Modding Project all-plexi keyboard --KONG is a god!! -- no really! he is!!!
Discussion in 'Modding' started by malcs, 30 Aug 2003.
  1. sirgeoph
    sirgeoph What's a Dremel?
    19 May 2003
    im not sure if the power situation has been handled, but one thing you could do is un a usb cable into the keyboard with the ps/2 cable. use the ps2/ cable for the keyboard and a bit of power, then use the usb merely for power... they have a playstation2 controller with a fan in it (i know, i know...) similar to that... it uses the usb port for power.
  2. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    kong-- updated DXF which i have uploaded btw im going to sign in to msn now
    DXF FILE
  3. Hyjnx
    Hyjnx What's a Dremel?
    16 Sep 2003
    sooo true!...im completely lost in what is going on here..which someone would diagram it for me
  4. kong
    kong cnc-guy
    24 Feb 2002
    I got it, I'll do the 2d.
  5. malcs
    24 May 2003
    this is the paint file that i did quickly :D
  6. Hyjnx
    16 Sep 2003
    ok that helps...u got the wiring figured out?
  7. malcs
    24 May 2003
    *another paint file requred here i think
    i will just do a quick drawing again....
  8. malcs
    24 May 2003
    the grey box is the top transparent bit for each switch, the blue box is the bottom bit to hold the circuit :D
  9. kong
    kong cnc-guy
    24 Feb 2002
    Mines better! \*sticks out tongue*\
    Firstly, a set of keys, from 3mm acrylic.
    Next, this is the top layer of the sandwich, 2mm polycarb, with holes for the keys cut out. Obvioulsy I will need to leave about 0.5mm clearance in each hole so the key doesn't stick. Look ok?
  10. Hyjnx
    16 Sep 2003
    did you get the delay down? like so it fades?
  11. malcs
    24 May 2003
    wow kong that does actually look fantastic :D
    edit @hyjinx it does have the fade thats what the capacitor is for :D
  12. Hyjnx
    16 Sep 2003
    sweet...so how much for one of these?
  13. malcs
    24 May 2003
    dunno we'll have to see how much it costs to build this one lol im not looking forward to all the soldering though lol
  14. Hyjnx
    16 Sep 2003
    u gimmie a price (USD) and if it works and looks sweet...ill buy it :) *But dont hold me to that*
  15. malcs
    24 May 2003
    why that sure does sound mighty tempting mister :D but you would have to ask kong for the price of manufacturing the plexiglass etc.... Anyone know where i could find myself a nice cable to whack onto it?? i could even do my own if i could find some real nice style braiding although EL wire would look niiice along the length of the cable :D
  16. Hyjnx
    16 Sep 2003
    ok kong...same question
  17. malcs
    24 May 2003
    am busy buying electrical components off RS-- just found an electrically conductive adhesive pen-- sounds great!! that should mean that i can just trace the circuits then stick on the components!! no soldering!! no transparency to melt!! that should make the cost significantly lower :D
  18. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    That is so cool. Btw, do pens which can draw conductive traces on e.g. plastic exist too?
  19. malcs
    24 May 2003
    these epoxy pens do :) on all surfaces it says :) good good :D
  20. bard
    8 Mar 2003
    How much are they?
