Scratch Build – In Progress Project: Aerodyne
Discussion in 'Project Logs' started by slipperyskip, 21 Nov 2011.
  1. slipperyskip
    slipperyskip Member
    26 Oct 2003
    The garnet-based fingernail files (not emory) are nothing but sandpaper on a stick. Very useful for doing precision work. Don't tell your mates though. :hehe: I send the wife out to buy mine. She knows I'll just steal hers if she doesn't.
  2. Waynio
    Waynio Relaxing
    20 Aug 2009
    :hehe::thumb: Yeah I found some in a draw while rooting around for modding bits & just thought they'd be excellent for some detail sanding :D.
  3. Dragonphreak
    Dragonphreak Minimodder
    26 Oct 2005
    I love the look of this build. Can't wait to see what you do with it from here.
  4. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Hahaha, another item on the list to steal from the misses!
    Hairdryer - bending plastics
    Tweasers - soldering aid
    Stockings - airbrush detail
    and now
    Nail files - precision sanding
    Nice !
  5. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Probably the same story on how I first started using them. A McGuyver moment I guess. :thumb:
    Thanks and welcome to the "show".
    Makes the wife feel like she's participating...besides getting me a samwich now and then. :D
    Cut the birch plywood "base" to the dimensions that look right...to me.
    The four square pegs are friction fit to just barely protrude above the surface. I can now sand the ends so they are as flat as possible. This will all become clearer later...hopefully.
    Made up some end caps and glued them into place. These complete the enclosure structure and makes it very solid.
    Final trimming of the grille. It's just about ready to be sent out for casting :hehe: Casting?
  6. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Aluminum?
  7. Waynio
    Waynio Relaxing
    20 Aug 2009
    :eeek::rock: I think, if you mean the grill bit :D.
  8. slipperyskip
    slipperyskip Member
    26 Oct 2003
    That's the plan.
    The sand cast aluminum grille in this photo is "pinched" in place between the aluminum cover and Bakelite base. I built mine the same way.
  9. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Sweet, fantastic wood work, as always:thumb:
  10. jhanlon303
    7 Sep 2006
    I'm on board! mini-ITX, Slipperyskip without a rush, Bliss.
    Oh, and Sally's Beauty Supply is a scarey place for neat detailing tools. Bring an available female and just browse. Be sure to scope out the small white nail sanding blocks - just sayin.
    john
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    ^ :lol:
    Nice :) the wood version looks sweet too though but yeah I guess it needs to be for a nice cast :D it'll be awesome.
  12. Cheapskate
    13 May 2007
    Casting? We have been a bad influence on you.:lol: I'm really happy there's a SS build to watch for the holidays!
    Please say it's gonna be brass.:D Polished brass and wood looks sweet.
  13. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Thanks phinix! I appreciate you stopping by and commenting.
    Hey John! Walked by a Sally's last Friday and thought of you. Gotta sneak inside there one of these days.
    It will either be cast or look like cast. Most people can't tell the difference from a photo and I'm not sayin' unless asked. :naughty:
    Brass would be sweet especially against mahogany. They go well together. Don't think I can fake polished brass with all the paint in the world. I'm talking to several foundries about pricing so we'll see. I'm hoping to find a fan of my work at one of these places or at least an easy bank to rob.
    My four "pegs" attached to a piece of 6-ply 1/8" birch plywood.
    Four small brass wood screws are countersunk and driven into the backs of the pegs.
    A design I'm playing with. A subroutine is constantly running in the back of my head concerning a decorative element for this thing. Lots of others to try out.
    Thanks for stopping by and looking!
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    That would actually be cooler IMO as it wouldn't cost anywhere near what casting would :D.
    The pattern looks nice to me :thumb:.
  15. Cheapskate
    13 May 2007
    The alternative to casting would be hammering some bars into shape, a little soldering on the brackets, and a lot of sanding.
    Neat design. It would look cool with the round area as a flattened hemisphere of wood, and the 'wings' as raised metal bars.:D
  16. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Cost is the excuse I've used in the past to not cast. I always just assumed it without actually checking it out. This time I'm getting quotes, talking shop and checking out alternatives and quantity price breaks.
    Get out of my head man! :cooldude: Bending bars and soldering is not going to happen because I don't think the quality (and accuracy) would be there no matter who or how well it was done. I have a few design ideas that are in-line with your suggestions. I'm looking primarily at aerodynamic-themed stuff. You know...looks like it is going 100 mph while sitting stiil kinda stuff.
    A refresher on how I cut panels. A stationary fence used with a finger fence and razor saw. It takes about 45 minutes for each cut. The result is a very clean edged cut that promotes adhesion for the following veneer layer. Power saws rip up plywood along the edges and thus lose a significant percentage of adhesion surface where it is needed most. Did I just say thus? Damn. Watching too many shows on the BBC.
    Identical panels. I mark the corners that are factory laser cut so they can be matched up later.
    First course for the sides.
    Second course creating a pocket for the USB ports. Ends are criss-crossed.
    Need to figure out how to do better close ups on this new camera.
    Same corner as above after third course and trimming.
    Fourth side is different. It has to be thinner to accept various switches and plugs.
    Gathered up my remaining mahogany. The higher quality stuff comes in thinner widths but these pieces are laser cut so matching edges is easy. An acceptable compromise IMO.
    Thanks for looking.
  17. peteski
    peteski long live the pc
    8 Jun 2011
    loving your wood work skills :rock: :rock: :rock:
  18. Dragonphreak
    26 Oct 2005
    I love the grill look. Reminds me of some 50's art decor.
  19. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Thanks peteski!
    If you are talking about the design I sketched on the side then this is the inspiration. If not then...nevermind. :hehe:
    Inverted photo of a 1937 Philco 610T Radio.
  20. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Every bank is easy to rob! It's the getting away part that's difficult! :lol:
    Looking really nice! Can't way for this to go further! :thumb:
