Scratch Build – In Progress Project Arctic, [The making of my first scratch-build] World record?! DONE!
Discussion in 'Project Logs' started by iSw3de, 28 Oct 2014.
  1. acmods
    acmods What's a Dremel?
    24 Nov 2014
    looking forward to this,
  2. Jeffinslaw
    Jeffinslaw What's a Dremel?
    26 Jun 2014
    This is awesome! I was wondering when someone would take on the task of making an mATX version of the Compact Splash. I dig the design cues you took from that case.
    Really interested in seeing how this progresses.
    -Jeffinslaw
  3. iSw3de
    iSw3de What's a Dremel?
    21 Dec 2012
    Here come a fast picture I took, Have no time for update, so you know how it looks now :D
  4. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    I would of liked this more if it wasnt a copy of the Compact Splash case......
    You have the tools to make something unique right there.
  5. iSw3de
    21 Dec 2012
    I really have, but the thing is that it is intentional, it is supposed to be a M-ATX tribute to the Compact splash! :D
  6. iSw3de
    21 Dec 2012
    The painting
    This is the painting result, must say I am satisfied since this was my first time ever powdercoating. Great that they made me do it myself!
    I had to do some pushing and bending with the PSU. Hard to fit it all in there...
    Once again, thanks to Anna @ Silverstone for fixing this one for me!
    Eventually I got it all cramped in there, and looks great to be honest! Although, I feel like I should have changed the fan because it make some noise....
    Here is the hooks, too bad they did not go in all the way.... No good way to file it down either...
    Great thing is that the HyperX Fury RAM matches the paint perfectly!
    Had to cut some screws to make it fit in the radiator tho :D
  7. WiSK
    WiSK What's a Dremel?
    7 May 2014
    But but but ... it is unique!
    Splashes are made of steel. This one is aluminium. Yet it's strong enough to hold more components than the original. When I saw the design first, back in July, I doubted it. Told him it won't be strong enough. But he's really done his homework and it worked out well. Plus he's only a young 'un - seventeen!
    Clean build, nice to look at, small footprint, 4x120mm rad in under 20 litres - not to be dismissed so lightly! :thumb:
    (And I say this despite having a white-with-blue-highlights Compact Splash of my own)
  8. iSw3de
    21 Dec 2012
    Thanks WiSK for the kind words! :blush:
  9. iSw3de
    21 Dec 2012
    FINALS
    Two big achievements for me right now, firstly, I made it to the mod of the month! (http://forums.bit-tech.net/showthread.php?t=279969) This have been a dream since I was 14 :D
    Secondly, I finished my project!
    I want to thank my sponsors, supporters and all of those who have helped me or given me thoughts!
    [IMG ALT=""]http://www.overclock.net/content/type/61/id/2283618/width/500/height/1000[/IMG]
    Thank you guys! Have been a great time doing this project!
  10. FAT
    FAT What's a Dremel?
    19 Mar 2013
    Wow... This build looks amazing! I absolutely love the color scheme! Well done!! :D
  11. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Great system Lucas!
    Also dat triple monitor setup with dat wallpaper!!!
  12. storm-83
    storm-83 Minimodder
    7 Nov 2014
    this is cool
    one thing i'm not really into, are the way the wires from the psu steals, pretty much, all of the show...
    but the color scheme is really nice and the whole process form design to finished product is well documented, and the case is well fitted with a lot of power - "thumbs up!"
  13. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    Have to agree with you 100% here.
    Absolutely stunning build and design, apart from the PSU location, it robs the entire clean look this machine has with the way the PSU blocks the board and CPU waterblock and also the way the cables run all over the show.
    Other than that, it's absolutely stunning and prefectly executed. :thumb:
  14. Falqoon
    Falqoon Minimodder
    13 May 2013
    Nice system! Looks very cool.
    One small point that i saw: I think your power button can be nicer, i see there is a hex ring behind the button, if you remove that and place it behind the panel i think its even better.
    Other than that great job!
  15. twister7800gtx
    twister7800gtx Minimodder
    2 Nov 2011
    Nice Job Lucas!
    triple monitor is..:jawdrop:
  16. iSw3de
    21 Dec 2012
    Thanks!
    Thanks Tim <3
    Same, there was this compromise about having small case vs having PSU somewhere else.
    Thanks Storm!
    Thanks Warn00b! With the PSU in that position made it SFF, at a volume of 18,9 Liters.
    Would I have put it somewhere else you would have had 22 liter + :(
    So this was compact > great looking
    Thanks! Finally someone points that out :clap:, the thing is that the button is too long and hits the radiator on the other side. So I have to find a smaller button. Therefore the hex ring is on the wrong side :)
    Thanks twister :3
    So what will happen now?
    Except for the selling of my case, this is what is next on my list ;)
  17. Zoyadog
    Zoyadog What's a Dremel?
    28 Jan 2014
    Those graphic cards... *drools*
