Scratch Build – In Progress Project: 4M (9/3 - F I N A L S ! ! !) > Completed
Discussion in 'Project Logs' started by quizz_kid, 17 Jan 2012.
  1. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanx Jokkos!
    Yeah... It seemed natural to follow the circuit chart when I decided where to put LED+switch. Thanks mate!
    Starts are stars, but thank you very much Waynio! Glad you´re diggin :D
    Thank you Southpaw!! Glad my sleeving got approved =)
    Cheers!
    Thank you Pranja!
  2. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Some final soldering
    DIN-females
    Lot of work just for removing the connectors to the other side, but I guess I like modding :lol:
    WARNING! 230V. Don´t do this unless you know how to isolate well
    Golden mesh on sides
    The mounting:
    Wood frame
    Just throw it all in there!!
    Back piece
    Fittings
    Brass screw
    Wingnut for accessible adjustment of the angle
    Cables in...
    You might think the power cable is a bit long, but that´s how I like it.
    TADA! Really stable actually
    Better than expected. Got a really interesting profile I think. Sad the back´ll be hidden more or less :sigh:
  3. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Amazing!! :O
    How did you lock the screen into the wood though?
  4. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thank you! It´s locked on the backside, through the wood and into the backplate. You can see the screws if you look closely.
  5. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Anyone know how to connect these white-blu-red wires to regular the red-yellow-black ones??
  6. peteski
    peteski long live the pc
    8 Jun 2011
    [​IMG][/QUOTE]
    love it mate cant wait to see this finished :rock: :rock: :rock:
  7. Dr.Joe
    Dr.Joe What's a Dremel?
    11 Mar 2007
    I absolutely love it...
    If that fan is a papst, then it should be like this:
    red: V+
    blue: GND
    white: rpm
  8. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    fantastic build! :-D if she don't want it i'll gladly take it! :-D
  9. Mark_Skeldon
    Mark_Skeldon What's a Dremel?
    5 Feb 2012
    Excellent wood working skills!
  10. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanx man!
    Cheers! And thanks for the info.
    Thanks. I´ll let you know if she rejects it =)
    Thank you
  11. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Small update
    Molex connectors seemed dead so cut them off
    Going to use a power SATA instead. 5V to graphic fan and 12V to LEDs
    Fan cable extension. Gonna be quiet with 5V
    Twin USB cable for DVD and foot
    Here´s my small LED stripe module with angle
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    Superb creating & modding mate. :clap: rep
  13. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    :rock:
  14. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Had to cut the HDD fitting a bit for SATA cable on mobo
    Made a new decal for the vents
    LED-stripe mounted
    A small cable for start button. Tried heat shrink tubing for the first time. Nice!! How could I´ve missed THIS??? No more ugly tape!
    Power-SATA to gpu fan
    Fanmate to the fans
    One last testrun before final assembly.
    Pimped the fan cable a bit with my new best friends, shrink tubes!!
    Empty shell
    DVD
    In place
    Locking fittings
  15. peteski
    8 Jun 2011
    not long now mate cant wait :rock: :rock: :rock:
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D It's so riddled with nice touches. :)
  17. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanx mates!
    Assembly part 2:
    PSU
    In place
    Hade to tape the ATX a bit for the mobo placement
    Mobo and front panel in place
    Here´s the fittings for the PSU
    Spacer/mobo/spacer/fittings is the idea. One screw holding both mobo and PSU in place. I´m quite proud of the solution
    Side view
    Tight and steady
    30 cm PCI-E riser from one side to the other, under mobo
    Noticed that the 4-pin ATX was a bit too long, so I cut it and made it a bit more appealing
    Soldering
    There we go!
    Opps, forgot the mesh :duh:
    Hade to start all over. Mesh in place.
    Over the the graphics. Hade to slide the back panel in to access the VGA port.
    This was tricky, I had no room left for hand work so had to play the surgeon for a while
    Tight!
    Managed to get it in position after 20 min
    Gpu fan cable could hide behind memory
    Here´s a visual of the limited space I had to work with. If the riser had been 1 cm shorter it would´ve been an epic failure. Got lucky I guess...
    VGA-port mounted on the outside
    4-pin ATX in place
    Push button for DVD eject
    Connection on the inside
    When I was mounting the fanmate there was no room for screwdrivers, so I hade to make a tool-thingy made of a star tip and a piece of wood.
    Took a bit of technique but it did the trick. Could be useful when mounting the HDD tomorrow
    ... and that´s it for today. My bed is waiting :lol:
  18. peteski
    8 Jun 2011
    man that is a tight fit in there but looking good mate :rock: :rock: :rock:
  19. Karrek
    Karrek Minimodder
    7 Jun 2011
    impressive work! and creativity! good inspiration for me...
    I love the look.
  20. Snubbs
    Snubbs CustomPC Migration victim....
    27 Mar 2009
    Just read the whole log. Really wonderful project! Love it throughout, it's a very well thought out idea with a very clever and complex design. I'm sure your mum will love it! Epic work!
