Project - ALU
Discussion in 'Project Logs' started by dark_luna, 14 Feb 2005.
  1. bort
    bort New Member
    24 Feb 2005
    not too shabby! nice work
  2. dark_luna
    dark_luna New Member
    14 Feb 2005
  3. Bluefan
    Bluefan test 123
    25 Feb 2005
    No doubt these cases will end up looking very good, they're certainly shining! :thumb:
  4. Neo4
    Neo4 New Member
    15 Oct 2004
    great projects, congratilations
  5. dark_luna
    14 Feb 2005
  6. KillaH
    KillaH New Member
    24 Jun 2004
    nice, it looks good, but why dont you speak in your updates, lot of pics but very little explanations
  7. Sanatarium
    Sanatarium The Artist Formerly ATi_Loyalist
    22 Feb 2005
    pictures are worth 1000 words anyways...
    Nice work on the passive PSU solution, are you at all concerned about heat from the other components on the board? Those produce a considerable amount of heat as well.
  8. rool
    rool New Member
    29 Aug 2003
    Very nice, but I'd say go with another fan grill. Perhaps mounted on the inside the front plate.
  9. roachm
    roachm New Member
    16 Nov 2004
    He should reverse mount that one so you only see the round part not the 4 pieces sticking out to the screw location. ;O
    Other than that, sexy
  10. antoniohawk
    antoniohawk New Member
    21 Oct 2004
    For some reason, I think that the fan grill actually adds to the overall look. Just my opinion, your rig.
  11. infered101
    infered101 New Member
    30 Oct 2004
    I agree with you. I think that the grill looks good that way. I dont know how to explain it but i just think that if he hid the screws and internally mounted the grill it would look bad.
  12. dark_luna
    14 Feb 2005
    PUH!
    just one more pci slot left and the i/o plate...
  13. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    ^ Mmm. Thick aluminum, I love thick slabs of aluminum o_O
    Nice project btw ;)
  14. dark_luna
    14 Feb 2005
  15. infered101
    30 Oct 2004
    Isnt that backwards. Shouldnt upwards part be next to the slot so you can screw the PCI card into place though it.
  16. dark_luna
    14 Feb 2005
  17. H311R4153R
    H311R4153R New Member
    28 Mar 2005
    Nice cutting and filing :thumb: . Nice idea with the PSU.
  18. mrhanky
    mrhanky New Member
    12 Sep 2004
    nice clean mod
  19. dark_luna
    14 Feb 2005
  20. Rufus-Seal
    Rufus-Seal Guest
    :D w00t, looks nice .. But i have a question, does the freezer 4 cools good? What are the tempps with the freezer 4 and the boxed cooler? Because i think i am also gonna buy that cpu-cooler;):)
