Case Mod - In Progress Project: Antec TwelvOrange **FINISHED**LOTS OF PICS**Update 31/05/2011
Discussion in 'Project Logs' started by flame696, 1 May 2011.
  1. bulldogjeff
    2 Mar 2010
    Looking at the pics you've got a nice finish. Like the lads have said practise makes perfect. It's coming along nicely, take your time and it'll all be just fine. Here's a little tip for you, give the paint a few days to dry and then go over it with some T cut 2 in 1 paint restores/wax. Itwill put a lovely shine on it.
  2. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Whoops i will remember that for my next mod as i have finished (in a way) but thanks its good to get tip from people do awsome mods like 'Saturday night project' :thumb:
  3. flame696
    15 May 2009
    hey guys a big update as i have spent the whole weekend get this thing as near completion as i can. I say near because its going to be an on going project (cable sleeving and a new window)
    so heres goes
    The laquer has dried (i gave it a couple of days) its time to put the case together.
    Firstly the rivet gun and rivets, 100 of them (Only 25 in pic :D)
    time to put the panels together. As you can see from the pics i have left the one of the panels as black I wanted to give it a bit of a contrast and i completely forgot about the piece :D
    All the panels are riveted together all holes filled :naughty::worried:
    I then had a brainwave :idea::idea: why not put the SSD on the back of the case. So i began to measure and drill 2 holes
    Viola! :clap: SSD attached perfectly
    more to follow......
  4. flame696
    15 May 2009
    Right so on to fitting all the plastic parts and get this case finished
    First i decided to use the U channel that i had left over from the window mod to put around all the holes that i have cut and the pre cuts ones as it looked good and would protect the paint work when i put through molex connectors etc.
    So on with the plastic fittings
    SQUIRRAL!!!!
    PIGEON!!
    Back to t he build. On with the Xigmatek fans
    Drive cages
    Now to operate on the rig. TIme for a transplant :dremel:
    Hard drives
    SSD
    And now for the rest of system
    OMG so many cables :wallbash::wallbash:
    More to follow....
  5. bulldogjeff
    2 Mar 2010
    Thanks for the nice comments.
    You can still do the outside of the case once it's all gone back together. The inside isn't quite so important.. It just gives it that final little polish and brings it up really nice. Quite often i'll go over the whole case 3 or 4 times. it also helps to stop dust sticking to it.
    Edit: I've just seen the 2nd part of the update, it didn't come up when I logged on, it's all gone together already.
    Black and orange is always a winner, going to look good when it's finished.
  6. flame696
    15 May 2009
    Ran into a problem with the NZXT fan controller. As i was using LED fans they kept pulsating so i had to go buy a analogue controller. I bought the Zalman ZM-MFC 1 Plus so had to the cable managment again :waah::waah::wallbash:
    Everything up a running with the fan controller
    everything cleaned and sorted
    Window mod (messed up) shot
    Front & fan controller shot
    Thats all for NOW but will be back with a better window mod and cable sleeving would love to hear comments on how it looks
    Thanks for all the support and kind words i received :thumb:
  7. flame696
    15 May 2009
    I had taken lots of pics and thought i would post everything on today! I have totally finished now going to redo the window as its not the way i wanted and some cable sleeving
  8. bulldogjeff
    2 Mar 2010
    That's a really tidy job. The zalman controller suits it .
    A nice bit of black braiding on the cable would finish it off nicely.
    Edit: you ninja'd me on the cabling...lol
  9. shadow19935
    shadow19935 Whats overclocking? :D
    17 May 2010
    Looking very nice, you have made an unattractive case very attractive :)
  10. flame696
    15 May 2009
    thanks mate :thumb:
  11. Guest-56605
    Guest-56605 Guest
    Now that flame is one very very tidy job mate :thumb:
    Like it :D
  12. flame696
    15 May 2009
    cheers thanks! i learnt alot while i did this project so im now a bit more clued up then i was before i started.
    Now i have been bitten by the modding bug, on my next holiday i might do something with the Fractal R3 :D
  13. flame696
    15 May 2009
    when i come around to do the sleeving should i just keep it all black, all orange or a mixture?
  14. bulldogjeff
    2 Mar 2010
    Me personally, I would go with black, you've got a nice balance with the case against the hard ware, to much orange could be a bit to over powering. But it's your rig so what ever you're happiest with.
  15. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    I would agree on the black, there's a lot of orange going on already, I think the cables would get "lost" in all that orange... not to mention it might not match the shade correctly either... but like bulldogjeff said, It's your rig, whatever makes you happy :)
  16. andrew8200m
    andrew8200m Modder
    4 May 2009
    I like it! Fans look awesome!! :)
  17. flame696
    15 May 2009
    Thanks and as for the fans they do look really cool pity about the persons I got them off tho he is the opposite of cool :D:thumb:
  18. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Mate, I would polish caps, de sticker everything and have Martin at http://www.psychosleeve.com/ sleeve everything for you. Also I would paint the PSU ;). But very good job otherwise! :D
  19. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    Awesome, that was pretty quick! Very clean, and I'd say all black sleeving as well to contrast the already very orange interior. The PSU needs a bit of attention though, sticker has to go...
  20. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Looking cool!
    Only thing letting it down for me is the yellow on the PSU, the red bars on the Frio, and the blue stickers on the 580. Sort them out and it would REALLY look the part IMO.
    Otherwise great work mate! :D
