Case Mod - In Progress Project Arclight
Discussion in 'Project Logs' started by tobyak, 24 Feb 2012.
  1. hero1
    hero1 Minimodder
    18 Oct 2013
    Awesome mod. Keep it up and I like that CNC.
  2. Xaine
    Xaine Death... destroyer of brain cells
    19 Sep 2012
    Sweet build dude,
    The tool you used to snip the aluminium looks very useful, need to cut a load of mm thick alu myself and only currently have a dremel (would take hours and several 10's of pounds in diamond circular saw bits), anychance of the details of what it's called/where you got it?
  3. Nexxo
    23 Oct 2001
    Some hardcore modding there! :dremel:
  4. Asouter
    Asouter --------
    18 Jan 2012
    Did you have any CNC experience before buying your machine ? and does it come with the software to get you started. You seem to be getting alot out of what you have ... I want some of that :)
  5. tobyak
    tobyak What's a Dremel?
    5 Jul 2011
    Here is he link, looks like the seller is keeping the item re listed http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=131106038461
  6. tobyak
    5 Jul 2011
    Prior to buying this CNC no, no experience at all, bar assembling 3D printers privately. No software came with this one but many sellers do include rather shady copies of the software you need
    Any questions or help in finding a good re seller (i had to do a lot of looking around to find one that was half decent as a lot are trash) PM me
    Sorry for double post chaps, in my haste I completely forgot about multiquote
  7. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    you need to buy the machine...
    you will need parts that will drive the machine from your computer, popular would be a g540
    you need software to run the machine, popular is mach3
    you need software to make the cad drawings
    you will need some form of g-code conversion program such as cut 2d or cut3d that can take your dwg or dxf files and covert it to g-code for your g540 to understand...
    you can go to cnczone and ask some questions.
    you are basically looking at a cnc router setup.
    nice looking build!
  8. tobyak
    5 Jul 2011
    Gecko drives are not cheap, what drives someone goes for would be very budget dependant
  9. kinghong1970
    19 Apr 2009
    true... they are not cheap... neither is a cnc-router... hahaha
    but it is fun though...
  10. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Well, well, well, welcome back from the grave!
  11. Xaine
    19 Sep 2012
  12. tobyak
    5 Jul 2011
    Np, im. Sure you will like them
    Oi oi Mads, long time no see
