Case Mod - In Progress Project 12 (Phantom 820)
Discussion in 'Project Logs' started by XNine, 3 Nov 2012.
  1. XNine
    XNine What's a Dremel?
    10 Dec 2011
    Hardware
    Case: NZXT Phantom 820 (modified)
    Motherboard: Asrock Extreme 6/GB 2011
    CPU: Intel 3820
    Ram: Samsung Green low-profile
    GPU: Sapphire 7870
    Fans: NZXT 200mm, Gelid 120mm Fans for radiators.
    Sleeve: MDPCX Black and Vanilla Sands
    PSU: NZXT 850watt
    Watercooling:
    Reservoir: EK Multioption 250
    CPU: EK Supremacy Nickel/Acetal
    GPU: EK 7870 Waterblock
    Controller: Aquaero 5 Pro controller w/ Waterblock and custom face plate
    Radiators: EK XTX240mm and XT360mm
    Tubing: Tygon R3400 1/2" 3/4"
    Fittings: Monsoon Cooling
    Pump: EK 4.0
    Unboxing late at night:
    Removing Fan hub for sleeving
    Now, it's time to remove the mesh and prepare for plexi windows. I need to remove the 200mm fan mount as well... so...
    And it's time to start sleeving and cable management. I find it much easier to Cable manage from the beginning to avoid headaches down the road.
    Some really cool gear came in. EK gives you a lot of nice stuff, like nice stop fittings for reservoirs and radiators, cable adapters for their pumps, different sized screws for radiators. The 7870 block also came with an adapter to mount fittings horizontally instead of vertically.... REALLY awesome that they include all that kind of stuff in their products.
    Monsoon Rotary fittings. These things are awesome. Very well built and you can customize their look with colored "accent disks." As well, light port rotarty fittings are available if you want LEDs to color your clear tubing instead of using dyes.
    The LED fittings come with a couple of different sleeved cables. I already have some though, as I'll be using amber/yellow LEDs in this build.
    Now it's time to mount the radiators. 360mm up top
    HUGE BOX!
    For tiny items... Greenpeace would be really annoyed!
    Cutting down the rods...
    Mounting the Pump and reservoir:
    More to follow soon!
  2. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Verry good start Xnine! I hope my phannie will come quickly :D!
  3. XNine
    10 Dec 2011
    Thanks K.3nny. Nice to see you around again :)
  4. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    I think the Phantom 820 is one of the modt beatiful cases out there. I'm curious to see what you'll do with it ;)
  5. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Very nice work.
  6. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    I love the photos look so pro, nice work dude.. Will watch this.. :)
  7. XNine
    10 Dec 2011
    Thanks guys. :) Those are actually taken with my HTC One X. Pretty damn good for a phone camera. What I've learned over the last couple of years is that natural lighting=best photos. So, even with a cheap camera, you should be able to get good pics.
    I'm doing more work on her, should have it done by the end of the week!
  8. XNine
    10 Dec 2011
    Unfortunately, the 7870 will have to be RMA'd. Hopefully grabbing a 7950 to replace it. Updates to the build coming in the next day or so.
  9. XNine
    10 Dec 2011
    Small update for today. Unfortunately, my 7870 needs to be sent in for RMA which really skews my hope for having it done in the next week, but, rest assured, I'll have more this weekend.
    DWood's custom Aquaero Panel that will be going in:
    This is the rough outline he sent me. It only took like 3 PM's to get it from idea to final draft.
    And this is the panel already cut and bent, and ready for paint. It has shipped so it should be here Monday or Tuesday!
    The panel has 5.25 flaps for mounting it in the bays, the Aquaero will be mounted flush into the plate so there's no logos and no mounting screws to be seen. :)
    His work is fantastic, he's super easy to work with, and his prices are insanely low for the results he gives his customers. I don't put my name behind a lot of people, but this is one person I do!
  10. krussellusaf
    krussellusaf What's a Dremel?
    28 Jun 2012
    Looks like a promising project. Looking forward to seeing more.
  11. XNine
    10 Dec 2011
    Update!
    Sleeving USB 3.0 front headers. I haven't seen anyone make a tutorial on how to do it, and it was quite a task, let me tell you.
    The main problem, is that you either need large sleeve to go over the motherboard connector, or, you need to modify the headers because the casings are heat-sealed after they are installed on the header.
