project: AlumaxX (Dutch champion casemodding 2006! )
Discussion in 'Project Logs' started by Franklin, 28 Dec 2004.
  1. Dean_j2001
    Dean_j2001 What's a Dremel?
    1 Apr 2003
    don't worry i didn't for a second think it was
  2. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Very cleen work! and for me who are almost doing the same mod can look back to you and get some ideas :thumb:. And Im glad you showd the need of drilling the rear, so the radiator could fit.
    Goodie of hiding as mush as possible of the components, witch only can result as brilliant :clap:
    Looking forward to the next update!
  3. Neo4
    Neo4 What's a Dremel?
    15 Oct 2004
    good work.
    very clean.
  4. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    The acrylis parts for the front are ready.
    Just have to clean up the parts a bit, remove the pieces of tape and then polish it all.
  5. frodo
    frodo What's a Dremel?
    1 Nov 2003
    looks schweet man... keep up the good work
  6. M1ndZtorm
    M1ndZtorm What's a Dremel?
    8 Feb 2005
    Hello Frankling! This looks to be a "zweeeet" modd :rock:
    I really like your design theme - clean and simple. As you already know, some times more is less!
    I'm working on my own PCV 2100 case, you certainly gave me a few ideas for my project. I'll be waiting for future updates.
    Keep that Dremel spinning :clap:
    Kind regards,
    Karl
  7. Peddro
    Peddro What's a Dremel?
    21 Feb 2005
    This is my first post and iam proud to do it here!
    very nice mod...
    :D
    [dutch mode] Ik hoor het wel als je dat gezandstraalt moet hebben...[/dutch mode]
  8. mafia11671
    mafia11671 What's a Dremel?
    7 Feb 2005
    Dood,
    The acrylic looks very awesome. I have a 1030B Antec case and I am going to do some acrylic work on the front also :D . Oh yeah, the res in the front looks pretty killer, the way it was before and the way it is now! :rock:
    Could you tell a little bit more on how you bent the acrylic, I would like to do some things like that.
    Very clean job!!!!!
    Mafia :thumb:
  9. frodo
    1 Nov 2003
    hi...
    bending acrylic is very easy in my opinion... just get either a professional heat strip.. or a blow torch (or hair dryer... havent tried using one of them tho!) and heat the acrylic evenly where you want to bend it... then wait until it starts to flex/move... then bend the acrylic to shape. and hold while its temperatures drop... then you should have a nice solid bent piece o' acrylic
    hopefully that helps
  10. Franklin
    24 Oct 2004
  11. mafia11671
    7 Feb 2005
    Thanks bro, and it's a heatgun in my language too :D
    Mafia
  12. Franklin
    24 Oct 2004
    Yes the FMJ housings for the pumps are back they look fantastic. The chrome looks perfectly smooth and shiny :naughty: No pictures yet but I will post them soon.
  13. Franklin
    24 Oct 2004
    The photographs I promised from the chromed FMJ pump housings.
  14. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    ok and where's the picture of it mounted on the pump?
  15. Franklin
    24 Oct 2004
    Don't rush me KAMIKAZE-FREAK :rolleyes: I will have to replace the original screws for the housings, because they are butt ugly. First I'll have to determine where the housings will be placed. Maybe a little detail will be added to the housings before being mounted too.
  16. KAMIKAZE-FREAK
    30 May 2004
    sorry mate
    i'm kinda inpatient when it comes to first grade casemodding
  17. Franklin
    24 Oct 2004
    Doesn't matter, I just take my time for the details KAMIKAZE-FREAK. The FMJ housings came in sooner as expected. I was determining the place for the Crystalfontz LCD when a friend phoned me the FMJ housings were ready. I can tell you the mod is progressing rapidly now, so within two weeks from now some major updates will be posted here.
  18. KAMIKAZE-FREAK
    30 May 2004
    hurry up
    or else you cant join the NKCM commetition's
  19. Franklin
    24 Oct 2004
    What's NKCM?
  20. KAMIKAZE-FREAK
    30 May 2004
    Nederlands Kampioenschap Case Modden
