[Project] a fine day to die (Planning stage; input needed)
Discussion in 'Project Logs' started by Bbq.of.DooM, 15 Apr 2007.
  1. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    I've been wanting to do this casemod for the last 4 years, but no case has been suitable. The closest was the Silverstone TJ08. It meets all my requirements, except for the one which needs it to hold full ATX. Of course, this changed not too long ago with the release of the Lian Li A-05. Very small, holds a ton of hardware, full sized heatsinks, and is quite cheap (by Lian Li standards).
    Hardware that's going into it, unless I buy something new in the meantime:
    AMD Opteron 146 + Scythe Infinity
    Asus a8n-sli
    eVGA E-Geforce 7800GT (470/1100) + Thermalright HR-03
    4x512 DDR ram
    3 hdd's (Maybe I'll just get a single big sata, so i don't have to deal with a pata and 2 sata's.
    Sunbeam NUUO 550w (I'm really uncomfortable about using this psu in such a small case. I might buy something else)
    And of course, a Lian Li A 05
    Since the A05 is so new, I couldn't find any sketch-ups for it, so I spent an hour and made one:
    Another view:
    And another one:
    The right sidepanel (upside down case) will have a small rectangular window with rounded corners, and in handwriting, "a fine day to die", engraved into the case (or cut into the case).
    Input: I need to know which of the handwriting will fit this mod properly. I like #3, but it's not too suited for the style of case. Too happy.
    Also, if anyone can find me a good handwriting font that would match this case, I'd love them long time.
  2. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    Liking this idea, and for your font question, I'd suggest you take a look at www.dafont.com and look for handwritten fonts. I guess you will be able to find one there suited for your case.
    GL with your modding :dremel:
  3. Bbq.of.DooM
    12 Feb 2005
    Thanks for the link. I've added some more for judging. Thing is, the font can't be too 'happy'. Handwriting is a must, too. I have the PERFECT font out, but my scanner is broken.
  4. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    i would go with No 3.
    and you could submit your Lian-Li case to the SCC :)
  5. Bbq.of.DooM
    12 Feb 2005
    I still need to buy the case.
  6. ZenX
    ZenX How are you gentlemen?
    5 Aug 2005
    I like #7 the most
  7. <Blake>
    <Blake> What's a Dremel?
    16 Feb 2007
    7 8 or 9 look good
  8. elbarto241
    elbarto241 What's a Dremel?
    12 Sep 2006
    9 is the one to go with. unless you found more candidates at dafont.com?
  9. dacust
    dacust What's a Dremel?
    10 Mar 2007
    The question is, what emotion are you doing for:
    • Disturbed
    • Maniacal
    • Depressed
    • Mildly annoyed
    • Matter of fact
  10. Bbq.of.DooM
    12 Feb 2005
    it needs to be is somewhere between evil, while being minimal, elegant, and also possible to do with a dremel.
  11. dutchcedar
    dutchcedar What's a Dremel?
    24 Oct 2004
    File > Export > 2D image > Save in: where ever your heart desires
    Reduce the image size to something reaonable... etc.
    Thought ya might wanna know how... :D
  12. SlappKnutts
    SlappKnutts What's a Dremel?
    28 Jan 2007
    I'd lean more towards #7, but then I dont think its perfect, it needs to be more... evil, gothic, japanese... something along those lines.
  13. Evenge
    Evenge Minimodder
    16 Sep 2006
    7 and 9 looks nice...
  14. RonaldoR9
    RonaldoR9 What's a Dremel?
    17 Dec 2006
  15. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
  16. Bbq.of.DooM
    12 Feb 2005
    I've decided to go with font #7.
    Just gotta wait for NCIX to get the A05 in stock..
  17. KodiakStar
    KodiakStar What's a Dremel?
    3 Jan 2005
    Wow you are a member here too :)
  18. Lucifer's Shadow
    Lucifer's Shadow What's a Dremel?
    28 Mar 2007
    I like 7 myself
  19. Raziekiel
    Raziekiel What's a Dremel?
    12 Sep 2006
    I like 7 and 3
  20. Monkeyboy
    Monkeyboy Minimodder
    13 Dec 2003
    lucky number 7
    it looks like the loops on some of the a's don't connect, so it would be easy to cut that into the case and not worry about the center of the letter (since you mentioned possibly cutting it into the case). could do something similar to the o's and e's. would look real nice backlit.
