Project:[32%] AntecWC - 10/04/04 - New interior + hdd rack
Discussion in 'Project Logs' started by paradigmqc, 20 Jul 2004.
  1. Bob 1234
    Bob 1234 What's a Dremel?
    5 Aug 2003
    you said u had a led fan that turns from blue to red when the temp increases, could you tell me/us how you did it and/or where u can buy it? it looks (pun intended) really cool to me.
    -Bob
  2. paradigmqc
    paradigmqc What's a Dremel?
    20 Jul 2004
  3. paradigmqc
    20 Jul 2004
    ok, the first brown coat is done ! After it still left 2 coat of black paint !
    Less deeper blowhole, what about it ?
    HAHAHHA all is ****ed up !
  4. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    that would be rather simple to do for the heat colouring actually. all you would need is either bi-colour or simply two other leds. Along with either a heat sensitive resister (hotter = less resistance) or a circuit that is hooked to a temp sensor.
  5. TMM
    TMM Modder
    12 Jan 2004
    looks ok, but a little "busy" inside with all that wiring. you should also re-cut the bit around the handle on the side panel
  6. paradigmqc
    20 Jul 2004
    I know man, i'm busy with the front panel....
    for the side panel, there is no problem I will hide the cut lat8r!
  7. paradigmqc
    20 Jul 2004
    I've send my front to a guys who made AIRBRUSH... kmon guys he come back with THAT :
    He sand it with 80 paper.... OMFG
    Need to restart all the work !
    The gril will be placed on the blowholes. need to fix the fan and the radiator too.
    One coat of primer doesn't fix all **** he does!<
    if pics doesn't work go there :
    http://forums.qctuningpc.net/viewtopic.php?t=801&start=140
    One good news, I've buy this brand new MX310 logitech mouse :clap:
    Remember the interior, little cleared !
    [​IMG] :jawdrop:
    And just buy this brand new M-Audio LX4 2.1 Sound system !
    [​IMG][​IMG]
  8. -EVRE-
    -EVRE- What's a Dremel?
    12 May 2004
    the idiot used 80 grit?! i dont touch my case with anything less than 400 wet dry.
    Very sweet looking front btw. gives me an idea for my next case mod
  9. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I can't enlarge any of your new pics, the thumbs look cool though :D
  10. TMM
    TMM Modder
    12 Jan 2004
    yeah some of the links are screwed. they have a "ℑ" instead of "&image"
    anyway, its looking good. try getting some good quality primer and black paint. the finish will come out much smoother :)
  11. TomboyMS
    TomboyMS What's a Dremel?
    6 May 2004
    You might want to check the link on the airbrush picture. I get an upload page.
  12. paradigmqc
    20 Jul 2004
    yep I know, the pics are ****ed up !
    here's some "working" update : the interior is now white :
    This rack is fired!
    Here's some high-quality primer !
    Working on hdd rack (the space between metal plate will be filled with black plexi)
    [​IMG][​IMG][​IMG]
    The stuff I use in my mod :D
  13. sqaulidhummer
    sqaulidhummer What's a Dremel?
    11 Sep 2003
    nice job paradigm.
    good luck with the rest of it ;)
  14. paradigmqc
    20 Jul 2004
    squidhummer from XI?
    hehhe nice man hello ;p
    thx gonna update this P.i.m.p. case tonight maybe.... koz it's raining hre! :wallbash:
  15. Cisko
    Cisko What's a Dremel?
    6 Jun 2004
    hello mate :)
    good job :thumb:
