project: AlumaxX (Dutch champion casemodding 2006! )
Discussion in 'Project Logs' started by Franklin, 28 Dec 2004.
  1. Firehed
    15 Feb 2004
    Wow, really nice ram-cooler cover (if that's what you'd call it) - it being a similar shape to the hard drive thing makes it feel right at home.
    Maybe I missed it, but why bother with the fillport? Surely it's no harder to hunt for the allen wrench to open the Aquatube than one for the fillport, and in my experience a T-setup is a lot harder to fill properly than something aquatube-style (because the air that's in the lines builds up and the water doesn't want to flow in)
  2. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    This fillcap is for the second waterloop. The reservoir in this loop is the reservoir in the front, the one that is on its side. A T-setup isn't that difficult to fill.
    I had to do something with the cables from the second PSU, this one
    I will use an U-profile for it. The sleeving will have to be removed to be able to get all the wires through.
    The wires that you see now, will all be covered by the aluminium profile.
  3. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    And another very nice idea... :D
  4. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Will you have that fan blowing or sucking the air through the radiator? I belive sucking through the radiator is the best way to do it..
    :thumb:
  5. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    but if you suck the air though the radiator
    then the harddisks wont profit from the air
    and come components in the power supply's stil like some air
    so i say push from front to back
  6. Franklin
    24 Oct 2004
    I made an acryic piece for the section that devides the lower and upper part of the case. I don't want to see a hole that isn't used for the hoses. I used a milk white acrylic. This looks better as green I found out.
    I had to adapt the holes a bit to make it easier for the hoses to get through the holes.
    Today I will mount the last pieces that will have to guide the hoses. Here are some. ( These will not be visible )
  7. Razor_cut
    12 Mar 2004
    Brave choice :thumb: with white plexi. Have you tried to put that thing on a wighter? Seems heavy :)
  8. Firehed
    15 Feb 2004
    the hard drives are watercooled....
    starting to look a bit... full, and no hardware's even in yet, save the PSU and HDD racks! I forgot whether you said earlier, but are you going to have that mobo-cover piece chromed?
  9. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    How does it look when you add a layer of green plexi on top of the milk white plexi? The white color looks a bit strange to me between all that green and metal.
  10. perplekks45
    9 May 2004
    Or what about a mirror-ish piece of plexi? I know this is kinda a trend... but damn it looks awesome. :D
  11. Franklin
    24 Oct 2004
    It will be heavy, that I know. All the aluminium will be polished and will almost have the same look as chrome. Another layer of plexi is not possible, and I already tried it with green plexi and it just didn't look good. I kinda like the white, it looks "fresh". Mirror plexi is nice stuff, but I think with all the aluminium polished it would be to much. Today I want to install all the aluminium and acrylic parts for the last time, to see if I didn't miss anything.
  12. kimandsally
    kimandsally What's a Dremel?
    28 Jun 2005
    I like the look of the white plexi it breaks it up into defined sections helps to keep your eye on the top or bottom with out looking at both, great idea.
    I just wish I had so much patience, it's awesome I can't wait to see it finished, it would be great to see it in the flesh so to speak.
    Keep it up Franklin I'm loving it.
  13. Firehed
    15 Feb 2004
    yeah, the white piece kinda sticks out, but really prevents over-Orac3-ing it, so to speak (you know, green and chrome). I think I'd have to see it with all the hardware installed to make a final judgement about that piece, but it fits in well.
  14. Vito
    Vito What's a Dremel?
    19 Dec 2003
    Fantastic work. Keep updating, please.
  15. Franklin
    24 Oct 2004
    Just doing some small detail work at the moment. I hadn't finished the work on the acrylic part for the draining system yet, because I was waiting for the two fittings. Today they came in, so I started working on this piece again. The two sides are glued to the middle part. The sides will need some filing, but it will give a pretty good idea of what it will look like when its finished.
    and here you can see the way the fittings are mounted.
    Before I can start filing the edges I will have to wait for the glue to harden. I think I will wait 24 hours.
    This part will be mounted at the bottom at the backside of the case. Here
    When the system has to be drained I plug in a hosefitting with a piece of hose and turn open a valve.
  16. invalid
    invalid What's a Dremel?
    23 Jan 2005
    Lovin it! Keep the updates coming.
  17. Franklin
    24 Oct 2004
    I will have to clean the acrylic, but it fits
  18. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Nice 1 Franklin, I love this mod :D, Keep it up :thumb:
    edit: also nice work on that alu profile :thumb:
  19. perplekks45
    9 May 2004
    I really love that project. Very nice work.
    And with that white thing in there... I still don't know if I like it... but I'll wait 'till it's finished. :D
  20. Franklin
    24 Oct 2004
    I mounted the flowmeterholder.
    This will not be visible in the endresult because it is on the backside of the aluminium plating.
