project: AlumaxX (Dutch champion casemodding 2006! )
Discussion in 'Project Logs' started by Franklin, 28 Dec 2004.
  1. Rufus-Seal
    Rufus-Seal Guest
    Franklin, can i have you case:p?
  2. LightStar
    LightStar What's a Dremel?
    21 Sep 2004
    Wow nice project you got there keep up the good work
  3. jackjr
    jackjr What's a Dremel?
    27 May 2005
    Just have to say real quick that I just read through this entire thread and am amazed - I love the quality and craftsmanship that you're putting into this case. Glad you're taking your time and getting it right. My favorite part of the mod? Dual watercooled PSU's. Man - *that's* cool...
  4. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    This looks really nice #337
    With the second 1048 near the PSU :impressive:!
  5. dex2407
    dex2407 What's a Dremel?
    9 May 2005
    man this is amazing but a couple of things
    1 i think the res in the front would look better if it was flush with the plexi
    2 the cover for the lcd on the drive bay has the alu over the plexi but every where else the plexi is on on top of the alu it might look better if it was swapped.
    just an idea
    ur craftmanship is spot on keep it up
  6. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    I like the reservoir better as it is now. I kinda breaks the green.
    The LCD cover will look better when all the plates are polished and when the lights are turned on. The green will reflect on the alumium plate behind it.
  7. invalid
    invalid What's a Dremel?
    23 Jan 2005
    Just wanted to post and say that I love this case. UV acrylic is not my thing, so that says alot. Its the cleanliness of it and the patience in carrying it out.
    Nothing but props from me.
  8. Franklin
    24 Oct 2004
    If someone that isn't into UV acrylic likes a case with much UV acrylic, I must be doing something right :D Thanks. No updates today. I did some brain gymnastics today :hehe: I have to decide how the waterloops will be, to determine where to make holes in the aluminium plates for the hoses.
    small preview of what is going to be the last work on the stealthing plates.
    These aluminium plates will come in the bottom comparment of the case.
    There are openings for the PSU's, pumphousing, the cables from one of the PSU's and the small gap is where the two plates come that are already in the case. The ones that keep the cables from the harddisks out of sight. When I have finished this all I have to do is drill holes for all the hoses and polish all the plates.
    The first of the three plates is ready.
    and with the plate in place, seen from the back.
  9. Franklin
    24 Oct 2004
    And the second one is finished.
    one half of the compartment is closed now.
    Just attach those two parts with some bolts and they are ready to be sanded and polished.
  10. Razor_cut
    12 Mar 2004
    Tight and nice. Will look great with some shine attatched.
    :thumb:
  11. Franklin
    24 Oct 2004
    Finished the last plate.
    To mount I will have to remove the harddisk rack first. I can mark all the places in the case that have to be drilled for the hoses. The plan for the waterloop is ready. The first loop will be:
    pump-->radiator (top)-->Northbridge-->CPU-->GPU (under)-->GPU (top)-->reservoir-->flowmeter and back to the pump
    The second loop
    pump-->radiator (front of case)-->radiator (back of case)-->PSU (top)-->PSU (bottom)-->HDD (bottom)-->HDD (top)-->flowmeter-->reservoir and back to the pump again
    There will be some nice curves in the loops and some nice details. I cost me a lot of time to figure out loops that will also look very nice.
  12. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I love the way the parts in your project are made with precision. Excellent work :D :hip:
  13. Franklin
    24 Oct 2004
    Thanks Leeum. I'm glad it is visible that I try to make things as perfect as possible. I'm not a fast modder, but some things need good thinking before starting. I feel so happy with the plans for the waterloops. There will be some nice details in it. The stealthing plates come in quite handy for the waterloops. Three days of brain gymnastics paid of :rock: :rock: Just can't wait to show the loops here.
  14. waitandbleed
    waitandbleed What's a Dremel?
    4 Feb 2005
    OOOOOO me like. All of these people who have got the Powermac G5 lookin case defiantly dont have as nice of a case as this! This mod is sweet! Just fix those eject buttons. (Yes I know someone said something already. Just a helpful reminder :D)
  15. Franklin
    24 Oct 2004
    Don't worry, those eject buttons will get all the attention they deserve. That's the problem I have, every time I finished something I get an idea for another detail.
  16. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    VERY nice work Franklin.. Also very original, you have some true innovations contained within this project.. :thumb:
  17. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    sweeet mod. Are you going to paint the drive under the acrylic? That eject button looks a bit... beige.
  18. XplicitContent
    XplicitContent What's a Dremel?
    12 Mar 2005
    This project is looking great. I love the acrylic green. How much does that case cost and what brand is it? Something like Li2000 or something?
    Subscribed.
  19. Wesker
    Wesker What's a Dremel?
    26 Sep 2004
    Its a Lian Li v2000
  20. Firehed
    15 Feb 2004
