Scratch Build – In Progress Project: 4M (9/3 - F I N A L S ! ! !) > Completed
Discussion in 'Project Logs' started by quizz_kid, 17 Jan 2012.
  1. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Project: 4M
    Some of the final pictures, check page 9 for more of them
    My mom's computer broke down the other week. Since I am such a loving son I have to
    give her a new one. And since she´s not picky when it comes to performance,
    I´m going to use these modest components:
    Spcs:
    ITX MSI H61I-E35
    CELERON G530 2.4GHZ
    Zalman 9500A
    4 gb RAM
    CLUB 3D GF 210 512MB
    WESTERN 500 Gb
    The idea is to get done by her birthday in mid-February, so expect something relatively simple.
    Design
    Delivery
    I ordered a 430W, but since I want to keep the volume down as much as possible,
    I now think I´m gonna use my old shuttle-250W instead
    Modified Zalman 9500
    Found a new bracket fortunately
    For mom, this mediocre card will do the trick
    Mobo
    Mock-up for start button
  2. Jay_UK
    Jay_UK What's a Dremel?
    27 Dec 2011
    Hi there,
    Intersting project... :)
    I believe you should be able to just cut the pins and remove the VGA connector (any reason you arent using the IGP?)
    In your config, a 20 pin PSU into a 24 pin Mobo should be ok (low power requirements)
    J.
  3. Mojo
    Mojo Multimodder
    18 Nov 2011
    Personally i would cut the pins with a set of wire side cutters..
    put some 1mm heatshrink over them one by one to protect them.
    Though not sure why you would need to remove them??
  4. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks! The reason is a backplate design I´m working on... But I might leave it there. Don´t know yet.
    Thanks for the tip mate :thumb:
  5. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Another question, this time about the C14 plug in the PSU.
    What is that green thingy under the question mark? I´m a bit confused...
    The thing is that I want to extend the cable. Can´t I just cut the blue/brown and add Gnd to a new plug?
  6. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Joystick ingredients
    Some drilling
    Alu fittings
    This is the constuction inside. The placing of the metal spring had to be precise and it took some time to get the right resistance when pulling the ballhead
    Close up
    Also made two simple HDD mountings
    Aslo started on the wood work. I changed the shape a bit. Less width / more depth
    For an idea of the size... It´s not the smallest htpc, but it´s no monster
    Layout on the roof. Mobo will hang upside down
    Here´s where the GPU´ll be. Going to use pci extensions later. This will be left side, and the only side with attributes (such as mesh, DVD, USB-panel, fan controller etc) I want to keep it a clean build so nothing on top and right side. Front will just be joystick and brass window...
    Right side with HDD
  7. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Btw, sorry for changing the title all the time... :p
  8. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Nice start man !
    KUTGW !
  9. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    Awsome work, m-itx AND mdf, two of my favourite things.
    Regarding the cutting of the VGA port. I did the exact same thing on my project. First I cutt the small connectors with a plier and then desoldered the rest of the connector. Your connector is however of another kind but you should be fine just to cut the VGA piece away. Might be tricky to remove the remaining pins since that black casing seems to cover their solderjoints. You could try and heat them from the other side while pulling with a plier.
    Just make shure to preotect the mobo from any metall/solder debris but i guess you already know that.
    Good luck
  10. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Your mom must be proud to have son like this. :D
  11. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks mate!!
    Thanks Gnu! Yeah, hate those covered solder joints. But thanks for the tip buddy. Will try that heating and pulling later :thumb:
    It´s the other way around, but I think she´ll like it :D
  12. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Made new plates for the joystick today. Some perfection this time. All but painting left now.
    Made some spacers
    Cut some lumber today. Walnut of course =)
    Made front/back frames
    Also made some simple fittings for DVD and graphics
    Just one last check before putting the box together. Drill some, mill some... Can´t miss anything here since it´ll be too tight for machinery use in there later.
    Box glued!!
    Waynio likes this.
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D This will be good & in a short time frame :jawdrop::rock:. 5 stars & rep :)
  14. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Much appreciated Waynio :thumb::D
  15. KidMod-Southpaw
    28 Sep 2010
    This is definitely a great idea for such a small build- love the power switch!
  16. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks KidMod!
  17. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Sunday. Just sitting here trying figuring out what foot stand design to use. I have 3 options so far... Any thoughts are welcome!
    A simple elegant wooden stand
    A metal stand inspired by old industrial stools, painted in a color matching the front panel maybe
    A stand with angle / nose pointing up
    AnG3L likes this.
  18. Pranja
    Pranja Blackwolf
    18 Dec 2011
    2 would be my choice because it is most stable.
  19. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Really nice idea, perfected execution, what else can I ask? Just mod on my friend, this looks awesome!!!!! :) +rep
  20. Cheapskate
    13 May 2007
    Something that sticks out further in the front would be good. The handle gives you the potential to topple forward when pulled.