    So, we cut both side with an exacto knife, leaving both screw mounts intact. Cut below and above it. You have to go fairly deep, but ensure you aren't cutting any wires. There's also hot clue on the wiring/connector to keep everything in place. When you remove the connector from the casing, you've gotta be careful, otherwise it the connector will come apart.
    After it's removed, you just use your MDPC USB sleeve to sleeve the cable. Placing the casing back on the connector takes a bit of work, just make sure you put your heatshrink ON before the casings. Once the casings are on, then you can torch your heatshrink.
    Just waiting for the Heatshrink to cool down to hit it again to make sure it's nice and form-fitting.
    The Hue Lighting system.
    Fans prepped for cleaning of where the Gelid decals were. Custom stickers are on order :
    Starting on tubing. Those Monsoon compressions look really sexy.
    And now I await my GPU back from RMA, and perhaps there's a little something something coming this week. :)
    The Custom front panel should be here today or tomorrow, so that will be test-fitted and the project box for the lighting completed as well.
  12. XNine
    10 Dec 2011
    Time for an update!
    So, the GPU should be in my hands Monday or Tuesday, which means? Build time! Now... for some more modding work....
    Received the custom Aquaero 5 panl from DWood
    Some Stickers for the fans.
    Now it's time for some Acrylic work. I found that if you actually use a Dremel Metal cutting disc, and use the top surface of it, you can "grind down" or shave off acrylic in orderly fashion, which allows you to get more detailed results with a handfile once you're done.
    Once cut down, I hand-file it
    PERFECT!
    Then I use a propane torch to gently "kiss" the edges to make them nice and smooth. No screws are needed to install as the acrylic fits perfectly into the opening....
    But.,.. I felt something was missing.... Something just didn't feel right... We need it to match the rest of the build... and there's mesh.... so...
    Now, we need a hole for the LED.... X marks the spot...
    More to come in the next few days.... :) The fun REALLY begins..
  13. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Great stat! You have my attention!
  14. XNine
    10 Dec 2011
    So many things have happened since I started this project.
    My SSD, Aquaero screen, and Hue board all went bye-bye. So, I had to get replacements for each.
    I added a Samsung 840 Pro SSD, a new Aquaero screen, new Hue control board, 16GB more of RAM for a total of 32....
    To top that, I chucked my old Corsair PSU in favor of the mighty Seasonic. Sure, my Corsair was technically a Seasonic, but, it was time for the OEM. Sleeving the new Seasonic was a daunting task. They have a really redundant and stupid pin set up on their full-modular systems.
    There's a 24pin motherboard connector splits into a 10 pin and a 19 pin on the PSU side. Why? No real reason that I can think of, other than it's proprietary and a real pain in the ass.
    Other than that, things are looking up! Got everything installed and we're back up and running!
    Here's a sneak-peak:
    I had trouble mounting the Aquaero, because it uses some stand off to connect the original faceplate to the unit itself, this made lining the buttons up impossible as they were just a 1-2mm too high. So, I had to rearrange the mounting and use some aluminum spacers to get it all where it needs to be.
    Fortunately, my plan worked (and why wouldn't it, I'm just that awesome) :thumb:
    More to come in the next couple of days!
  15. Psyance
    Psyance What's a Dremel?
    6 Dec 2012
    Enjoying watching this build :thumb:
  16. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    Looking promising, great great case, great skills, great ideas. Nice work.
  17. XNine
    10 Dec 2011
    After two months of delays and issues between life and the build, I'm proud to say, that Project 12 is DONE. Fini.
    I will let the images do the talking.... for the most part. :)
    BTW... Thanks Newegg! I always wanted a huge box for my 1 tube of TIM. :D
    I just want to take a moment to say thank you to a lot of people, a lot of which have really helped me through some rough times and have inspired me to be and do so much more!
    To Adam, wish you were here so I could share this with you. May you rest in peace.
    Charles, Nils, and the rest of the MDPC fam: Thank you for inspiring me and being the people you are.
    Bill Owen: I've always loved your work!
    NZXT and the NZXT Modding Community!
    Gregor at EK for putting up with all of my crap! lol
    Dwood: For metal and plastics!
    Geno with Monsoon for late-night emails, talks, and bringing out my favorite fittings and innovating on the watercooling front!
  18. Axoxenon
    Axoxenon Do it right the first time
    28 Dec 2012
    Its been a while since it got finished but I must bump this.
    It looks awesome!! Just love the Monsoon's!! Aswell the front panel you got!
    Job well done :thumb:
  19. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    Too much paste
