Scratch Build – In Progress [project]6th GeN. 30TB - 2730W PSU ^^ Finale?!
Discussion in 'Project Logs' started by grevaeg, 22 Apr 2009.
  1. grevaeg
    grevaeg Insanity driven
    17 Oct 2008
    Ey guys!
    New project on the starting steps now, hopefully gotten some more experience since last time, and going into this one with all my "might" :p
    24th apr - The windmill
    12th jun - the first package arrives!
    13th jun - Welding plan's
    16th jun - Cutting alu for the frame!
    19th jun - Building the frame, PORSA KNOTS ARRIVED!
    24th jun - Time to play with harddrive holders...
    28th jun - AMD knocks on the door!
    30th jun - The HDD rack..
    1st jul - The watercooling and fans arrive... atleast some of it ^^
    3rd jul - mounting up the 17" screen
    6th jul - Watercooling part 2! OCZ Brings the POWER!
    8th jul - Cable management, day 1
    11th jul - mounting up the PSU's and mobo plate
    13th jul - Cable management, day 2
    14th jul - The plexiglass arrives
    15th jul - The PSU shroud in place
    18th jul - SATA cable time !
    20th jul - Waterpumps arrived!
    24th jul - Grevaeg got engaged :p
    27th jul - The paintjob
    28th jul - Time to mount up some harddrives
    1st aug - Cable management, yet again, hoses and watercooling finally in place!
    7th aug - 6th GeN, more or less complete ^^
    Current pic
    -Sponsors-
    THX ALOT to these guys, they are making this project possible !
    OCZ
    AMD
    Spinnin Wheel
    Netshop
    Anfi-Tech
    EK waterblocks
    -Goals-
    I would like to develop my previous design, lots of hot air was blown directly onto other components last time, thats gonna change, all the disks will go in the middle module, while the main comps stay in their own on top and bottom, there will be no more "PSU in the top right corner" type of thing, got OCZ on the team this time, and they will provide some awesome custom powersupplies for this project
    to sum it up :
    * 3 mobo slots (gonna get in a mATX instead of the mITX)
    * seperate disk case
    * seperate comp case
    * watercooled cpu's/gpu's
    * TO HELL WITH PLEXI, god i hate that material...
    * YES to andonized, cnc'ed alu :p
    * fully welded alu frame
    -hardware-
    PC1 :
    MSI 790FX-GD70 AM3
    AMD Phenom II 955
    8 GB OCZ FlexX DDR3
    Radeon 4870x2
    910w Silencer PC Power&Cooling
    PC2 :
    MSI 790FX-GD70 AM3
    AMD Phenom II 955
    8 GB OCZ FlexX DDR3
    Radeon 4870x2
    PC3 :
    Asus M3A78-T AM2
    AMD Phenom II 955
    8 GB OCZ FlexX
    Radeon 4870x2
    Harddrives :
    6 x : WD500GB, 7200rpm, IDE
    16 x : WD500GB, 7200rpm, SATA
    8 x : WD750GB, 7200rpm, SATA
    4 x : WD1000GB, 7200rpm, SATA
    2 x : WD1000GB, 7200rpm, E-SATA
    4 x : SG80gb, 15000rpm, SAS
    4 x : Seagate 1.5TB, 7200rpm, SATA
    Watercooling loop1 - Mainrig, gfx :
    OCZ Hydroflow cpu blocks
    EK 4870x2 and 4870 gfx blocks
    1/2" hosing
    Iwaki MD15 pump
    4x 360 rad's
    A new day, a new set of renders !
    consept art
    Gonna post up some early renders on some thoughts and ideas this time around, feel free to contribute with ideas, they are greatly needed, as this is only the basic design without any awesome looking stuff
    Getting late at my place, gonna do a proper writeup tomorrow =)
    Stay tuned! ^^
  2. Mokey Mokey
    Mokey Mokey What's a Dremel?
    9 Mar 2009
    Whoa, it looks insane! I'll keep coming back to this thread.
  3. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    You are that duder who made the 29TB gaming rig right?
    Let me ask you one question: Why? Why would you want 30TB of space in your PC? Unless ofcourse you're going to make a fileserver out of this one?
    Good luck anyway :)
  4. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    what the hell are you going to do with this thing?
  5. Guest-23315
    Guest-23315 Guest
    I ALLOW THIS :D
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Wow, you got Mankz' approval. This better be good now. :p
  7. grevaeg
    17 Oct 2008
    moved
  8. FrooP
    FrooP can I eat this?
    24 Oct 2007
    i love you
  9. grevaeg
    17 Oct 2008
  10. grevaeg
    17 Oct 2008
    I also have FrooP's love ^^
    *edit*
    Hardware added .P
  11. perplekks45
    9 May 2004
    You're truely blessed.
  12. Beef Supreme
    Beef Supreme What's a Dremel?
    1 Mar 2009
    You will be bringing this one to TG10 also, right? ;)
    "TO HELL WITH PLEXI, god i hate that material..." :p
  13. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    Yikes! where are the rads btw... behind the HDDs? Or does every "box" have it's own rads?
  14. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Crap dude, first a 20tb mod? Now 30tb :S Have u got 50 tb's of storage :S Thats insane :p
  15. kenco_uk
    28 Nov 2003
    It's what the internet was made for.
  16. grevaeg
    17 Oct 2008
    The rads is placed on top of each of the computer "modules" 2x 360 rads in each, check out the 6x120mm fan's on the pics, will go here
  17. ModMonkey
    ModMonkey Size 11 Carbon footprint
    22 Sep 2003
    That brickwork looks a bit messy.
    I refuse to comment on the machine itself due to immense jealousy.
  18. Xtrafresh
    27 Dec 2007
    Aha, that makes sense now :)
    Are you sure you have enough clearance for the air to get out?
  19. grevaeg
    17 Oct 2008
    Nope, not really...
    But then again... air easily bends around stuff, so a 360x240x4 cm clearance should be sufficient
  20. Guest-23315
    Guest-23315 Guest
    My approval only lasts so long...
    (in other word, get building :p )
