Case Mod - Complete ⭐ Project ALIENBASE - Alienware Aurora R4 Case ATX mod
Discussion in 'Project Logs' started by 4LIEN, 10 May 2020.
  1. ivory2k19
    ivory2k19 Minimodder
    8 Feb 2019
    A lot of work i know how you feel :rollingeyes:
    4LIEN likes this.
  2. Mojo
    Mojo Multimodder
    18 Nov 2011
    That is a fantastic effort!!
    Loving this build so far :)
    4LIEN likes this.
  3. MADPC
    MADPC Minimodder
    10 May 2020
    interesting job
  4. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Thanks guys, meanwhile i'm painting, in the waiting moment in these days, I started working on the bottom PSU cables cover and other important parts....
    The PSU cover will be fixed with some screws and magnets
    All the bottom area of the case will be covered with a plexiglas panel, in the following picture i'm making a prototype with PVC forex and after will transfer it in illustrator to get ready for laser cut
    I've also makes a 3D render to see how i can make it!
    Other important parts are the foots, firts, i've cutted the L shape case extension riser, added another L shape reinforcement, and finally maked a prototype of the foots with PVC forex, and they will be maked with CNC aluminium
    After, I've maked all the holes for the wires from the PSU
    Wrapped all the cover in matte black and sleeved a cable just to test fit the holes
    Also maked some holes for two 2.5" drives
    And finally i will use a multiple terminal to make a "central power unit" to connect all the devices, SATA, MOLEX, LED, etc...
    In the next days i will post more update!
    ivory2k19 and Jean R built like this.
  5. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Here are the second part, but before the worklog pictures, i have to announce a big news for this project and also future projects!
    I've stared a collaboration with an Italian company that make high quality sleeved cables with MDPC-X materials! They make very cool cables set that you can config as you like, or if you want to D.I.Y you can also buy the materials from the main website ----> HARDWIRE
    So with the materials supplied by HARDWIRE, i started to make some new aviator connector for my PSU!
    Painted some bolts in silver....
    And after some time this is the final result!
  6. kim
    kim hardware addict
    10 Jan 2016
    That's great, nicely done, :thumb:
    :grin: I enjoy to see some ideas I had about the Tagan and the cable managment coming to life :rock:
    4LIEN likes this.
  7. 4LIEN
    4LIEN Modder
    4 Jan 2020
    So i can't resist to the end of the mod, and i maked this :grin:
    Canardwc, Vault-Tec and Jean R built like this.
  8. Jean R built
    Jean R built Modder
    17 Feb 2020
    4LIEN likes this.
  9. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Those cables are one of the coolest things i seen i ages!!! :thumb::thumb:
    4LIEN likes this.
  10. Vault-Tec
    30 Aug 2015
    Yeah they are awesome. Hard to find though !
    4LIEN likes this.
  11. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Thanks guys! I think i'm one of the first that make LED mod on AC cable!
    Canardwc likes this.
  12. 4LIEN
    4LIEN Modder
    4 Jan 2020
    So guys i've finally painted the case frame! Don't care about the unpainted MB area, i need clear metal to have a ground connection, it's very important!
    So I've installed the LED strip for the I/O illumination
    I've also maked an hole behind the CPU and some little holes behind RAM, so they allow better passive heat dissipation
    And this is a preview of the color of the central parts of the case shield!
    This is a special paint, made of matte grey with micaceous and metalized effects! (the photo is taken with flash, so you can see reflections...i hope...i will try in the end to take professional shots)
    Cheapskate, Vault-Tec, MADPC and 2 others like this.
  13. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    You won't need the bare metal the threading on the standoffs will take care of the grounding
  14. MADPC
    MADPC Minimodder
    10 May 2020
  15. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Yes i know, but in my project this way didn't work, because the MB support plate it's separated from the case frame, so the only connection are the clear screws that you can see...in the previous pages you can see the work done to adapt the ATX MB plate
  16. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    YOU should mod faster ! I'm impatient to see next steps and the final case !!! :clap::clap::clap::thumb::thumb::thumb:
    You maybe know if you follow Douglas alves mod, i'm not à fan of lights and rgb but you do it clean and right !!! :p::lol::thumb:
    4LIEN likes this.
  17. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Thanks, i really appreciate your support! I'm working hard to try to finish the mod ASAP, but the time in my life is very short! i can do the bigger work only in the weekend :(
    About the lighting, i really hate the A-RGB, so my project will not have this kid stuff :lol:, but will be all single color R.G.B with some pure white 5000K spots!
    Defyant Mods likes this.
  18. 4LIEN
    4LIEN Modder
    4 Jan 2020
    So another working weekend, this week i be able to make some new parts for the project!
    These are the side PSU panels, glossy black acrylic 3 mm
    After i make the backlight panel, recycling parts from a broken LCD LED display
    Installed the parts with RGB LEDs
    In the front there is a mirror chrome film
    And this is the final result! Very smooth lighting!
    These are the case foots, for now without holes like the concept, but i think i will do very soon....
  19. Defyant Mods
    14 Sep 2004
    I'm such a fan of rgb case lighting when it's well done! and that's VERY well done! :rock: the PSU side panels look awsome are they laser cut?
    4LIEN likes this.
  20. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Thanks, yes they are laser cutted, and designed by me with illustrator!
