Project Antec Sonata Mod (Project Serenity)
Discussion in 'Project Logs' started by Kurtis, 9 Apr 2004.
  1. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    sorry... i'm just blind. Looks like it'll be good.
  2. ErrOnReq
    ErrOnReq What's a Dremel?
    7 Apr 2004
    Actually, he doesn't need a northbridge block. The heatsink on that board is passive.
    (This is the other owner of TTL)
  3. Tulatin
    16 Oct 2003
    oh, hey brian. Sure, a passive sink will handle most loads. But considering the airflow through that case... :D
  4. ErrOnReq
    7 Apr 2004
    He has been running that case with just a CPU fan for a while. As have I in the past when I was using that board. It will hold up unless he really stresses it.
    The airflow coming from the radiator's fan(s) should be sufficient.
  5. Tulatin
    16 Oct 2003
    come to think of it, it should
    [offtopic]
    Can you toss the activation on my TheTechLounge forum account? Hotmail doesn't seem to want to get the message. Same acct name as here, thanks [/offtopic]
  6. ErrOnReq
    7 Apr 2004
    Actually, I was considering that before. It might be turning a lot of people away. Since you mention it, I will turn off email activation right now.
  7. Tulatin
    16 Oct 2003
    thanks, now about activating that account ;)
  8. ErrOnReq
    7 Apr 2004
    You can try to subscribe to our forum again. If you need me to delete your old username there or something in order for you to use it, let me know.
  9. ErrOnReq
    7 Apr 2004
    NM, I'll just activate it for you.
    EDIT:
    You are good to go :)
  10. Tulatin
    16 Oct 2003
    thanks dude. Whoops... we hijacked the thread... Sorry Kurtis...
  11. Kurtis
    Kurtis What's a Dremel?
    9 Apr 2004
    ah well :) im not done with my mod just yet, so i'll un-hijack it soon :)
  12. Tulatin
    16 Oct 2003
    that works :D
  13. naelq
    naelq What's a Dremel?
    14 Oct 2003
    maybe it's time to take care of my SONATA tooo! :naughty: :hehe:
    good work bud! :thumb:
  14. Kurtis
    9 Apr 2004
    okay... this is what i've been up to...
    i was messing with my water cooling stuff, and decided to watercool my fx5950u. So I installed the GPU block as you can see here. I also ordered some tweakmonster ramsinks for it (i have them now, but not installed yet...)
    I used some plumber's goop to attach the duct flange to the front of the case... I let it cure for 24 hours before proceeding to the next step.
    here's the rest of the duct, after being cut to necessary length, sanded nice and smooth, and cleaned with soap and water...
    Next I used some more Plumber's Goop to attach the duct to the flange. I will be using some bondo next, but i needed it to be attached (at least i think i needed it to be :D)
    I'm letting that cure overnight and maybe I'll mess with it some tomorrow, but probably I will wait until Thursday to do anything else to the duct, as it is supposed to cure for 24-72 hours.
  15. Meatloaf
    Meatloaf What's a Dremel?
    3 Nov 2003
    It's looking really good. I'm really liking the fornm of the case. Keep it up.
  16. sickskater6911
    sickskater6911 What's a Dremel?
    9 Oct 2003
    wat type of case is that?
    where did u get it?
    how much did u pay for it?
    THANKS! GREAT WORK ON THE MOD
  17. ErrOnReq
    7 Apr 2004
  18. sickskater6911
    9 Oct 2003
    asome thanks, although i was hoping it would be cheaper w.e have to find a different case
  19. 3vil-Grin
    3vil-Grin What's a Dremel?
    25 Jun 2003
    Great project!!!
    *Subscribed*
    Its cool to see more Texas modders out there in this forum.
    (Zap is our leader!!! LMAO!!)
    Keep up the great work!!!
    :rock: :D :dremel:
  20. dreamreality
    dreamreality What's a Dremel?
    4 Mar 2003
    nice
    the front is lookin good!
    just curious, cuz i'm not that sure yet, but did u cut the front of the duct off and put it on then attached the rest? is it more bendable that way? that would be a great idea for my duct mod. thanks!
