Scratch Build – In Progress Project: Ark of the Covenant Mod - Update 9/28
Discussion in 'Project Logs' started by TheGreatSatan, 7 Feb 2008.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    I've made a decision. This will just be a case mod. I actually have no use for another system and wouldn't have anywhere to put it when finished. So the CPU, Mobo, RAM and Heatsink are all on ebay in one auction. The 500GB Hard drive I'm going to keep and add to R2-M5 (giving him a total of 750GB!)
    The modding continues.
  2. TheGreatSatan
    5 Aug 2005
    So I decided to use the shape of the ten commandments as the window, since they are what is in the Ark. I found a pic online
    Then cut out the shape and drew it on the panel.
    Looks interesting
    Hard to cut the curves
    I want to coat this side with the mesh too, but should I cut out the commandments here too or leave it covered?
    I was drilling the holes for the rivets and bent my new bit!! :(
    Painted it gold too.
    Started on the other front bezel beam.
  3. JBLPL
    JBLPL What's a Dremel?
    5 Mar 2008
    Bent?? not break? little strange :eeek:
  4. TheGreatSatan
    5 Aug 2005
    Titanium, my Butt!
  5. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    Wow, you must have really strong buttocks!!!
  6. LooZypher
    LooZypher Huh!? What!?
    4 Jan 2008
    :D:D:D:D Hahahahahaha :D:D:D:D
    Interesting work:rock:
  7. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    dare you to go all the way and etch the ten commandments into the side panel ... go on, dare ya!
  8. CobraMods
    CobraMods Gettin there slowly
    28 Mar 2008
    Thou Shalt not Dare ?
    :naughty:
  9. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    This is a little uncanny... I was just googling the ten commandments yesterday... an now they pop up here.... is someone trying to tell me something? <=)
    [edit]
    About that drill bit..
    [/edit]
  10. TheGreatSatan
    5 Aug 2005
    Here's the gold layer on the pillar
    I cut off the top piece of mesh so that the board will lay flatter and it left a cool effect.
    So much more to do and this is where I'm heading...
  11. TheGreatSatan
    5 Aug 2005
    So more work to show.
    This is what I'm shooting for.
    Here's how I'll do it. I used good ol' expanding foam to fill in the pillar
    I have this thin rod
    I had to cut it to size
    Then I dropped in the rod
    And drilled a hole in the plywood base
    I checked to make sure that the rod will fit.
    And shaved off the excess foam
    Then all I had to do was set the pillar on top and push the rod through the top and bottom.
    Three to go. :)
  12. TheGreatSatan
    5 Aug 2005
    I'll get more done soon. My wife has had the week off and doesn't want me modding while she's home, because I'm not spending time with the family.
  13. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    I like the mod, i like the gold, i like the pillars.
    Jury's still out on the metal screening on the window side. Seems to negate the already small window, imo.
  14. TheGreatSatan
    5 Aug 2005
    So it's been months now and I'm finally ready to finish this mod. There will be some changes made to the base and topper because wood looks like crap when painted gold so I'll do something different there.
    My Angels arrived and I've painted them!
    The pillars were done with tow different kinds of gold paint, but now that I bought more I can match them all.
  15. Nuffenburger
    Nuffenburger The Burgerman Can
    18 Sep 2007
    Lookin real smooth mann
    I love the pole idea Hope all goes well=]
  16. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    you may be better off building a propper Old Testiment Ark like Noah with all this excessive weather of late.
  17. TheGreatSatan
    5 Aug 2005
    So I finished the 1st part of the top, there's more coming.
    I have some old trim lying around that I'll be adding under the topper to transition the 90 degree angle.
    I'll also be adding more to the top along the edges making it look far more elegant.
  18. TheGreatSatan
    5 Aug 2005
    The trim has been painted.
    Here's where it'll go
    I bought more trim too
    And these cool knobs
    This is how I do my wood cuts. Plain old Miter setup
    The two pieces go under the case like this:
    And here's what to expect when I add the columns
  19. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    Looking good so far, but needs more Ark, and less the looks of a gold painted case :)
  20. TheGreatSatan
    5 Aug 2005
    There's tons more coming.
