project: AlumaxX (Dutch champion casemodding 2006! )
Discussion in 'Project Logs' started by Franklin, 28 Dec 2004.
  1. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    Good ideas are always welcome.
    and Dean_j2001 you live in a nice city b.t.w. Visited your city last year for a soccermatch. Too bad we lost, but enjoyed my stay over there anyway.
  2. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    i love this mod so far. :eek: the only down is the look of ´the res there on the front. for me a no go! i would go with the one piece idea like the others. everything else is just supreme modding. keep it up :thumb:
  3. Franklin
    24 Oct 2004
    Acrylglas on the rack
  4. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    WoW!!! That looks sweet...
  5. bootupbuddha
    bootupbuddha grunge modder
    3 Feb 2004
    This one of the best mods right now on Bit-Tech... :dremel:
  6. Franklin
    24 Oct 2004
    I installed the acryl glas on the PSU, only have to shorten the bolds a bit.
    Here you can see the space between the acryl glas and the PSU cover.
    and from the side the PSU will be seen in the case.
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I guess I was right thinkin' this was a f***in' nice mod...
  8. Franklin
    24 Oct 2004
    The next thing I want to hide for the eye is this
    I dont like the holes, they mess up the clean look I want.
  9. Anthony
    6 Jan 2005
    Just a little aluminium plate, and it will be great!
  10. Franklin
    24 Oct 2004
    It's going to be aluminium indeed. It will also hide the drives and some other stuff, like the flow meters.
  11. AutoExec
    AutoExec What's a Dremel?
    31 May 2004
    I've always thought those holes looked messy..
    great work! :)
  12. Anthony
    6 Jan 2005
    Yeah, i was just looking at some other places to put aluminium.. And you found them too
  13. repawn
    repawn What's a Dremel?
    19 Jan 2005
    I think the psu cover looks really good with the acrylic off the metal by a few mms, even if that isn't your intent - I will probably try to do this with my mod. Great job on the aluminum and acrylic work! :thumb:
  14. Franklin
    24 Oct 2004
    The motherboard is such a place too. I have some nice plans with it in combination with the acryl glas. The theme from the HDD rack and the PSU will come back in plate above the motherboard. You should think about openings above the RAM memory, covered with acryl glas in the same way as on the PSU and HDD rack, so that airflow will still be possible.
    repawn, that was my intent. Only the bolts are a bit too long in the inside of the PSU. You can see it in the photgraph. The space is needed to allow some airflow in the PSU. I will use this way of installing the acryl glas more often in my mod b.t.w.
  15. perplekks45
    9 May 2004
    Blank Alu ? Chromed ? Or matt ?
  16. Franklin
    24 Oct 2004
    I will start with the same look a the HDD rack, that's polished a littlebit, but not shiny. If this doesn't look the way I want I can always go to shiny and even chromed.
    A quick overview the way it looks now.
  17. fieroloki
    fieroloki What's a Dremel?
    3 Jan 2004
    Tagged cause this is slick.
  18. perplekks45
    9 May 2004
    I begin to like you... Nice and clean, that's how a case gotta look ! :rock:
  19. Rh1n0x
    Rh1n0x What's a Dremel?
    15 Nov 2004
    Dutch Mode:
    Mooi hoor Franklin, gewoon die UV-plexi doorzetten op die bovenste bay met die niet stylish bevestigings 'gaten' :).
    Dit gaat een mooie mod worden! :thumb: .
  20. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    You could cover the Alu with a piece of plexy similar in shape to the three in the HDD rack.
