project aries (for wywywywy)
Discussion in 'Project Logs' started by Joel, 5 May 2003.
  1. Joel
    Joel New Member
    9 May 2002
    here ya go, gonna dig out my tech folder later and get some pics in progress
  2. Dad
    Dad You talkin to me?
    15 Apr 2003
    Very nice indeed! One question though... Why do I see an UNMODDED BEIGE computer sitting lonely in the corner in the 2nd pic!?!?!? :D
  3. Joel
    Joel New Member
    9 May 2002
    its my backup server, only had it a few days, gonna be modded asap.....
  4. wywywywy
    wywywywy Member
    26 Sep 2002
    Wow :eeek:
    Dedicated to me! :clap: Yay!! :clap:
    Thanks Joel.
  5. wywywywy
    wywywywy Member
    26 Sep 2002
    Hi Joel,
    Did you use L-profile and screws (or epoxy) to join the sheets?
    Or by some other method?
    Thanks.
  6. sojumk
    sojumk New Member
    11 Sep 2002
    plastic bubble wraps inside the case? :jawdrop: :nono:
  7. Joel
    Joel New Member
    9 May 2002
    the main part is bent alu sheet, bent into a |_| shape, then there is a frame inside, to which the front and back are screwed.
    bubble wrap reduces the noise, by quiet a a considerable amount, and it looks cool under uv light....
  8. wywywywy
    wywywywy Member
    26 Sep 2002
    Now that's cool, how did you bent the alu sheet then? Pure viking force (i.e. with hands)?
    Sorry I know I ask too much... but I hope you don't mind.
    Many thanks.
  9. Joel
    Joel New Member
    9 May 2002
    it was bent with a sheet bender... bit of a job as the alu is about 4mm thick...
  10. bilnv
    bilnv New Member
    20 Apr 2003
    Great case. I really like that bubble wrap idea. Do you have a pic of the bubble wrap with the uv light?
  11. Morphine
    Morphine weeee!
    23 Feb 2002
    lol makes me feel stupid buying paxmate when i coulda used bubble wrap to get the same effect
  12. Joel
    Joel New Member
    9 May 2002
    no, i broke my uv cathode....
