Case Mod - In Progress Project: Alumino Fantastico [Stacker 832] updated 2 feb.
Discussion in 'Project Logs' started by Thadeez, 29 Jan 2008.
  1. tribaloverkill
    tribaloverkill Who needs sleep,... bah.
    1 Jan 2005
    Sweet! Good to see you modding man! I owe your some reservoirs:)
  2. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    I don't know about the look of this whole thing, I don't think it's for me. But you are doing a fantastic job of putting this thing together with excellent craftsmanship, BRAVO! :clap:
  3. Thadeez
    Thadeez What's a Dremel?
    20 Dec 2005
    Update February 3rd
    So we left off with the hinge on the upper wing. Today i started by visiting my good friend Snakez who lives not far from me. He had a triple radiator lying around for which he had no purpose, so he decided to offer it to my project :) Thanks!
    First, i flipped the motherboard tray, since the case will be BTX. I noticed the bar to which the lower hinge is mounted was a bit in the way, so i took the Dremel and started cutting a strip away. Now the tray fits again :) Also, i mounted the upper wing and i checked out how to use the snap locks. Here are the results!
    This is what Snakez donated! just need to clean it here and there :)
    Safety first! No seriously, i've spoken with guys that have permanent damage to their eye(s) by using rotary tools without safety goggles. I always use my special Dremel goggles :p
    Cutting away the strip to fit the motherboard tray again.
    Here's the upper wing mounted and motherboard tray in BTX mode.
    Well these pics don't need any comments :) Just watch.
    Yeah, i only fitted the front snaplocks. Just want to test it out, see if i'm satisfied with the results. If i don't like it, i'll change it next update :)
    Next update will probably be tomorrow or the day after, so hang in there and check ya guys later!
    Cheers!
  4. radodrill
    radodrill Resident EI
    14 Mar 2006
    Sweet latches :D
    good to see this is getting the H2O treatment
  5. Thadeez
    20 Dec 2005
    Thanks, can't wait to put on the panels so that the whole thing will look so much better! Will install plain aluminium panels right on the frame, and then, using some spacers, i will install some sweet looking black anodized and brushed alu panels!
  6. tribaloverkill
    1 Jan 2005
    I like those lock thingies you got going on there,... I need something like that for down the road. Good job man.
  7. 12modderz
    12modderz L33T еÐ3!
    29 May 2007
    Nice Start mate. Intresting Design.
  8. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Are you going to do the same to both sides? I don't see why you'd really want a fancy door on the motherboard-side of your case. :/
  9. iwog
    iwog Linux cursed
    14 Jun 2007
    :read: he said he's making up one side, getting it perfected and then copying it onto the other side.
  10. Thadeez
    20 Dec 2005
    Hehe, thanks iwog:thumb:
    But let me explain why i will use fancypants doors on the motherboard side. I am thinking of using 2 triple radiators :hip: Otherwise, i will put the custom reservoir in the upper or lower wing.
  11. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    can you translate the title of that book for us? so i can see if i can get one.....
    and "Alumino Fantastico" is in your language?
    subscribed.
  12. Thadeez
    20 Dec 2005
    I can't really translate it because it just says "The big Haefele". I saw on their website that the catalog is also available in english, under the name "Complete Häfele".
    See their website for more info: http://www.hafele.com/uk/about-us/haefele-group/901.asp
    And Alumino Fantastico, i guess it's got a little bit of italian in it. So no dutch there :) I just wondered about a project name for too long, so i ended up just scribbling this down. I will change the name if i find a better one :)
  13. DXR_13KE
    14 Sep 2005
    its almost Portuguese: Aluminio Fantastico or Fantastic Aluminium....
    thanks for the link :D
  14. Thadeez
    20 Dec 2005
    Np mate :)
