Project: ALUminous, a Lian Li PC71 Casemod ~Upd:03.08-08: ~Final shots~
Discussion in 'Project Logs' started by Caliber, 8 Nov 2005.
  1. Caliber
    Caliber New Member
    26 Aug 2004
    Thanks for the comments guy. I also prefer the older lian li cases, they really are something special in my eyes when it comes to simplistic design...
  2. Caliber
    Caliber New Member
    26 Aug 2004
    Continuation of the worklog
    ~Prosjekt ALUminous~
    Yet another update. This is gonna be a big one, im gonna mount all the blocks on the mainboard and the gpu.
    First well have to remove the excisting heatpipe from the card and give it a good old clean. Thank god for the invention of hair-dryers :)
    Its cleaning time!
    All cleaned up
    Its time to unmount the fan on the ultra
    They sure didnt save costs on screws... :p
    Before and after cleaning
    More cooling-paste is NOT better, or it'll work against its purpose as many of you already know
    Now lets mount that pretty EK-block
    ...and mount it again to check that all the chips make contact
    All ready to make itself useful in my rig
    Then it was time for getting the mobo ready for that h2o
    Ive switched the nipples for some nice Danger Den cromed ones
    Lets move on to the final installation in the case, dont it look purdy?;)
    Hex-screws all the way baby
    and finally; thats what i call having the margins on your side:rock:
    Regards,
    Haakon Bowitz
  3. lost_modder
    lost_modder New Member
    5 Dec 2006
    nice chrome show man
  4. ComputerKing
    8 Sep 2006
    Buddy. I'm Fan of your cleaning. Dam You did the cleaning job very dam well. I wish if I can do that like you. You care about the hardware soo much :) that what makes me want to be fan of you.
    I really love the Water cooling Gear man. Well done, I don't have any thing more to say.
  5. p3ri0d
    p3ri0d New Member
    9 Jul 2008
    Me likey
  6. Caliber
    Caliber New Member
    26 Aug 2004
    The power-cabling to my harddrives have always been a clutter due to un-customized lengts, so I decided to make my own cable to make it look better.
    This is what I started with, an old power-cable and a buch of push-on sata-connections from AC Ryan
    Then I started connecting the cables at the correct lengts
    All done, lets start hiding those colorful wires with some heatshrink
    All done!
    Now lets see if it fits
    Regards,
    Haakon Bowitz
  7. Caliber
    Caliber New Member
    26 Aug 2004
    Thank you guys for the comments, appreciate it :clap:
  8. Stievius
    Stievius Industrial Design Student
    12 Nov 2006
    That's a nice job you did there on the power cable! :clap:
  9. Caliber
    Caliber New Member
    26 Aug 2004
    Thank you, im very happy with the result ;)
  10. GavX
    GavX New Member
    5 Apr 2008
    can you do that with SATA cables? If so that idea is truely stolen, its brilliant! Really good mod you got going here, looking forward to seing updates, and I am impressed the ammount of sponsors you have going here
  11. Caliber
    Caliber New Member
    26 Aug 2004
    Its only one way to find out, ill look into it. Thanks for the compliments, ill keep those updates coming. Yeah, ive promoted myself a bit in the modding-community in Norway (wich isnt big).
  12. ComputerKing
    8 Sep 2006
    Well done buddy with the Power Cable :D that look very very clean work :) but why you didn't add the orange cable?
  13. Colossous
    Colossous Member
    28 May 2007
    Great job duder :thumb:
  14. *Alex*
    *Alex* New Member
    23 Mar 2008
    looking good man, i have one stashed away you have made me wanna fish it out and mod the hell out of it =)
  15. Caliber
    Caliber New Member
    26 Aug 2004
    ComputerKing: Thanks, I didnt use the orange wire because it isn't needed ;)
    Colossus: Thanks, keep on watching, there's plenty more to come...
    Alex: What are you waiting for, its a great case with a lot of space!
  16. *Alex*
    *Alex* New Member
    23 Mar 2008
    i gotta finish the v300 and G70 first lmao :dremel:
  17. Caliber
    Caliber New Member
    26 Aug 2004
    Then get em finished you slacker! :p
  18. Caliber
    Caliber New Member
    26 Aug 2004
    I decided that I not only want two fans in the bottom of the case, but also a slimfit Black ice dual rad. That means that Ill be needing to make holes in the bottom of the case for passing through the tubing, and I came up with something to make it a bit more interesting...
    So what might this be? Anyone who remember this geometry formula from math-class...?
    hmm, still no clues?
    Allright then, its a set of tinted plexi dougnuts with screws in a pentagon-pattern to complement the res-unit in my system. They will be mounted around the holes for the tubing in the bottom for the 2nd rad.
    You guys like it?
    Regards,
    Haakon Bowitz
  19. p3ri0d
    p3ri0d New Member
    9 Jul 2008
    It's clean and sleek ;)
  20. Caliber
    Caliber New Member
    26 Aug 2004
    Thanks, wait until you see em installed ;)
