project: AlumaxX (Dutch champion casemodding 2006! )
Discussion in 'Project Logs' started by Franklin, 28 Dec 2004.
  1. Graffix
    Graffix What's a Dremel?
    5 Jul 2005
    sweet case man ceem the updates commin !
  2. popwar
    popwar What's a Dremel?
    18 Jun 2005
    man i cant wait to see this thing up and running!
  3. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    Finishing the edges of the acrylic part that comes at top of the case.
    Only the edge of the acrylic will be visible underneath the grill, reservoirplate and the fillcap.
    And from another angle
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Nice and clean... just like it's supposed to be. :D
  5. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Very nice... and clean. Are you going to remove the material inside the radiator grill?
  6. Franklin
    24 Oct 2004
    Oh yes, I forgot to tell that. I didn't remove it yet, because I'm not sure how I will cut it. Maybe I will follow the grill with all the "legs". Will be a lot of work, but I think the result will be worth it.
  7. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Wow, you don't know how much I envy your plexi skills. I've been working with the stuff most of the day and have been driven round the bend. Keep it up! :D
  8. Drexial
    Drexial Minimodder
    28 Jul 2005
    you have absolutly no idea how much of a masterpiece this case is even in an unfinished state. its just jaw dropping how well you work this all out by hand, and the inspiration that you have added up in my head, i only hope my bank account can keep up with my imagination from this. thanks for making things look easier then i thought they were so it gives me some motivation to try more projects out... wow i make it sound like im going off to cure cancer.... :p
  9. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    That looks damm amazing :D well impressed!
    (also a great inspiration :naughty: )
  10. Franklin
    24 Oct 2004
    I want to place a lot of LEDs in the case, but can't decide on one thing. Should I place the LEDs in series or parallel. What are the advantages and disadvantages of these two? Someone?
  11. speedybe
    speedybe What's a Dremel?
    18 Apr 2004
    in parallel the all the leds get the same voltage
    in serie all the leds get the same current.
    Parallel is the way to go for leds
    gtzzz
  12. Firehed
    15 Feb 2004
    I saw that done once... very cool effect but may or may not be worth the effort of just one big hole. The person who did it had a frosted blue effect so fairly different than yours but looked very nice.
  13. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Looking very good Franklin. I just noticed the new update..You did not change the update-date on the project..You tricked me.. :hehe:
  14. quadmodz
    quadmodz What's a Dremel?
    9 Oct 2004
    WOW!! looks so clean and nice Franklin. better to use your leds in parallel. :)
  15. maeterlinck
    maeterlinck What's a Dremel?
    14 Jul 2003
    They will need to be in series, but they can share a pull down resistor.
  16. Franklin
    24 Oct 2004
    Sanding all the aluminium takes a lot of time. I guess the sanding will be ready the end of this week. Ready to be polished.
    These parts have been sanded and are waiting to be polished.
  17. mrhanky
    mrhanky What's a Dremel?
    12 Sep 2004
    Looking nice, this will defenately come out very nice.
  18. Franklin
    24 Oct 2004
    I'm thinking about a last minute modification. A while back I had to buy some parts from a German webshop. Because of the costs to have the stuff send over to Holland I always buy several things, also stuff I sell to other people. This just to cover the shipment costs. Last time I saw and bought this
    A regcooler for the ASUS A8N-SLI Deluxe motherboard. I didn't think it would be possible to use it in this mod, because it would be just behind the radiator in the back and there would be no room to fit the hoses, but I just couldn't stop thinking about this cooler. It is perfect for this mod, with all the other watercooled parts. Now i think it might just be possible to place it when I use these fittings.
    That it's blue is no problem, it will be behind the aluminium cover, so it will not be visible. I think I will have to give it a try.
  19. Devil_909
    Devil_909 What's a Dremel?
    16 Mar 2005
    Hmm I like the idea. Where exactly does that thing fit and how thick is it?
  20. Franklin
    24 Oct 2004
    It is a mosfetcooler so it will come in this spot
    This watercoolblock is even a bit thinner as the original block, but the hosefittings are the problem. The way you see the motherboard on this photo it will be placed into the Lian Li. You can see it is directly behind the radiator in the back.
