project: AlumaxX (Dutch champion casemodding 2006! )
Discussion in 'Project Logs' started by Franklin, 28 Dec 2004.
  1. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    Temps are still dropping, because there is still some air in the big radiator. I don't use the fans at full speed, but at 60 to 70 percent. CPU ( AMD FX-55 ) is around 38 to 40 degrees and the videocards 48 degrees Celcius. Hardisks both around 29 to 30 degrees Celcius. It's strange but the temps in full load don't get much higher, only about 5 to 6 degrees Celcius higher. Temps are not all that important for this mod, it has to run quiet.
  2. customh
    customh conflagration.
    22 Oct 2005
    Understood. Thanks!!
  3. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    That's the thing about Water. The delta between idle and load is not that much. Whereas with iar, you might have a difference of 15+ degrees, 5 is about right for water.
  4. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Those are the same numbers I get with Black Narcissus(s) small-bore loop, same AMD-chip as well.. Under "full load" is where H20-cooling flexes it's muscles!
  5. crazytyler34
    crazytyler34 What's a Dremel?
    12 Apr 2007
    at the begining of this mod you cut out acrylic alumax letters...what did you ever do with those? i dont seem to see them anywhere on your case.
  6. Franklin
    24 Oct 2004
    I didn't use them in the casemod, but it was a good way to get the feeling of working with the acrylic though. Sometimes plans change during the work on the mod.
  7. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    i noticed you got one of the hiper aluminium keyboards, how do you like it? i am thinking about getting one and polishing it. are the keys aluminum as well, or just the surround?
    killer mod, man. a well deserved win. those cuts are just so dang perfect!
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    I happened to have looked at that keyboard today - the keys are also aluminium.
    note that the layout is not quite standard.
  9. itsjustacompaq
    7 Sep 2006
    sweet, thanks jazzle. looks like i have another thing to add to my newegg wishlist ;)
  10. kimandsally
    kimandsally What's a Dremel?
    28 Jun 2005
    I've read the whole thread before, but I think of it so often I've come back for another look, and it still impressed me as much as the first time.
    Absolutely superb. :rock:
  11. Blackcrown
    Blackcrown What's a Dremel?
    1 Oct 2005
    The keys of mine Hiper Aluminium keyboard are just made of plastic. :rolleyes:
    I've got excactly the same one as Franklin has. (same winning batch)
  12. DAE_JA_VOO
    DAE_JA_VOO What's a Dremel?
    11 Nov 2005
    Yeah the keys on the Enermax Keyboards are not aluminium...
  13. itsjustacompaq
    7 Sep 2006
    darn, that's disapointing. i was really looking forward to a completely polished keyboard, ala filimon. i have access to a foundry, i may have to do that, actually :D
