Scratch Build – In Progress Project : Alu Blue [Update: 26 Feb] Detail Work
Discussion in 'Project Logs' started by lamanl, 20 Jan 2011.
  1. OC Maximus
    OC Maximus What's a Dremel?
    7 Aug 2010
    I'm a big fan of the honeycomb look. Very nice work so far.
  2. j0rd
    j0rd FLOSS folder
    13 May 2011
    The hard disk rack is great, will the drives mount with a slight slant? just wondering because (what i assume are) the screw holes are at an angle. Looking forward to seeing the panels on this rig, the shape is very unique :)
  3. TimtomNL
    TimtomNL What's a Dremel?
    25 Jan 2011
    :clap:
    Looking forward to see the sidepanels!
    And I was hoping to see a sneak-preview of the front ;)
  4. bulldogjeff
    2 Mar 2010
    Lokking back through the log, it's all coming along really nicely. The honey comb grills look superb. Nice work:thumb:
  5. domthecondom
    domthecondom Noob Modder
    27 Jun 2010
    Nice scratch build :)
  6. lamanl
    lamanl So little done, so much to do
    4 Nov 2009
    first of all
    thank you al for the compliments and comments :D
    and yes the harddrives will be mounted under a slide angle
    as promised
    now let's start with the side panel
    made ??of 1mm anodised aluminum like the front panel
    that big hole is for the side window
    and next, underneath the window hole the cut out for the 3x120mm rads
    :naughty: :dremel: just to finish the radius
    And done after allot of filling
    Hope you like it, and thnx for looking
    PS: as you can see in my signature i already got my new components photos up next :D
  7. randomhero
    randomhero Minimodder
    6 Nov 2005
    Looks great and man you have some clean edges on your cuts :D
  8. lamanl
    4 Nov 2009
    I was able to get the intel DX58O2 at a auction for €133 (new) instead of €220
    I planned to wait with my upgrate until the case was finished, and than go for the Gigabyte GA-X58A-UD3R
    but for €133 I could not wait
    and I also immediately purchased the other components because it is a shame not to use the motherboard
    I hesitated between:
    Gigabyte GA-X58A-UD3R €189
    Asus Sabertooth X58 €164
    Asrock X58 EXTREME 6 €187
    Intel DX58SO2 €220 paid €133 :D
    The cheapest X58 board is €140
    I have chosen the DX58SO2 because it was cheap :D and it has 8 SATA ports, 2 of them sata 6 and 2x usb3
    The photos were taken with another camera because my Canon 400D was not available
    Mushkin Blackline 3x2GB DDR3 @1600mhz 7-9-7-24
    OCZ vertex 2 60gb 25nm! and i think V2
    i got 200mb/s READ and 60mb/s WRITE
    and not 35mb/s WRITE every one complains about
    Intel I7 950 3.03 Ghz
    boxed cooler until case and water coolings is done
    Thats it for now, next the cut out for the 3x120mm rads
  9. TimtomNL
    25 Jan 2011
    I like the components! Minus the boxed cooler :wallbash: ;) :waah:
  10. lamanl
    4 Nov 2009
    thnx tim
    srry was realy bussy modding and not blogging :duh:
    Safety First :D
    firts drilling the hole so i can put my jigsaw in
    Left side got a nice fit :D
    Next bending the panels, and more plate work
    Thats it for now
  11. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    yup yup yup looking real good so far.
  12. Shael
    Shael What's a Dremel?
    19 Jan 2011
    very nice work so far keep it up :thumb:
  13. TimtomNL
    25 Jan 2011
    Lookink quite awesome! Like to see how you bend the sidepanels :worried:
  14. lamanl
    4 Nov 2009
    Back Again
    After a LONG time, i am back again
    Most of the time i was working on my build and not working on my log
    BUT i did make alot of pictures
    So the log will continue :D
    The side panels are done the only thing left was bending them to the shape of the frame
    I did it with a nice bending bench at school
    I made a cardbord mold to test fit the shape
    Because I can't take the whole computer case with me in the train to school to test fit it XD
    Let the pictures do the talking
    Thats it for now
    Next the top and back pannels
  15. TimtomNL
    25 Jan 2011
    I like to see the final sketches or moddeling first and then the real thing :) :dremel:
  16. ryanexiled
    ryanexiled What's a Dremel?
    9 Nov 2011
    nice case man keep up the good work
  17. lamanl
    4 Nov 2009
    Because of some problems with Gluing the double bottum(spoilers) the project has been delayed, later more about the double bottum.
    And also an other project(DIY 5.2 speaker set) i have been working on caused a delay.
    all together caused a delay of more than a year, but i did some work on the build and kept taking pictures.
    So here is the continuation of Alu Blue!
    The rear panel
    Poeple will sometimes forget it but the rear should also look neat.
    I chose for a flat IO shield and not a countersunk IO shield like most cases have.
    Behold!
    Like all panels of this build this one will also be made out of 1mm anodised aluminum.
    First the rough cut with the saw after that finishing it with a file.
    Thats a nice fit
    Now the holes for the PCI slots
    The good old jigsaw
    And done
    Next the panel on top of the case
    This will have a smal compartment for the SSD, and maybe a hot swab for a 3.5inch HDD
    Next time the last outside panel of the case
    THNX
  18. lamanl
    4 Nov 2009
    The last plate of this build, after that its time for the detail work.
    The power supply will be placed at the bottum rear of the case, it will be paced on some aluminum beams.
    I faild a bit so if it realy annoys me i can redo it later.
    plate mounted next the holes for the PSU
    But first the support beam for the PSU
    Here the finished naked outside
    Next time I will start with the detail work on the outside plating
    THNX
  19. lamanl
    4 Nov 2009
    Today I will not yet start with the outside work, first i have to do the motherboard tray.
    The tray was lasercutted so il didn't have do al the work my self.
    For now the tray is only connected with a long piece of aluminum.
    Only that resulted in a wobbling motherboard tray, i will later fix it to one more place.
    The holes in the tray are designed to easy take of the CPU but this was designed for socket 755 only now there will be a socked 1155 installed and that wont fit anymore:blah:.
    So after this its time for the outside work
    THNX
  20. lamanl
    4 Nov 2009
    Niw the frame and platework are done ist time for the outside work.
    I made a render of the outside, to get an idea of how it wil look like.
    stay tuned
