Project AquaLight - updated [23-2-2007] FINISHED!!!
Discussion in 'Project Logs' started by ssR, 16 Aug 2006.
  1. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Are you going to paint that mouse blue to match the lighting?
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    you should polish up the bezels!
  3. ssR
    ssR Carbon God
    11 Aug 2006
    duste: now that you mention it ill think about it :p
    burnout21: cant do :(. i mentioned in the previous updates that the aluminium alloy i used to make the side panel isnt suitable for polishing. it looks great when brushed though. this case isnt meant to bling, i want a clean and smooth look :)
  4. ssR
    ssR Carbon God
    11 Aug 2006
    well since there was no real progress in the project lately i decided to run some experiments since the paint i ordered for the case has finally arrived :D
    other than that i experimented a bit with brushed aluminium and decided to do a little something with the PSU mounting plate i made a while ago. after brushing it with 180 grit sandpaper i shot some layers of clearcoat on it. after the clearcoat dried i smoothed it with 2000 grid paper and some water and polished it. the pictures really dont do it any justice
    before
    and after
    some closeups
    the paint has arrived at last
    i did some experiments on an old speaker mesh grill i had lying around. it was originally white. i sanded the paint a bit with 360 grid paper
    and in the progress
    closeup on the paint. i really love that color, it looks much better in real life than it looked in the catalogue
    after some layers of clearcoat
    and the finished product
    next week ill prepare the entire case for the paint and hopefully paint it aswell. also my plexi order should arrive next week so you can expect lots of action
  5. eegg
    eegg What's a Dremel?
    29 Aug 2006
    nice paint job real professional waiting for updates
    הי גם אני ישראלי
  6. Dracula
    Dracula What's a Dremel?
    27 Aug 2006
    Nice Colour
  7. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Me want airbrush...
  8. ssR
    ssR Carbon God
    11 Aug 2006
    thanks guys :D
    i got my order from frozencpu today
    AC Ryan short UV blue IDE cable
    short UV blue SATA cables
    C-strip
    sleeving kit
    bulgin illuminated switches.
    other than that i primed the side panels and the top/bottom of the case and enlarged the holes for the power/reset buttons to accept the bulgin switches. pictures of the progress will be posted tomorrow
    edit: just soldered the wires to one of the switches
    1st soldering with heatshrinks
    checking if it works... its alive :D
    after the final sleeving
  9. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Very impressive work, keep it up! :thumb:
  10. chase
    chase What's a Dremel?
    11 May 2006
    Looking better and better everytime i check in ssR, keep em coming ;)
    Petter
  11. ssR
    ssR Carbon God
    11 Aug 2006
    thanks guys :)
    im here with another update. as promised pictures from yesturday of primer painted panels, together with today's progress
    panels painted in primer paint
    rear fan hole covered with c-strip
    bulgin switches placed on the panel
    and an overall look of the panel before it went to the primer paint
    and the front panel painted with white primer
    another pic of the front panel
    thats it for today i hope to finish the paint job by the end of this week
  12. hujambo_Bwana
    hujambo_Bwana What's a Dremel?
    2 Aug 2006
    Very nice SSR, I like the way you've sleeved the switches, I might steal that idea for my own project and your front panel looks good after primer.
    Jimbo
  13. FooSai
    FooSai What's a Dremel?
    6 Feb 2006
    Looking good, very clean looking front panel... except the blow hole seems out of place becaue its got such a sharp angle to the panel, i think it would look better if it blended with the panel more. Couldn't really see it till you primed it.
    The colour you're gonna use looks real sweet! can't wait to see it on.
  14. tkdwarrior
    tkdwarrior What's a Dremel?
    5 Jul 2006
    something to show the potential of this project. sure to look amazing clad in that brilliant shade of blue you chose :D looking forward to updates, dont keep us waiting too long..
  15. ssR
    ssR Carbon God
    11 Aug 2006
    thanks for the feedback guys :)
    FooSai: the angle isnt that big, ill take some closeup shots to show you how it looks exactly. also with the paint on i believe it will look much better.
    i should get some more progress done today, so stay tuned
  16. luis_pedro_Sato
    luis_pedro_Sato Minimodder
    29 Nov 2004
    Your font case looks great .
    Congrath
  17. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    wow i really like the case! it looks great
    i am very jealous of your airbrush though
    and congrats on your swithes they are ace gud luck!
  18. ssR
    ssR Carbon God
    11 Aug 2006
    thanks for the replies guys :)
    here is today's progress
    i painted the case legs with primer paint. i also dremeled a piece of 1 of the supports out to make room for the CCFL which will be sitting there. and i also sleeved some more cables
    the legs are disassembled and painted in primer paint
    a piece of the support beam dremeled out
    and from the inside
    the CCFL is placed inside the beam
    and a shot from the inside
    and now for some cable sleeving
    reset button. the led will be connected to HDD activity
    power button
    one of the usb cables is sleeved
  19. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    woo im going to have to borrow your idea for the ccfl
  20. Yumadil
    Yumadil What's a Dremel?
    17 Jul 2004
    isnt that ccfl placement not gonna let much light out... or maybe just directionalize it... but the way its hiden is awsome, if it works im gonna borrow the idea too!
    good job, keep it up
