Case Mod - In Progress Project:American choppers! bondo fun!
Discussion in 'Project Logs' started by grritsshawn, 2 Mar 2010.
  1. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    Hello!let me start off by saying I'm Shawn i'm a 16 year old and this will be my first mod I've put on a forum.
    Some background info on why i'm doing this. Well my favorite show has been American choppers for years!I mean I loved everything from, the planing,the making,and the out come of the bikes and just the shower was amazing.But as some of you may know the show has come to an end on February 11th 2010. So because this was my favorite show why not do a mod about it!
    The specs are as follow:
    CPU:Intel core i5 750 running at 3.5ghz currently (temps 28 idle/39 load)
    GPU:powercolor 5850
    RAM:4gb(2x2gb) G.skill ripjaws ddr3 1600
    MOBO:Foxconn Inferno Katana
    PSU:Ocz stealth 700watt
    HDD:750gb Seagate barracuda
    OPTICAL:Lite-on Blu ray player/Sony dvd/cd burner/player
    CPU COOLER: Coolermaster hyper 212 plus
    Still need to buy-
    120x2 rad
    HDD water block
    CPU water block
    GPU full coverage water block
    tubbing
    coolant
    anti-kink coils
    barbs
    fans
    other(paint,plexi,mesh,new dremal,nofear/monster,switches,lights,etc)
    Some of the parts i will be using in this build
    after 6 hours of prime 95 and wat i overclocked it to
  2. grritsshawn
    20 Apr 2009
    got the new case I'm gonna be using!!
  3. grritsshawn
    20 Apr 2009
    just bought 2 of these [​IMG]
    and one of these [​IMG]
  4. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Nice start. Have you got a sketch or a render on what you are planning on doing?
  5. grritsshawn
    20 Apr 2009
    yes but i am debating if i should release it or keep it a secret....i mean seeing stuff happen without knowing is the best
  6. grritsshawn
    20 Apr 2009
    some quick removal of a few things
    first to go is the 9 hard drive cages!!
    second is the 140mm fan!
    more things when i get my parts
  7. grritsshawn
    20 Apr 2009
    after 3 weeks of waiting that parts have arrived!!! [​IMG]
    i will start work on putting them on the case once i get my new dremal and some fiberglass but i just bought a truck and im taking the gf to a movie saturday so im spent for now
  8. grritsshawn
    20 Apr 2009
    been a while will have new pics up tomorrow!!
  9. grritsshawn
    20 Apr 2009
    here is part of the inside put together and painted.....thats the american chopper part of it....
    and here is the start of the front and the outside which is the orange county chopper part
  10. stonedsurd
    11 Mar 2009
    red/blu/white look great together.
    Seeing the rest of the stuff you have collected, I really want to see how this turns out. Especially the placement/integration of the tank.
  11. grritsshawn
    20 Apr 2009
    thanks for the feed back i still need to get some more parts b4 i start the tank part
  12. sejutaluka
    sejutaluka What's a Dremel?
    23 Nov 2007
    yes I also can not wait. blue / white / red is a very stylish america. especially if you make a few stars
  13. grritsshawn
    20 Apr 2009
    ya i thought about that but seemed to hard during work and school and gf
  14. sejutaluka
    23 Nov 2007
    maybe you can buy some decal (cutting sticker) and put it on.
  15. Sushi Warrior
    Sushi Warrior What's a Dremel?
    20 Mar 2009
    You're the only person I've ever seen using this case! Good luck with the mod.
  16. grritsshawn
    20 Apr 2009
    thanks its a pain in the but so far
  17. blackadda15
    blackadda15 What's a Dremel?
    28 Apr 2010
    I have to agree the Red, White and blue looks epic
  18. grritsshawn
    20 Apr 2009
    Hey im back!!! Well i been working a lot and my birthdays coming up so been busy. But i did get some work done!!
    Well i will start here i bought a black and decker rotary tool and Ive bondo the part of the front of the case and then also got a placement idea of the gas tank
  19. grritsshawn
    20 Apr 2009
    well broke alot of my tools so im kinda stuck might see how much a cheep jig saw will cost for me to finsih cutting 3 holes!!!! only after that gotta drill holes and put screws in after that paint!!! then sadly finish this project and then be done for good
