Windows "Program too big to fit in memory"?!
Discussion in 'Software' started by Foolio882, 1 Oct 2003.
  1. Foolio882
    Foolio882 What's a Dremel?
    1 Sep 2003
    Ok, I wanna see whos hotlinking from my hosting so I downloaded the Raw Access Logs in .tar.gz format. I untarred it and got a program, extracted that to D:\logs\program.exe
    Start>Run>cmd
    d:\logs\program.exe
    "Program too big to fit in memory:
    Now, what does this MEAN, first of all? And second, how do I view the Access Logs if cmd wont work?
  2. Lucifer
    Lucifer What's a Dremel?
    18 Nov 2001
    how the smeg did you get an exe from your logs? how about you open it in notepad?
