Scratch Build – In Progress Project ADAMAS - 04/03/16
Discussion in 'Project Logs' started by Phame, 4 Mar 2016.
  1. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Intro:
    Project ADAMAS is a scratch build which has sadly kept getting
    put on the back burner as I have just been so busy but I have been
    making more time for it and started folding the panels and machining parts for it.
    Hardware:
    All the hardware in the build is subject to change.
    Motherboard: TBC
    CPU: TBC
    RAM: 64GB Dominator (8 sticks)
    GPU(s): Titan 4-way SLi
    PSU: TBC
    SSD(s): 8 x TBC
    Watercooling:
    All watercooling will be custom Diamond Cooling parts
    with some new products from the 2016 range.
    To do List:
    Finish up design - ☑
    Laser all parts and panels - ☑
    Fold panels - ☐
    Assembly of parts and panels - ☐
    Machine various parts - ☐
    Paint/powder coat - ☐
    Hardware - ☐
    Final assembly - ☐
    Hardware installation - ☐
    Finish this BUILD! (ETA 01/06/16) - ☐
  2. Phame
    17 Sep 2012
    UPDATE:
    Started to fold all the main structural panels of the case.
    This is the base panel that will hold two of the three (360) rads in the build
    Test fold
    One down...
    The top panel will serve as cable management to hide all the
    shoddy cables and hopefully make for a clean look
    I machined the ADAMAS logo into the top corner and scotch brite'd it back.
    I have some more panels folded but will update the log with those soon.
  3. Cheapskate
    13 May 2007
    Looks good already.:D
  4. IonKnight
    IonKnight What's a Dremel?
    17 Jun 2011
    Looks great just wondering what did you use to bend the aluminium?
  5. Phame
    17 Sep 2012
    Thanks bro, still alot to do! :)
    I have a 1.5m and 2m brakepress mate, I will show them in the next update. :)
  6. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Having seen a tad more than this I can honestly say this is going to be absolutely amazing.
    I am so looking forward to how this project will look all finished.
    Good luck buddy!
  7. disturbed13
    disturbed13 Minimodder
    28 Nov 2008
    okay, im sub'd
    8 ssd's and a quad SLI Titan GPU set up
    lets get on with it!
