Scratch Build – In Progress [project]6th GeN. 30TB - 2730W PSU ^^ Finale?!
Discussion in 'Project Logs' started by grevaeg, 22 Apr 2009.
  1. grevaeg
    grevaeg Insanity driven
    17 Oct 2008
    im one of em norwegian guys, so they have to run either 220v or 12v :p anyways, used the iwaki rd15 in the previous build, but cant find anyone retailing em =/
  2. Odin Eidolon
    Odin Eidolon What's a Dremel?
    7 Feb 2009
    220V, eheim 1048
    for 12V i would use some DCC3.25, thats the best you can find performance and dimension wise
  3. Mark_Hardware
    Mark_Hardware What's a Dremel?
    5 Apr 2009
    I have a concern,
    This spot. You are going to have all the weight of almost the entire case on these four bolts, which are towards the middle of that bar, instead of on the ends where it's stronger.
    This is awesome work man. Props for anyone who makes a case bigger than mine! :rock:
  4. grevaeg
    17 Oct 2008
    If you look closely, u will see a hole on the middle bar aswell :p
    Just ran out of bolts, lol (BTW, its 10mm stainless steel bolts) u could hang a car from each one of em ^^
  5. Mark_Hardware
    5 Apr 2009
    lol ok, you the man. I have personally designed something for aesthetics, only later to find out it the functionality (or support) was lacking. Just was hoping this wasn't one of those cases. err, instances lol
  6. grevaeg
    17 Oct 2008
    Cable management, day 2
    Hi guys!
    New update today ! running really low on materials now, all from alu to steel, and the plexi have yet to arrive.... so somewhat in a standstill now, ah well.... found a few parts to work on anyways ^^
    Whats been done:
    * PSU mounts done
    * Middle mobo plate mounted
    * Front and backplate of mid module finally popped in place
    * Started working on consealing the middle PC aswell as all the cables that comes with em
    * 2x 240 and 2x 360 radiators arrived
    * ordered up 12x 120mm fractal design 16db fans
    * ordered up 3x laing pumps
    * ordered up hosing and "coolsleeves"
    The mobo plate
    Well... as you prolly know by now, the PC thats gonna manage most of the disks will be placed in the middle module, up front on the middle module to be exact ^^
    Had to file down the back of the spacers to make sure the mobo plate was in touch with the front plate
    Drilled a bunch of holes, and popped stuff into place^..
    The PSU mount
    cmon, its basically just 2 plates of alu with holes in em, not gonna go further into that venture ^^
    The secret!
    Wonder whats gonna hide behind the lower disk rack... :p oh, and tape measure Cheesecake ^^
    Might be able to get some work done tomorrow aswell, time will tell ^^
    -Cg
  7. Mark_Hardware
    5 Apr 2009
    That's a whole lotta aluminum lol. Looks sweet though! What kind of finish are you going to use? (Sorry if you already answered that)
  8. Guest-23315
    Guest-23315 Guest
    Very nice work dude :thumb:
  9. grevaeg
    17 Oct 2008
    not certain about the finish yet, will either be powder coated, water sanded, or eloxated ^^
  10. ry@n
    ry@n Minimodder
    31 Aug 2005
    Make sure you weigh this monster when its done ;) Seriously hardcore!
  11. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    ^^ What they said.
  12. skreenname
    skreenname SFF Forever
    11 Jun 2009
    He's gonna need a truck scale.
  13. Mark_Hardware
    5 Apr 2009
    what about wire brushed? Or maybe just some of the pieces brushed. Brushed alum is niiiice
  14. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Wow, when you dream big, you dream big!
    congrats on all the sponsors and good luck!
  15. Yourmum366
    Yourmum366 First-Time Modder
    5 May 2009
    What's happening with the wind tunnel idea that was in the renders?
    I liked the idea a lot and wanted to see how you were going to implement it...
    But otherwise, some awesome HDD pr0n coming our way.
    Please excuse me now, I have to pick my jaw off the floor...
  16. grevaeg
    17 Oct 2008
    Well my friend, who knows what might be coming up =)
    Small update guys :p no pics today though ^^
    whats been done :
    * cut the top module in half
    * mounted 4x 360 radiators in top module
    * top plate mounted up
    Tomorrows shipment
    * 2x 240 radiators
    * 12x fractal design 120mm 16db fans
    * 10x meters of 1/2" tubing
    * 110x 120mm golden fan grills... no idea why they sendt me those -.-
    Images coming up tomorrow =)
  17. Yourmum366
    5 May 2009
    :eeek:Is that a typo, or are they just sending you an insane number of guards?
  18. grevaeg
    17 Oct 2008
    The hardware store im buying most of my stuff in are dropping them from stock... so they figured i prolly needed a box... lol, so ill be the proud owner of 100x "gold" 120mm grills tomorrow 0.o
    And another 12x chromed 120mm's :p
  19. Mark_Hardware
    5 Apr 2009
    well maybe you can sell the gold ones as necklaces. Techie bling.
  20. grevaeg
    17 Oct 2008
    MOTM nominee Cheesecake =)
