Scratch Build – In Progress Project: Aluminum Water Cooling Case
Discussion in 'Project Logs' started by Spotswood, 17 Apr 2011.
  1. randomhero
    randomhero Minimodder
    6 Nov 2005
    Sweet! That's some serious rad you got there! 4x140mm push'n'pull configuration?
  2. Spotswood
    Spotswood Custom PC case builder
    30 Jul 2007
    Thanks! I believe the setup is going to be push with custom shrouds:
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking very much perfect :).
  4. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Nice Rich. Very nice.
  5. randomhero
    6 Nov 2005
    Awesome shroud you got there! You need to do a metal working guide once you're done ;)
  6. Spotswood
    30 Jul 2007
    Thanks.
    Here's my aluminum working guide:
    • Cut flat/bar stock with a chop/miter saw
    • Cut sheets with a router guided by a template or straightedge
    • Drill holes with a drill press and invest in a self-centering vise
    • Don't waste your time reading my boring project logs, read Attila's instead. :D
  7. Spotswood
    30 Jul 2007
    Next up is to cut the front sheet.
    In order to cut-out all of the openings for the 5.25-inch drives accurately, a custom router template is required. I used .5x1-inch u-channel and .25x1.25-inch flat bar to frame the openings on .5-inch particle board.
    The aluminum bits guided my flush trimming router bit.
    The aluminum bits were removed and the particle board template was used to cut the .10-inch thick aluminum sheet.
    Now I just need to square all of the corners and cut to width. Ugh.
  8. randomhero
    6 Nov 2005
    Oh, I'm reading his aswell belive me ;) Nice work with the router too! Never seen Attila use a router btw :p
  9. Spotswood
    30 Jul 2007
    "Life" had gotten in the way of this project for a few weeks, but I've managed to fabricate the inner and outer sheets of the front panel. It took me 5 hours to square-off all of the inside corners.
  10. Spotswood
    30 Jul 2007
    Back sheet cut to width, height and the hole for the 10-slot motherboard tray routed out.
  11. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    nice work so far - I like the rounded corners. :)
  12. randomhero
    6 Nov 2005
    Looking good, got the exact same motherboard tray for my build ;)
  13. Spotswood
    30 Jul 2007
    The inner and outer front sheets, cut to final length.
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking really nice Rich :).
  15. Spotswood
    30 Jul 2007
    Shelves!
  16. dark4181
    dark4181 Ero-sennin-tebayo
    3 Jan 2008
    I remember the render threads for this in the EVGA forum. Glad to see it's finally coming to life
  17. ColdzeroTeam
    ColdzeroTeam What's a Dremel?
    9 Dec 2010
    nice case you got there.
    it must be sturdy as hell with all that thick alu :thumb:
  18. Spotswood
    30 Jul 2007
    The 5.25-inch drive bay rails:
  19. Spotswood
    30 Jul 2007
    I bolted the 5.25-inch drive rail assemblies to the front inner sheet.
    Note how the extra deep rails will completely hide the drives and cables.
    Another design benefit of the front air duct is hiding all of the mounting hardware.
  20. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Monstrous. Looking good
