someone Asked if they could see my pics of cases i have done here is one i just started today it has alot to go "wetsanding,clearcoat,and more wetsanding"
    the black is Gloss black and the red is a Metallic red and yess there is a small S shape in the black on the bottom pic :wallbash: i will be able to fix that very simply :thumb:
