project: AlumaxX (Dutch champion casemodding 2006! )
Discussion in 'Project Logs' started by Franklin, 28 Dec 2004.
  1. [ShoNuff]
    [ShoNuff] What's a Dremel?
    10 Sep 2004
    The flowmeter holder is an original. Nice, very nice! :thumb:
    I'm looking forward to seeing how you are going to plumb your loop with the dual pumps. Are you planning to run your pumps in series or parallel?
  2. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    I will use two seperate loops.
  3. Franklin
    24 Oct 2004
    The cables from the second psu are out of sight now and guided through an aluminium profil to the back (behand the aluminium sheets.
    I'm working on the aluminium part that will keep the reservoir (in the front) in place.
    Here you can see how the hoses will be kept in place. These holders are almost out of sight when everything is in place.
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Kinda turns out like manufactured in all its 'precisement'. o_O
    Great work you did with this.
  5. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    I can't get enuff of this case, a true piece of modding :thumb:
    BTW: you should work for Lain-Li :D
  6. frodo
    frodo What's a Dremel?
    1 Nov 2003
    dammnnnn thats some sweet ass work!, it looks really nice, and very very very clean :D
    keep it up!
  7. Franklin
    24 Oct 2004
    The reservoir could in theory slip out of the back
    To prevent the reservoir from sliding to the back I attached a piece of an aluminium profile.
  8. LightStar
    LightStar What's a Dremel?
    21 Sep 2004
    looking good :)
  9. pc-modd.dk
    pc-modd.dk What's a Dremel?
    22 Apr 2005
  10. Liquid
    Liquid What's a Dremel?
    20 Jul 2005
    keep going... nice to see a good modding lian li! :thumb:
  11. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Franklin, could I ask you for a big favor? Could you if you have the lover compartment unmounted, palce the two FMJs beside eachother, pointing forward. And say if there are ehough space to do so.
    Great and many thanks.
  12. Franklin
    24 Oct 2004
    I will do that when I take everything apart next week. Maybe you will know it will fit when I tell you the width of a FMJ housing is 9,6 centimeters (that's with the bolts on the sides included)
    The room needed to place them beside eachother will be 19,2 centimeters. So this should fit into the Lian on the bottom according to my measurements.
  13. Razor_cut
    12 Mar 2004
    Thats true, great, this will bring speed to the projekt.
    Thanks
  14. Franklin
    24 Oct 2004
    After the installation of the Danger Den fillcap I had the feeling the top didn't look the way it should look. That's why I made another acrylic part.
    It will come right under the grill, reservoir and the ring from the fillcap. Before I can finish the part I will have to mark the places to drill the mountingholes. After that I will make the acrylic a bit smaller, so only the sides will be visible underneath the grill, reservoir and fillcap. The acrylic glas will "connect" the seperate parts that are in the top of the case.
  15. [ShoNuff]
    10 Sep 2004
    Franklin I am impressed with your acrylic work. Do you make your cuts "freehand"?
  16. Franklin
    24 Oct 2004
    Yes, I only use a saw, file, sandingpaper and my hands.
  17. popwar
    popwar What's a Dremel?
    18 Jun 2005
    how long have you been working on this masterpiece?
  18. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    That is a nice peice of acrylic... not that bad to make that shape, what is more impressive is the metal work in the project... convergence is more about specailzed plexi work...
  19. Franklin
    24 Oct 2004
    I started in decemeber 2004 with this case and it will be finished in a couple of weeks.
  20. frodo
    1 Nov 2003
    damn thats going to look sweet!
