project: AlumaxX (Dutch champion casemodding 2006! )
Discussion in 'Project Logs' started by Franklin, 28 Dec 2004.
  1. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    @ AJB2K3: Thanks, but it's not finished yet. Need to take care of some details, the acrylic windows and ofcourse the hardware problem.
    @ Leeum: I can't get into the BIOS. That's the problem at the moment. The hardisks are formatted, you can see the formatscreen at the back of this photo.
    I was installing my Windows XP and after the restart no more display. I'm beginning to loose all my faith in ASUS and the A8N boards now. I started to search different forums for people with the same problem and I can't say i't gives much confidence, many people with simular problems but no answers. I will take everything apart and test it outside the case. Hope I will solve the problem.
    @ customholle: Do you mean this spot?
    This is an opening so you can see the chromed radiator. The gap will be closed with some aluminium plating later on. It looks a bit "jagged" but that is because the alumium cover isn't attached yet with the bolts that keep it in place.
    @ aon`aTv.gsus666": Thanks, it was one of my goals for the project to keep a clean look and it wasn't easy, because I watercool so many parts.
  2. customh
    customh conflagration.
    22 Oct 2005
    yes that spot, is it sort of a messy cut?
  3. Franklin
    24 Oct 2004
    I don't know what you see. All the cuts are straight there.
    here a picture from the cover only.
  4. customh
    22 Oct 2005
    It just looked jagged... pic must have foobarred it
  5. Big SturL
    Big SturL What's a Dremel?
    15 Jul 2005
    Ahh, this case is soo nice! Makes me wanna mod my V1000B (not really :p)
  6. G69T
    G69T CNC Modder
    6 Jun 2004
    It's amazing and I like its look so clean.. :rock:
    Gian
  7. huren
    huren What's a Dremel?
    14 Aug 2004
    why isnt this on the front page yet :grr: :D
  8. hobogoblin
    hobogoblin What's a Dremel?
    6 Feb 2006
    I too have a v2000 and all i can say is WOW! Excellent work man,My case should be up over the next few days watch out for Project bL@nG*.
  9. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    awesome case mod, I love the watercooling setup and the thought you put into the routing of the tubes, wires etc. Will be visiting regulary to see when you get it fired up and working properly.
    Will look out for your next mod.
  10. Franklin
    24 Oct 2004
    Today the hoses arrived that I will use for testing the parts seperately. Hope I will have time to do some testing this weekend.
    Started with the plexi that will cover the windows. I use one big piece of acrylic to cover both windows.
    I added a small detail on the side of the acrylic. This is just between the two windows.
    On 22 and 23 april I will take part in the NKCM, what stands for the Dutch Championship Casemodding. Whatever place it will be I'm happy with the result of my first serious casemod.
  11. Deathrow
    Deathrow Minimodder
    30 Jul 2005
    Looks great Franklin and I wish you good luck in the competition, although for anyone to beat you they would vae to have some sort of serious case.
  12. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    God knows you can be proud son. :D
    This is one of the best mods over here at BT imho. Much work spent on details... that makes it stand out.
    Good luck for the NKCM though.
  13. customh
    22 Oct 2005
    Looking forward to seeing the "i got 1st place!!" post
  14. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    Also I give him a big chance to win the 1 place, at the nkcm. :rock:
  15. Franklin
    24 Oct 2004
    Thanks for all your support guys for the Dutch casemodding championship, I will need it. I've seen a lot of great cases that take part in the competition. I'm glad you don't join the competition Ediejo :thumb:
    I didn't have much time to do some modding last couple of weeks. Only did some work on the sidepanel and this will be finished this week.
    Because I will visit Australia this summer I had to do a lot of planning. It was a dream of me to go to Australia once. Will travel from Holland to Sydney and travel along the coast to Canberra, Melbourne,Victoria, Adelaide. From here I will fly to Darwin to stay and visit the Kakadu National Park for some days.
  16. tacticus
    tacticus What's a Dremel?
    14 Jan 2006
    bah you should try and get about 6 days extra and drive from adelaide to darwin there is some amazing territory along the way
    also drive carefully
    welcome to my part of the world :)
    its still a bit warm so it might be best bet not to hit central au
  17. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Definately one of the better mod projects I've seen. The attention to detail is never compromised and the sheer ammount of planning this project must have required has got to be incredible (I know because I'm in the process of trying to plan a mod myself).
    Excellent, excellent work Franklin!
  18. Shnitzle1
    Shnitzle1 What's a Dremel?
    3 Mar 2006
    is there anyway you could post some vids of your rig running?
    this is a work of art and I would definately like to see more :rock:
  19. Touchwood
    Touchwood What's a Dremel?
    12 Jun 2005
    You appear to be well organised so I think you are going to produce a real pro job on this mod. Can't wait to see the finished project. Good luck!
    Touchwood
  20. Franklin
    24 Oct 2004
    At the moment all the hardware is out of the case, just to be sure everything works, before it will all be installed. I tested the system with memory sticks that are on the qualified vendors list and this seems to be the solution. I have installed windows XP now. I still have some problems to getting the system to run stable, so I'll update the drivers and BIOS and do some further testing. The mod just has to be finished before 22 of april, for the Dutch modding championship.
    I have never had so many different problems with hardware as with this computer, but now everything work fine. At last. I didn't take any chance and tested everything outside the case. Installed Windows XP in RAID0 and installed everything that had to be installed. This weekend I can put everything back into the case, so I'm sure it will be finished in time for the photoshoot that will take place in about two weeks.
    Off topic: I'm very curious who won the AC Ryan contest, still nothing on the AC Ryan website.
