*PROJECT APOLLO* G4 to PC mod (56k warning)
Discussion in 'Project Logs' started by MachinaEX, 3 Nov 2003.
  1. MachinaEX
    MachinaEX What's a Dremel?
    3 Nov 2003
    I've been a regular poster over at the Futuremark forum, so some of you might have seen this mod. It took some creative license and some elbow grease, but I've finally finished my PowerMac G4 to PC mod. Here are a few pics of the process it took converting a PowerMac G4 case into an AthlonXP 2600+ machine.
    First of all, you might be thinking, "why does it look like its upside down?"
    Well, that's because it is...well, at least the front plastic panel is. I relocated the CD-ROM drive to the lower part of the case (so the microATX motherboard would fit), so in turn, I had to flip the front plastic panel upsidedown to accomidate this. After some careful fabrication, I got the CD-ROM door to open correctly and I also built a custom LED power switch. Here's the final beast. I just put in the top 80mm Blue LED exhaust fan a couple of days ago.
    Total Build Time: September 13 - October 30
    Here's the custom made LED power button. The case I bought did'nt come with the on/off switch or LED, just the decorative button (the part you see from the front of the case), so I had to make one.
    I had to de-solder and remove the onboard sound, video, parallel, and serial ports in order for the rear 60mm fan to fit.
    I had to do a lot more modding to get to the finished product, but these pics highlight the major mods. Other modifications were: removing the old mobo mounts and installing new ones, cutting an air intake hole for the new Antec 480watt PSU, cutting out internal case panels to increase airflow, modifying the internal 120mm case fan shroud, cutting out the rear case plate for new motherboard ports, and more! :dremel:
    APOLLO SPECS:
    AthlonXP 2600+ (333 FSB)
    Albatron KM18G nforce2 microATX motherboard
    512MB CorsairXMS PC2700
    Asus GeForce4 128MB Ti4800SE
    Audigy 2 PCI audio card (for gaming)
    Echo MIA digital audio card (for audio recording, mixing/mastering)
    120 GB Western Digital 7200rpm Hard Drive
    Antec True 480watt PSU
    Lite-On 48x24x48x CD-R/DVD-ROM combo drive
    Keep in mind, this was my first try at modding, so if you guys have any suggestions on what I could have done different, feel free to let me know!:idea:
    BTW, thanks to Lucifer for hosting!
  2. MachinaEX
    3 Nov 2003
    MORE PICS:
    EARLY PICTURE. internal black 80mm fan has been removed. Also, stock AMD HSF was replaced.
    The air intake for the new 480watt PSU.
    The rear plate had to be cut out to allow for the new motherboard ports.
    Here's the case with most of the plastic panels removed.
    Here's the modified front plastic panel.
    BTW, thanks to Lucifer for hosting! :rock:
  3. Pliskin
    Pliskin What's a Dremel?
    23 Aug 2003
    where did you get your case? I've been trying to hit up local repair shops with dead G4 towers, and no luck!
  4. MachinaEX
    3 Nov 2003
    $100 (USD) off of eBay. There's usually 3-4 up for sale there.
  5. MachinaEX
    3 Nov 2003
    Keep in mind, my pic hosting account only has a daily bandwidth limit of 220MB. If you see X's, check back the next day.
    Hmmmmm....unless somebody wants to host these pics for me? :D :D :D
  6. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Nice work , I like what you did with the cd drives , its a pain they don't fit. :) I had to have mine at the rear of the case on its side :)
  7. Lucifer
    Lucifer What's a Dremel?
    18 Nov 2001
    mail the pics to me or use the uploader in my sig
    looks like a tidy job :)
  8. TheDon
    TheDon What's a Dremel?
    21 Oct 2003
  9. MachinaEX
    3 Nov 2003
    My next mod, or computer for that matter, is probably going to be a G5 to PC conversion. I just have to wait until the G5's are as cheap as the G4's are! :sigh:
    *machinaEX waits....and waits....and waits.....*
  10. pranks7er
    pranks7er mange tout
    25 Dec 2002
    Project Bad Apple all over again!
  11. MachinaEX
    3 Nov 2003
    Actually, I think you mean "Rotten Apple", the mod by Brian Holmes.
    His article in the September 2002 issue of CPU Magazine was what inspired me to make my mod.
  12. Gordy
    Gordy Evil Teddy
    17 Apr 2001
  13. MachinaEX
    3 Nov 2003
    :blush: Sorry about that. Thanks for the clarification, Gordy. :D ;)
  14. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    hehe no probs :D
  15. Mikec4costa
    Mikec4costa What's a Dremel?
    27 Oct 2003
    nice :thumb: Modding an apple should prove to be good and interesting :rock: :dremel: good luck
  16. MachinaEX
    3 Nov 2003
    I finally made a dual hard drive bracket to mount my WD 120GB and my Maxtor 40GB drives.
  17. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Wow Nice... I could not see my G4 this way though... it is staying mac all the way... :D
