project: AlumaxX (Dutch champion casemodding 2006! )
Discussion in 'Project Logs' started by Franklin, 28 Dec 2004.
  1. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    God damn, this case is really cool! I cant express my feelings to this project, looks awesome! :thumb: :D
    Like that logo and your tube work, and all the stealthing!
    I looked over the whole log, and noticed that you have some really expensive ****, how can you afford this? :p
    Dj Ovin
  2. Immy
    Immy What's a Dremel?
    13 Nov 2003
    I have been lurking around these forums for years and dont post often, but this is my new favourite case of all time. Keep up the good work ;)
  3. htm_elle
    htm_elle What's a Dremel?
    8 Sep 2005
    One of my fav projects. Keep up the good work!
  4. rhysmodder
    rhysmodder What's a Dremel?
    15 Dec 2005
    can we have some more photos? I cant help lying in suspence...
  5. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    Problem with the pumps is solved. Eheim gave me two new O-rings for free. Thanks guys. First loop is filled now with water. Had some help from a little friend
    :D
  6. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    haha cool! :D
  7. Thadeez
    Thadeez What's a Dremel?
    20 Dec 2005
    This reminds me of the time we found a dead bird, and some birdshit on our server (yeah it was laying around for a while...). The serverroom at that location had only 1 way in that was open, the ventillation shaft...
    well anyway, it all looks nice and tight, good news you got your system going :)
  8. Franklin
    24 Oct 2004
    Today I started soldering the relais, this relais makes the two PSU's start up almost simultaniously. Soldering the wires from the first PSU to the relais.
    And here the PS_on and a black wire from the second PSU.
    If nothing goes wrong today I hope to be able to fire up the system for the first time today. Only will have to place a couple of temperature sensors and solder the leds from the reservoirs in.
  9. PHILIP1193
    PHILIP1193 a Self Confessed HP Server Lover!!
    8 Dec 2004
    b a bugger if your mobo was DOA :(, all that water cooling would take ages to rip out, but lets all corss our fingers and hope it aint. This project is reaslly nice bud, and i think you may win the worklog competition cuz of it
    Phl
  10. Hellboy787
    Hellboy787 What's a Dremel?
    3 Nov 2005
    PRAGTIG Man!!!! one of the best MODS I have seen!!!!
  11. olle
    olle What's a Dremel?
    26 Nov 2005
    Looking really nice!!
    One question: That Board with all Led connections, how do u power that up?!?
    Going to be many cables if u going to use a Molex supply?!
  12. Franklin
    24 Oct 2004
    J-chill I use two seperate waterloops.
    The board with connections gets its power from just one molex. I split the power with four switches. One wire from every switch to one seperate group on the board. I made four groups so I can turn of and 4 groups of leds.
    Almost right Hellboy787 prachtig :D Thanks Hellboy787
    A bit late, but today I send a photo to A.C. Ryan for the worklog contest, the gallery. This one.
  13. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Your so-close Franklin. It's a bit "nerve-racking" just prior to firing-up a machine you have put soo many man hours into (with excellent results, I might add). Best of luck. I hope all goes well.. :thumb:
  14. Goth
    Goth What's a Dremel?
    17 Oct 2004
    yummi :D ! you have given me so much ideas for my first mod! very-very nice case.
    im considering that i might buy an Lian-Li case too :)
  15. Franklin
    24 Oct 2004
    Sorry no pictures yet. I didn't test the motherboard before I installed it because that was somewhat difficult with the watercooled PSU's, but now I wished I had done so. I encountered a problem that is not unique for the ASUS A8N-SLI Deluxe. No bootup at all, only the green powerup led lights up, but nothing more, no beep, nothing. I tried everything. Other PSU, one DIMM and everything you could possibly do, but nothing. I hope to get a new motherboard this week.
    Didn''t waste time though, cause I started working on my next project. Will start a worklog in about 2 months. First get this damn thing to work.
  16. nyzrox
    nyzrox What's a Dremel?
    27 Nov 2005
    man that sucks, i always test hardware first, you have been working on the project for so long, can you not RMA?
  17. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    I suppose you have tested the cpu seprately? a few fx-55s were known to come doa.
  18. Franklin
    24 Oct 2004
    I don't have another board that fits the FX-55, but I'm quite sure it is the ASUS board. It just doesn't post, a problem that occurs quite often with the A8N-SLI. Seen so many people on different fora with the same problem. Tomorrow I will have the replacement ( not the Deluxe but the Premium )so I can get on with AlumaxX.
    I can test the new board with a PSU I already bought for my next mod :naughty: I will start building the next case ( building it from scratch ) when I've finished the room that will be my "modroom". No modding in the kitchen anymore.
  19. Zds
    Zds What's a Dremel?
    3 Nov 2005
    Does it post at all?
    I had a similar problem with my A8N-SLI Deluxe when it was new; I had to iterate half a dozen times with reset switch to have it boot, cold or warm. I flashed BIOS when new ones came out and even rebuilt the whole machine with minimal parts to the table, out from the chassis. Didn't help. I took it to warranty service, they tested and said "works fine", and indeed, from that on it has worked fine :eek:. And yes, exactly the same board..
  20. Liquid
    Liquid What's a Dremel?
    20 Jul 2005
    to heavy for me...
    but a damm god project :D :thumb:
    many, many details... that´s nice :jawdrop: :clap: :clap:
