Project 358 Kelvin (originally Big and Blue)
Discussion in 'Project Logs' started by kill_me_quick, 13 Jun 2005.
  1. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    It comes from a company called Technology Supplies, the order was from this group
    My collection of acrylic and a bit of ally
  2. moddenmania
    moddenmania What's a Dremel?
    18 Sep 2004
    do they have a u.s site? if not where do you think I could get some there
  3. kill_me_quick
    7 Jan 2004
    Well its a technology suppliers for schools.
    The acrylic is made by a company called Irpen which is a Spanish company. From their website they have suppliers in the UK, France and Spain.
    If you can find a suplier in the US, the type is "Policril" under which it says "Placa acrílica - Acrylic sheet UNE - EN ISO 9001:2000"
    Hope that helps
  4. gometro33
    gometro33 What's a Dremel?
    11 Jan 2005
  5. kill_me_quick
    7 Jan 2004
    Update:
    Finally got round to installing the watercooling and a new grill. Ordered a Watercool grill but didnt realise that it doesnt fit with a 120.3 so I had to modify the brackets. Enough of the bable on with the pics.
    Next is the WC
    After managing to snap the "Y" that came with the RBX kit I had to find an alternative. Rather than buying one off the net i had to find an alternative so I went to Keydell Nurseries and picked up a "T" piece, I will get a "Y" when they are instock.
  6. white modder
    white modder What's a Dremel?
    19 Sep 2003
    looking cool (y)
  7. Firehed
    15 Feb 2004
    What's with all the people recently top-mounting rad fans as intake? People really fail to see the "heat rises" thing.... and I think it's been determined more than once that a "pull fan" on a radiator is slightly better for performance.
    That said, good work.
  8. frodo
    frodo What's a Dremel?
    1 Nov 2003
    ^ so true. but its his choice really!
    i personally have my rad on my intake, but in a push pull config, but thats because its on the fornt of my case, so heat does rise, but to a roof that doesnt care
    i love the looks of this rig, makes me want to grab my cheiftec full tower and mod it! may well do it, if i can be bothered.
  9. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    One way to make blue tinted plexi cheaply is to go to any auto parts store and buy a can of "candy apple" spray paint (the stuff i have is made by plasti-kote). If you spray the inside of a sheet of clear plexiglass. The result looks very similar, and you get a really beautiful glossy look. ALso, if you spray another coat of a different colored paint (like a metallic paint) over the candy apple , you can get some really interesting looks.
