Case Mod - Complete ⭐ Project ALIENBASE - Alienware Aurora R4 Case ATX mod
Discussion in 'Project Logs' started by 4LIEN, 10 May 2020.
  1. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Yes you did it (update) !! :clap::lol:
    4LIEN likes this.
  2. 4LIEN
    4LIEN Modder
    4 Jan 2020
    I really appreciate your interest, tomorrow new updates!
    Canardwc likes this.
  3. ciaognep
    ciaognep Minimodder
    10 May 2020
    it's and hard modding... :happy:
    4LIEN likes this.
  4. 4LIEN
    4LIEN Modder
    4 Jan 2020
    You are really right, it seems easy to see the photos, but in reality every modification requires a lot of time and attention to have the best results.
    Here are another update, the second part of the side window!:rock:
    After cutting the window hole, i have to cover the gap between the black shield and the metal panel (red line).
    So i take a 3 mm forex sheet and bend it with heat to follow the S shape of the panel.
    But before set it, i've make the clear plexiglass window
    And then with the window installed i finished shaping the forex sheet, wrapped in matte black and glued to the black shield.
    I've made also extra screws points to fix the metal panel to the shield, using m3 stand sticked with epoxy.
    The original Alienware plexiglas panel was also shaped and the RGB LED bar fix with little screws in the new position.
    On the left and on the top of the picture, you can see black sheet, they are always PCV forex, i've made them to cover gaps and metal panel parts.
    Cheapskate and ivory2k19 like this.
  5. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Finally i've wrapped all the black shield with a special vinyl with honeycomb 3D texture that create a mix of reflections dark and clear!
    And this is ready to install! One of the first part 100% done!
    Painted all the metal in black, and deep polished the Alienware plexiglass!
    For now, i keep the lower black shield without wrapping, because i like the difference in colors.
    lowfat, ciaognep, Cheapskate and 4 others like this.
  6. Canardwc
    22 Sep 2011
    A snake or comodo dragon it looks :clap:
    ciaognep and 4LIEN like this.
  7. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Today i will show a special part that i realized for this mod! Also there will be others special parts in the future!
    I like recycling things from all over the world, so i found this component, it's a metal ring of an electric industrial motor 220V / 380V, and when i saw it my imagination started....
    So i started to mod it, cutting some parts and sanded all
    Painted in metalized silver
    Added a blacked out RGB LED strip
    Cutted two round of plexiglas and wrapped with mirror film
    And that's it! Infinity mirror! But it's not finished, tonight i will post more!
  8. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Look's mad mate I like it,great job so far.:dremel:
    4LIEN likes this.
  9. Vault-Tec
    30 Aug 2015
    That's awesome :D
    4LIEN likes this.
  10. Vault-Tec
    30 Aug 2015
    Maximum Armour. :D
  11. kim
    kim hardware addict
    10 Jan 2016
    wow, great recycled part, it became fantastic with that infinity mirror :rock:
    4LIEN likes this.
  12. ciaognep
    ciaognep Minimodder
    10 May 2020
    go ahead!!! :rock::rock:
    Canardwc and 4LIEN like this.
  13. Canardwc
    22 Sep 2011
    The Green Iron Man Arc looks pretty :lol:
  14. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Thanks to all guys!
    @Canardwc this isn't an Ironman style arc, you will see now why!
    I've made an hole in the back side of the ring
    Placed in the hole a LED strip
    And designed and then laser cutted a new plexiglas ring...
    Also glued the LED strip on the back of the mirror
    Another parts recycled from my old case from 2010! Side panel clips! (in red squares)
    Painted in matte black
    And this is the finished result! So i have make an Alien portal, so aliens can enter in their base! LOL! :clap:
    (don't care about bubbles and scratches, they are on the protection film)
    This is what my imagination saw when i saw this old motor ring frame in the trash!
    This portal will be placed on the right of the MB, over the wires cover.
    Cheapskate, ivory2k19, Toru and 2 others like this.
  15. 4LIEN
    4LIEN Modder
    4 Jan 2020
    More like Crysis! :grin:
  16. Canardwc
    22 Sep 2011
    Or Predator style
  17. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Now that's modding! :rock::rock::rock:
    4LIEN and Canardwc like this.
  18. ivory2k19
    ivory2k19 Minimodder
    8 Feb 2019
    Dang dude it looks really nice:thumb:
    4LIEN likes this.
  19. 4LIEN
    4LIEN Modder
    4 Jan 2020
    In the last weeks i've started the painting process of some parts that are finished, and it take a lot of time, filling, sanding, apply primer, apply base coat (here in the picture), sanding again wet, dry, etc....
  20. Canardwc
    22 Sep 2011
    Yep that's exactly why I really don't like painting job. :waah:
    But have de to those boring stuff for good quality
    YOU seems to do it right :thumb:
    4LIEN likes this.
