Case Mod - In Progress Project: 900D Monster Xtreme
Discussion in 'Project Logs' started by The Colonel, 27 Jul 2014.
  1. The Colonel
    The Colonel What's a Dremel?
    18 Jul 2014
    A couple of things I had left behind.
    I had done a LED System and the fans ducts for a front but lacked for the other
    And a third that I've already done it twice: PSUs support, I know that you will not see it and that the PC will stand almost always firm, but I want that all parts are solid and that they remain in place even if the case was overturned.
    I removed the old support
    and I built the new
    the last part of locking
    Next time
  2. The Colonel
    18 Jul 2014
    Latest products arrived.
    Plugs panel with switch, now I just have to find the right place to put them.
    an interesting thing that I wanted to experience: a speed controller for DC motors (Pmax 1000W-15A), why do I needit?
    to adjust LED strips, I know that there are Drimmer ready, but in this Mod I want the wheels to turn (potentiometer) and the problem is that I have many meters of powerful LED strips.
    How do you imagine I could not resist and I did a test immediately
    [video]https://youtu.be/elg6XA38JXI[/video]
    And finally a bit 'of things from Aquatuning
    20 Red LEDs
    2 Station for 20 LEDs
    and 50 fasteners
    clearly I tried also these LEDs
    But go with Modding, as anticipated last time I wanted to put the ducts also in the fans down, even though I knew that it presented difficulties .....
    I take measures and do the ducts
    The problem is that in the structure that I built the opening for this fan is a bit tight so I have to make some changes
    and here is the effect
  3. The Colonel
    18 Jul 2014
    Hi guys,
    Today I finished the work started yesterday, I made another 4 fan ducts
    and shaped the supports so that did not touch on the same ducts
    and now cover plexy is perfectly in place
    today is also arrived a package with some Wrap films
  4. The Colonel
    18 Jul 2014
    Hi guys,
    the carbon fiber wrap red arrived, it doesn't have the same quality as that 3M, however, it seems usable for small details
    Remember when I modified the original windows of the 900D
    Well I decided not to use them and make custom plexy transparent windows, thanks to my friends C3r34L3 and sangyzan for the suggestion.
    First I made a new rear edge, which allow me to attach the rear panel, to have a interspace where to run the cables that go to the Mobo and the SSD and finally that will enable me to put a strip of LED to illuminate the panel.
    Considering the new window and considering the aspect that will have the case without windows, I didn't like the edges because of irregular and with visible rivets
    I therefore decided to modify them so they are smooth and homogeneous so they can be painted or wrap, clearly all aluminum
    Here is the final effect
    What do you think about to wrap these parts in carbon fiber black?
  5. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Do you even read the comments?
    Please, please, PLEASE try to do something about the picture sizing. It took ages to finish resizing everything so I could view the build itself, and that's on a beefy desktop with 152MB internet. I hate to think what this would do to somebody viewing on a laptop over okay wifi or worse a phone/tablet over 3/4G. What's the point in having the log if nobody can read it? It's not a simple copy/paste job posting between forums, they all work in different ways. OCN uploads everything and does it for you, Bit does not.
    /rant
    Slowly getting there
  6. The Colonel
    18 Jul 2014
    Hi Maki role,
    yes I did, I read your problem last time and I apologize for not having responded you and explained my problem. My biggest problem is the time, in recent months, when I stopped I also had family problems, however, to stay on topic I cann't resize all my photos, I'm sorry, let me say that the interface with CODE is not at all comfortable and has many flaws, I don't understand why a so important site not solve this inconvenience with something more modern, meanwhile my options are to insert images in this way, or delete my worklog bit-tech :(
  7. The Colonel
    18 Jul 2014
    I work on pumps support, the initial idea was that it was raised from the plane of about 1-2 cm
    L support
    Horizontal bracket with cable open
    Test height pumps
    fixing plate pumps
    And here is the result
    More I looked them, less I liked ......
    I tried to turn them and ........
  8. The Colonel
    18 Jul 2014
    I do some position test for the loop, something I wanted to use from the beginning are the Silver Coil Mayhems spirals
    here is some tubes
    This solution don't convince me much, especially as aesthetics.
    So I dusted off an old solution that I had set aside because the spaces are too precise, put the connecting pipes under the floor and behind the side panels, another solution is to put out the Tanks
    I then redone the pumps support as anticipated to have more space above and in front
    The support isn't touching the floor, it's raised by 5 mm, the last finishing touch with chrome edging, which I will use also other parts like finish
  9. The Colonel
    18 Jul 2014
    I do the duct fans Wrapping Test to decide which color-material have the best effect
    Assembled it all
    Here are four options:
    1) Mirrored chrome effect, this film is very difficult to put on a curved surface, it is 3M but not for car wrapping, is specific for glass or flat surfaces
    2) Brushed Metal, this film is beautiful and I have seen it used in some projects on SSD and other parts, in this application, however, it seems me that doesn't sit well with the red and black plexy
    3) Red Carbon Fiber, this would be my first choice but 3M doesn't offer this color, so I bought the film on Amazon and with fans off you can see a big difference ....
    4) Black Carbon Fiber, the quality can be seen, 3M original film, a bit thick to put on, but it's fantastic, it isn't exactly the effect that I had thought but very nice I'm reevaluating it
    I would like these parts were beautiful both with fans off that on, certainly you must consider that for a long time the PC is turned on.
    Then turn on the turbojet !
    Here are four options turn on:
    1) Mirrored chrome, much better than turn off, but not the effect that I had thought, moreover this film, because of its characteristics, has imperfections
    2) Brushed Metal, this film hasn't a good effect even with the fans on
    3) Red Carbon Fiber, as expected this color maximizes the effect of the fans LED, but you continue to note the low quality of the material
    4) Black Carbon Fiber, the quality is undeniable, there is also the 3D effect, but there isn't a real incandescent effect of duct as above
    I am torn between the two colors of Carbon Fiber
    PS.
