Project : AlienWorx - UPDATE !!CONTROL PANEL BRUSHED - TOP
Discussion in 'Project Logs' started by w4rr1or, 4 Jan 2005.
  1. w4rr1or
    w4rr1or New Member
    24 Dec 2004
    I just started my 1st mod so let's start with the pics and some details . The main goal i want to succed is to put as much of my modding talent as possible on this project and give a big attention to details.
    I created the feet of the case
    Aluminium and transparent acrylic where i am going to install some green leds
    I will update in a few Hours as i am going to school ! Keep updated lots to come
    EDIT: The feet are not completed yet. Need to be polished and formed into a perfect circle
  2. w4rr1or
    w4rr1or New Member
    24 Dec 2004
    Small Update - Center Control Panel Designed
    Here is the control panel that would be placed in the middle of the front . Tell me what you think.
    BTW. Dont mind the Colors , its just the marking on the polished aluminum and after i make the holes i will print it again without the holes marked on a transparent paper . After that, i am going to attach it to the aluminium and in the same time on the front with some alien screws!
    ALSO, the eyes of the alien will be cut and frosted plexi will be placed behind it, green uv leds will be installed and the eyes will be used as HDD activity
    Keep updated!
  3. WaZzUp115
    WaZzUp115 New Member
    12 Feb 2004
    Cool feet, and cool design :thumb: !
    Maybe i'll make such feet myself :D!
  4. Cereal
    Cereal New Member
    28 Feb 2004
    yeah, really like the feet, like the front control panel alot
    keep on workin'
  5. DoNuT
    DoNuT New Member
    20 Dec 2004
    That is a cool idea for the feet...might have to try it. Also what kind of case are you working with, just out of curiosity.
  6. w4rr1or
    w4rr1or New Member
    24 Dec 2004
    TOp design Completed
    Where it writes Alum , a piece of polished will be placed with alien screws . Where it writes UV Plexi, a piece of uv reactive green plexi will be placed after the piece will be cut off the case. In the middle an 120 mm Aluminium Framed fan will be installed
  7. Cereal
    Cereal New Member
    28 Feb 2004
    as long as its really clean, that top will be nice
  8. Arkuden
    Arkuden mow?
    9 Jul 2004
    yes this should be a nice clean mod. Cant wait to see more progress
  9. w4rr1or
    w4rr1or New Member
    24 Dec 2004
    Thanks guys, as i said i am really really inspired by the attention of detail that many other modders give in their projects. There is nothing better than a nice clean case!:)
  10. Iaidoka
    Iaidoka New Member
    20 Jul 2004
    Are you planning to build the case completely from the ground up, or are you using another case as a base?
  11. george_seamons
    george_seamons New Member
    27 Nov 2002
    Hahahaha...that is so blatently my design for the control panel! :hehe:
    It's ok though, I don't mind. A little credit would have been nice though :p
    Maybe it's just me being petty. I'm not really bothered, I just thought it was humerous.
  12. Bubba8
    Bubba8 New Member
    28 Sep 2004
    What program did u use to make that panel design?
    btw it looks great :thumb:
  13. Cereal
    Cereal New Member
    28 Feb 2004
    haha, thats funny
  14. preatorian
    preatorian New Member
    18 Aug 2004
    does'nt look like alienware at all *coughs*
  15. george_seamons
    27 Nov 2002
    If you're talking to me, I used AutoCAD 2004.
  16. w4rr1or
    w4rr1or New Member
    24 Dec 2004
    Update: Control Panel 50 % Finished - Brushed
    Yo guys, im back again with an update. I finally decided to brush the alumium that was going to be place in front of the case ( It's my first time that i attempt to brush anything ). I still need to print the layout on a paper to cut the holes, print the transparent paper and attach it to the front with alien screws. Here are some pics!
    How it was before i started
    The reflection
    1st "layer" of brushing
    A not so good zoom
    The finished !:)
    Keep Update. I m probably gonna post some pics of the cut aluminium pieces of the top
  17. w4rr1or
    w4rr1or New Member
    24 Dec 2004
    UPDATE: TOP 80 % FINISHED
    As i promised! The top aluminum parts have been cut however i changed the Template of the Top. It still needs to be sanded , mount the aluminium pieces and the aluminium 120mm fan and of course paint it!
    Between the alumium parts, the uv green acrylic is going to be installed and lighted with leds
  18. OverFloW
    OverFloW New Member
    30 Jul 2004
    I suscribe :thumb:
  19. Cereal
    Cereal New Member
    28 Feb 2004
    id it dead?
  20. MAD_OCM
    MAD_OCM New Member
    12 Feb 2005
    very interesting, look forward to updates. :thumb:
