project: AlumaxX (Dutch champion casemodding 2006! )
Discussion in 'Project Logs' started by Franklin, 28 Dec 2004.
  1. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    I want to be able to switch all the lights in the case off. I use 4 switches to control the lights.
    Now it is still possible to watch behind the aluminium plates and see all the cables
    That's why I will use this stuff at that area
    It's normally used to blind windows.
  2. revlimit
    revlimit What's a Dremel?
    25 Aug 2005
    What is the brand, make, and model of this power supply? How much did it cost and where can I order one?
  3. Franklin
    24 Oct 2004
    I ordered those powersupplies in Germany from Heat-Trap
    It's an Enermax EG465AX-VE 460W
    GuardianStorm thanks for the 5*
  4. revlimit
    25 Aug 2005
    So this is a modded PSU? I comes with the water block installed? Do you have the link to the product? I can't read Germany. Thanks for the response. Oh nice mod work btw.
  5. Franklin
    24 Oct 2004
    Yes it comes with the block installed. A direst link doesn't work. But just go to
    SHOP-->Netzteile-->Wassergekuhlte
  6. revlimit
    25 Aug 2005
    It is difficult to make such a waterblock? Any tips or guide on how to make a water block? I like that idea of water cooled PSU. I'm surprise no PSU manufacturer has one yet.
  7. re'gen
    re'gen What's a Dremel?
    8 Aug 2005
    i have a question about those switches.
    i'm planning on using them in my casemod ,but are they expensive ?
    you can say the price in euro , i'm from belgium ;)
    and i have another question:
    are there any switches you can use to open cd/dvd-drives ?
    i mean that when i push the switch up the drive goes open en when i lower the switch the drive closes again ?
    and one last , verry noob question: a regular 3 mm led , how much power does it needs en so , how big does the resistor (weerstand in dutch) has to be ?
    thanks in advance
  8. HilRam
    HilRam What's a Dremel?
    22 Apr 2005
    Windows XP Pro x64 (64-bit version) can indeed address 4GB of RAM. :) You are right about the problem with 4 sticks and 333MH though. This is fixed in the latest revisions of the A64 processor, but requires MB manufacturers to update their BIOSes. If you swap two of the sticks with single-sided ones, you solve the problem. I.e. 2x 1GB and 2x 256MB would still run at 400MHz.
  9. madhatter
    madhatter What's a Dremel?
    16 Sep 2003
    This mod looks super sweet. I'm not sure if you can call it a mod any more really, it's more of a creation. I love how it's quite subtle, I hate those over the top mods that you see so many of. Can't wait to see the lighting for this. Nice work!
  10. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    pics aren't working :waah:
  11. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    No pics..... :duh:
  12. Franklin
    24 Oct 2004
    Pics are back up, some problems with datalimit.
  13. Franklin
    24 Oct 2004
    All my problems with my datalimits are resolved by ACRyan, they helped me out with 100 Mb without any datalimit. I will have to change all the links from the photographs or can a moderator help me with this?
    I started working on the lighting. First I need to place alle the resistors. Not finished yet, but the first 37 are fixed.
    If you don't believe you can count them
    And this side will be "visible", but only when the side is open.
    These resistors are needed for the 37 LEDs that with be placed here
  14. dex2407
    dex2407 What's a Dremel?
    9 May 2005
    cool thats gonna be blinding
  15. Franklin
    24 Oct 2004
    Bright not blinding, because the acrylic part wil be covered with the grill like this
    This is an old picture, the acrylic follows the opening of the grill now. I need this many LEDs to light up all the 'legs' and not only the side.
  16. Edvuld
    Edvuld Minimodder
    2 Aug 2005
    This'll be niiice :D
    A few questions that probably already have been answered before, but what do you use to heat the acrylic glass to be able to bend it, and where/what do you use to bend it?
    I used the oven for my project and a pair of metal plates to get the right shape, but I'd love if there were an easier way.
    Also, are you doing all this work in your apartment/house, or do you have a workshop or something?
  17. kimandsally
    kimandsally What's a Dremel?
    28 Jun 2005
    Franklin will you be bringing the PC over to the UK at anytime?
    I would love to see it when it's finished.
    Keep up the great work I just love to look at the beauty of it :clap:
  18. Goth
    Goth What's a Dremel?
    17 Oct 2004
    Edvuld, he uses heat-gun ;)
  19. Edvuld
    Edvuld Minimodder
    2 Aug 2005
    Really, hm,
    I had trouble getting it evenly hot, but that could be due to the fact that I was trying to bend a 40cm long piece... Also had problems with the acrylic melting :duh:
  20. frodo
    frodo What's a Dremel?
    1 Nov 2003
    you need to move the heat-gun faster, as in keep it moving never stop
    doing this ive bent a full 600mm sheet easily, so it can be done :D