    I ordered a new Red Carbon Fiber film of Hexis specific for Car Wrapping
    https://www.youtube.com/watch?v=ZxVP9eXpy2Y
    http://www.hexis.nl/hexis-skintac-hx30ca200b-kardinaal-rood-carbon-glans-1520mm
  10. The Colonel
    18 Jul 2014
    I modified for the third time the pumps support and the support plate behind
    Before
    After
  11. The Colonel
    18 Jul 2014
    Hi guys,
    arrived a Rock 'n Roll package from the UK, and what's more Rock' n Roll of Fender guitars?
    and I will use the chrome knobs on my Mod!
    Don't you think that I would use those included?
    I wanted do some finish and I wrapped mirror the pumps support plan to get a chrome effect
    I painted with chrome paint the black supports that I had sawn
    At the end finishes will be all chrome as fittings.
    Here is the piece assembled
  12. The Colonel
    18 Jul 2014
    After the first LOOPs tests with illuminated plane, pumps and Cooling Towers in position I decided to put out 2 BP Water Tank Z-400 Multi, that are fantastic and huge, as you know. I'll do a specific Mod of these Tanks.
    The first tests made however were not satisfactory:
    I so decided to make a change that in the course of Mod i think several times, but had never done because it would take me a lot of time: making an extension which lengthens further case.
    In a first version I tested an extension of 100 mm
    in a second extension of 120 mm, that's the difference before-after treatment "Enlarge your Case"
    and the case with both extensions installed
    I also had to redo the case top , this has made happy my monkeys because before the Monsta was precise whereas now there is much more space
    A test with a cover (it isn't the final one) and the grid
  13. Icelander
    Icelander Minimodder
    3 Mar 2015
    this is Nuts. HUGE Case Colonel
  14. The Colonel
    18 Jul 2014
    Yes, IT is. Thanks Bro! The case is HUGE and it give me much more work than I thought!
    Meanwhile also arrived the new Red Carbon Fiber film of HEXIS for the fans ducts. I ordered it in Nederland, the previous film hadn't satisfied me for the low quality, this costs about ten times more but the difference can be seen. It's of the same quality of 3M if not better, with real 3D effect to the touch
    CORSAIR NEW SPONSOR for Project 900D Monster Xtreme
    I'm finally VERY HAPPY to announce a new sponsorNEW SPONSOR for the new version of my Project, I want to thank CORSAIR and Jon for their support and for the RAM DDR4 send me
    Dominator Platinum Series 32GB (4 x 8GB) DDR4 DRAM 3000MHz C15 Memory Kit (CMD32GX4M4B3000C15)
  15. The Colonel
    18 Jul 2014
    Another reason for which I did the Tanks extensions is that I will use 2 PSU, 2 LEPA G-1600W. However these remain inside the case and are not accessible, so I will use sockets with on-off button.
    Initially I wanted to place the PSUs under the Cooling Towers, but the space was little and remained under the RADs, thing I didn't like at all, but now I have much more space, the plug is next to the PSU and not under the RADs.
    Here is below the case and positioning
    I then made metal extensions covers, that then I'll wrap.
    I did 4 panels to size.
    I have bent them
    Some tests with the Tanks of Bitspower positioning higher and lower
    I fasten the cover extensions
    and the socket panel
    The fan bocks that are inside the 900D were a bit covered by grids, about 25mm per side, thanks to the extension I can overcome this problem, I have "only" widen these grids, that is remake them.
    Top case
    and lower lateral blocks
    Test on the case
  16. The Colonel
    18 Jul 2014
    Once again I thank my new sponsors CORSAIR, and Jon Gerow for his support, they have posted the new RAM DDR4, as usual, for me, Corsair Platinum, the BEST RAM of EVER:
    Memory Kit C15 DRAM DDR4 3000MHz 32GB (4 x 8GB) Dominator Platinum Series (CMD32GX4M4B3000C15)
    After years is a real satisfaction for me have Corsair as Sponsor
    Let go the unboxing, the kit that Corsair sent me is of 32GBs and equipped with air cooling.
    It features a beautiful box, but the most important thing is that the modules are Platinum of 8GBs (faster than Corsair do), so I'm free to upgrade to 64 GBs
    Here the air cooling module
    And RAM Modules
    I LOVE these things .....
    NOW starts the upgrade to X99
  17. Gramps-Makarov
    Gramps-Makarov What's a Dremel?
    11 Aug 2015
    Stuning project, deteljs and creitivity!
    Top of the line :D
  18. uerseya
    uerseya Covered in rock wool
    25 Aug 2008
  19. Cheapskate
    13 May 2007
    ^This. :lol: Also, If you have photoshop, there's a way to record the process and turn it into a one-click button macro.
    This thing has doubled in size since the last time I peeked in. HUGE! :D You've made enough frame for 4 or 5 cases now.
    I didn't notice it before, but you might not want to display your silver coils. They are there to corrode and leak silver biocides into the water, so they will turn grey and eventually black.
  20. The Colonel
    18 Jul 2014
    Thanks Buddy! Winter is coming! And will be HOT HW for me ;)
    Sorry Bro, I know this problem, but is the forum that have a bud interface, this is my hobby but I like spend my time (I don't have a lot :( ) modding, if you have this problem can you see my worklog in other site
    Really the case is now HUGE..... I think it's like 3-4 900D !
    But now it has reached the final dimensions
    Yes I know like works the silvber coils, I hope I have time to do many Photo before it turn color
