Case Mod - In Progress Project: 900D Monster Xtreme
Discussion in 'Project Logs' started by The Colonel, 27 Jul 2014.
  1. The Colonel
    The Colonel What's a Dremel?
    18 Jul 2014
    n°4 Aqua Computer D5 pump motor with USB and aquabus interface
    Flow sensor "high flow"
  2. The Colonel
    18 Jul 2014
    safety system shutdown
    Y Splitter for Aquabus
    some cables for Aquabus connections
    some fan extension
    Flow Sensors Connection
  3. The Colonel
    18 Jul 2014
    Let us now something you've already seen, but now we'll look at it in more detail:
    the Aquatube Aluminum Silver
  4. The Colonel
    18 Jul 2014
    and Filter with stainless steel mesh
    But unmount it a bit ...
    A final overview of these filters that I like so much
  5. The Colonel
    18 Jul 2014
    After irradiation of the case with the light of 46 Apollish Enermax 140mm fans, something is mutated ..........
    Something BIG, something BAD, something EVIL
  6. The Colonel
    18 Jul 2014
    Meanwhile, I reassembled the Banchetto 101 to test the HW, this time powered by N° 2 LEPA G-1600 and 780ti EVGA Classified 4 K|NGP|N Edition
    Microcool Banchetto 101
    2 LEPA G1600
    4 Enermax Apollish 140mm
    Intel i7-4960X, 64GB Corsair Dominator Platinum kit, EVGA X-79 Dark, Swifthech H320,
    4 SLI EVGA 780ti Classified K|NGP|N Edition
    Some TEST with 3D Mark Fire Strike, 2SLI 19619, 3SLI 23553 e 4 SLI 25980
  7. The Colonel
    18 Jul 2014
    I decided to start painting, even if it is the painting of the internal parts.
    In theory, I could'ot make it, but in this way so everything will be clean and tidy.
    The problem is the complexity of TdR, I'll do one at a time and unmount the various parts that will paint separately.
    At the end, when I'll assemble and teste plexy covers if there is need I'll give one last hand.
    But let's start by the tower that I had to disassemble, remove the paper tape residual, fill hole a few more, sanded and cleaned with acetone
    Gone with the Primer
    The paint is already dry on the surface, anyway I will give another hand tomorrow
    Actually it is much better and above there is another layer of aluminum that I have taken apart, so it will be even better
    Here's the second Cooling Tower and then the two together with the case, the color is matte black, there are some imperfection, but this is only a first painting and we don't see it because it'll be cover
    Aquatubes and Aqua Filters Supports:
  8. The Colonel
    18 Jul 2014
    Here painted the inside partes of the case, the frame
    I picked up the Cooling Towers, Aquatube and Aqua Filter supports, a nice set of screws and I mount the screws that will be used to secure the plexy and the famous grids.
    Into the screws heads slots I used a two-component glue and now I put the screws in place with a nut, that then I will remove, the screws are different lengths, depending if they whether should also hold or not the grids
    And here is the effect of the grid and the test with 2 layers of plexy as planned
    Overview comparison:
  9. The Colonel
    18 Jul 2014
    Last Saturday I had the pleasure to come back to visit one of EXTREME MODDING FACTORY headquarters and to work with the great C3r34L KilL3rs, this time we dealt plexy covers for my case as planned, the parties were already been cut with a little of margin
    and we then brought them to the precise measurement with this mega CNC, the C3r34L KilL3rs's Frankenstein Machine
    Then we went on this other CNC to do the finer working and that's the 8 main parts that we made
    While I was there I improvised a hot bending test on a black plexy scrap to see how the material react
    Test passed, no color change
    Thank you again to C3r34L KilL3rs and Tombino-, their decision to sponsor me, as well as great for my project allowed me to meet two fantastic guys that now I can truly call friends
  10. The Colonel
    18 Jul 2014
    Back to my secret lab after the weekend with C3r34L KilL3rs at EXTREME MODDING FACTORY I went to make final changes to my case, so to assemble the plexy parts made and finally see the effect that I thought for the fans openings.
    For these Concept and Effect I was inspired by a couple of mods that I've seen even though they were different, I still have to say THANKS to kier, Richard Keirsgieter, a Plexy Magician Modder with whom I had discussed it and he gave me a number of suggestions.
    I have reassemble the parts and tried quickly the plexy; then I assemble completely the case to do a plexy and fans test and especially to see the effect, even if not complete
  11. The Colonel
    18 Jul 2014
    Turn on some fans
    put the plexy covers on side
    and on front
  12. The Colonel
    18 Jul 2014
    Overview
    IMHO it's already beautiful, however, remember the famous grids? well, they aren't yet finished, should be painted, but I tried them anyway
    Overview
  13. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    My god!! Colonel, I salute you!
  14. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Friendly note, must you upload quite so many photos at that resolution? It's a pain as it means this log is basically impossible to read on mobile (for me at least). The page spends so long resizing the images to fit that it often times out or crashes. It would be great if you could resize them to something like 800x600 and then have them link to the hi-res shots? That way your log loads like 20x faster and you don't lose any picture quality.
    Aside from that, this thing is pretty big. Must admit it looks a little like a 90s home theatre setup where you'd have a whacking great CRT in the centre rofl.
  15. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    And the sweetness keeps coming! :D
    Maki makes a fair point though. Loads of pictures at a monster resolution= no fun on mobile.
  16. Hukkel
    Hukkel James' minion
    20 Dec 2012
    You just have to love those fans.
  17. PlaverdaTonk
    PlaverdaTonk What's a Dremel?
    17 Dec 2014
    Epic build. Not to mention how big its going to be!
    If you don't need the plinths that the HDDs slot into in the bottom of the 900D i am more than happy to buy these off you - although i am not swapping Pio Cesare Barolo Cannubi to add to your paperweight collection!!
  18. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I would ask Guinness if they have category for biggest case mod? :D
  19. onevoicewild
    onevoicewild What's a Dremel?
    20 Dec 2014
    Try not to suck the cat up off the floor Bro! Pushing the limits of limits
  20. The Colonel
    18 Jul 2014
    Hi Guys,
    you may have noticed that I have attached grids to the case only through the holes in the corners, however, to get the studded effect I wanted, I made more holes a average 8 per grid, in those holes that aren't needed to put the fastening screws I put shorter screws with a nut on the outside.
    On the inside of the grid, however, where is the screw head, there is also the edge of the perforated sheet which I glued and this cluttered preventing these screws to be perfectly straight.
    Therefore I will go to remove a small semicircular parts so those screws will be perfectly level.
    And here's the result
    I remind you that on the inner part of the grids, once they are painted, I will put some nice rubber adhesive strips that I have already prepared, which will serve both to interpose between plexy and metal both for pieces finishing.
