Case Mod - In Progress [project] Apple Cube - final photos !!
Discussion in 'Project Logs' started by thegyufi, 5 Mar 2012.
  1. leslie
    leslie Just me!
    19 May 2009
    That is one tight little package, nice work!
  2. biojellywobbles
    biojellywobbles Minimodder
    12 Feb 2011
    This looks amazing been following it and you certainly have a knack for making it look very sleek. Can't wait to see what you do with the outer shell!
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    You'd never know unless told, looks very good.
  4. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    Hi!
    It's not a big update, just some photos of the assembly in the cube : it fits !
    For the moment I'm working on the top of the case, I cut all isn't necessary to let the air circulate.
    Soon some news !
  5. Lance
    Lance Ender of discussions.
    6 May 2010
    That is looking great!
    I would happily have that in my house.
  6. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    you painting the exteria love the work mate !
  7. Mr.Evil
    Mr.Evil What's a Dremel?
    7 Feb 2012
    looks really nice!
    it is a shame that the case is not transparent to show all the work you've done inside :dremel:
  8. thegyufi
    21 Mar 2011
    It's been a while now since my last update !
    I was really busy with my work, with this
    to this :
    Big pressure inside ! But now it's done so I can breath and post some news
    Ok, so now just a little update before a big one, I work on the mettalic part inside the plexi cube
    drawing:
    As I cut many surface, I must re-rivet the part which serves to hold in place
    finitions :
    As I decided to keep the apple and illuminated in white, I cut the mettalic part, just behind the other apple on the plexi.
    The holes to let in the jigsaw
    and after a little filling
    That's it ! So nothing really amazing, but just wait the big one about the work on the plexi part which I have totally modified !
    big F likes this.
  9. pahoran
    pahoran What's a Dremel?
    16 Mar 2012
    amazing work! this is by far THE best Cube mod I have ever seen!! :jawdrop:
    what kind of metal are you using to manufacture custom parts you've made? aluminum? link to where I can buy some?
    POw
  10. thegyufi
    21 Mar 2011
    Tks a lot for the compliment !
    Yes this is aluminum, I use the alu of my FD Array case, so I think it's not the cheaper you can find :duh: :lol:
  11. Foregasm
    Foregasm What's a Dremel?
    3 Apr 2012
    truly spectacular metalwork!:thumb:
    can't wait to see whats next!
  12. big F
    big F What's a Dremel?
    1 Feb 2010
    Excellent work
    I love the designs of the apple cases and love modding existing cases.
    The thing is that with a modification build you are locked down to the design of the original case or what ever you are using be it a toaster or an Imac or old pc case. You have to make the hardware fit in, where as when making a scratch build you can make it to fit the hardware.
    Keep up the good work.
  13. thegyufi
    21 Mar 2011
    teaser ...
    soon !
  14. Mr.Evil
    7 Feb 2012
    very interesting :D
  15. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Just gotta keep drawing it out dont ya? Imma find that Lawyer that Cheaps hired...
  16. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    havent looked at this log for a while, nothing to see here... Kidding! looking REALLY good!! :roll:
  17. thegyufi
    21 Mar 2011
    Hi !
    @ALL: I really appreciate that you appreciate my work :lol:
    End of the teaser (I think you've waited long enough)
    First, this is the cut I need to do to realise the entire assembly of the cube
    drawing
    dremel's cut
    filling
    (this two holes are used to fix the anti-vandal switch'support)
    And the chassis almost finish, just need to do some finishing and be painting
    On the last we can an "accessorie" I create to fix the AC/DC entry of the picoPSU
    The next pictures arrives, the time to reduce and host !
  18. thegyufi
    21 Mar 2011
    The next
    To broke this massive visual of the cube I cut the same existing cut on the bottom to let trought the cables, on each side
    the first !
    the second !
    and the third !
    Then I cut this news feets a little too high
    The I cut the top of the cube, I remove surfaces as much as possible to increase the convection power of the cube
    Now the switch's emplacement
    Easy system to fix this support, I drill 2mm holes and heat 3mm bars to be sealed in the plastic
    The next with the paint arrives
  19. thegyufi
    21 Mar 2011
    the next and end with the paint !
    Aller suite et fin avec la peinture :
    the cube entirely sand with the P240 paper
    Paint
    Switch support
    Mounted
    The cube fully assembled
    Need to do a little P1000 sanding and some polishing and this part will be finishing.
    That's it for today !! :dremel:
  20. SilveR_172
    24 Nov 2011
    OH GOD , Why is this build soo HOT !!!!!!
