Project Arkadur
Discussion in 'Project Logs' started by arkadur, 3 May 2005.
  1. arkadur
    arkadur What's a Dremel?
    3 May 2005
    Hi!
    i'am new, and i want to show you my project:
    the begineing:
    the window
    roof:
  2. arkadur
    3 May 2005
    i decided that its not..
    :blush:
    the secend painting:
    except this: (electeronicks..)
    LEDs board: (2 PIns connectors for each LED)
    LCD (the old one - 2X16, now i got 2X40)
    the EL cable
    now i'am working on it again..
    i'll buy new perspex, cables,pipes, conectors and more
    so - the update will be ready - soon (its my first project :rolleyes: )
  3. arkadur
    3 May 2005
    update! :D
    i bought VATEC sliving kit
    and genric PSU
    and i build the LCD (2X40)
    enjoy!
  4. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    First thing.. what's up with the tape? Are you going to work that away or what? Cause it doesn't look good IMO.
    I find black cases always to look pretty nice.. especially with the shower hoses. Keep us updated :rock:
    Mod on :dremel:
  5. Rh1n0x
    Rh1n0x What's a Dremel?
    15 Nov 2004
    It looks like it has potential to be very nice mod.
    Maybe if you took the photo's in better light environment, and a bit sharper we would be able to see more and effectively drool more :thumb:
  6. asafy
    asafy What's a Dremel?
    27 Feb 2005
    very nice eli!
    kEEp moDDing !
  7. n0ll4k
    n0ll4k What's a Dremel?
    1 Jun 2003
    looks promising
    but please try to make better pics ;)
  8. (spc)kuhnkejer
    (spc)kuhnkejer What's a Dremel?
    14 Feb 2005
    What up with the tape? You should never use tape it looks like crap. but i love every thing about this mod keep it up. better pics of the paint job would be nice and what is that top made of where did you get it?/
  9. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    I agree, get rid of the tape, everything else looks so clean it would be a shame to have the one bad thing mess it up.
    The top looks like a plastic storage bin he cut the bottom out of and used screening for the mesh. Looks great in my opinion. Way to use your imagination when it comes to supplies.
  10. BrokeEnthusiast
    BrokeEnthusiast What's a Dremel?
    28 Mar 2005
    Thats a clean rig. I like youre power supplies. how and why do you have so many???
  11. arkadur
    3 May 2005
    it's old PSU (P1\2..) - i took the fans, and dump it befor few days..
    the tape is its just tow boards 1X7 CM, the cables make it big and ugly
    i'll remove it - dont worry, i'll put it in box (mini project "the brain" - all the controls will be there (leds, LCD, fan bus..) with the beutiful pipes around)
    the "thing" on the top is a small basket of writing implement - if i get some money
    i'll put there Redeator all the water cooling stuff
    and more update - the rehobus
    1. the panel with the tape
    2. the first holes
    3. 2.5 CM holes
    from the back - the perspex, with the Leds places
    primer (Motip :D )
    the end of painting - metalic Black (motip..)
    testing the beutiful panel (i put 1 led behind the panel - to see the effect)
    today i finish it - and install it in the case
    by the way - now the holes are fine, in the same high
  12. arkadur
    3 May 2005
    hi
    i have a big update..
    ready?
    i decided to mod the PSU
    its isn't finished yet..
    few pictures of the case now:
    the LED bus
    now the rehobus
    it's finished and working nice - just put it is CD case..
    (2,3 chanel doesn't have the right SCREW)
    for the sliving - i make i very useful tool (for the ATX)
    in the secendery pipe i put red led (some of the lightning effects)
    cd case and more pipe
    and the LCD connector (i hide all the ugly tape :blush: )
    i put the connector in the buttom of the case - under the HDD gourd)
  13. Xhiz
    Xhiz What's a Dremel?
    28 Oct 2004
    This looks great!
    Can't wait to see more :rock:
  14. zapperfish
    zapperfish What's a Dremel?
    24 Apr 2005
    that case looks dam nice so far, good luck
  15. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Looks good, but please fix the fiddly knobs on the baybus.
  16. arkadur
    3 May 2005
    update :D
    i finished the front panel+lightning, and repaint the basket on the roof (with motip..)
    i create intersting lightning effect, putting leds in pipes :rock:
    i want to give a name to this project, what do you thing?
    1: phantom
    2: impact
    gets some pics!
  17. Arkuden
    Arkuden mow?
    9 Jul 2004
    very cool, i love the design to the top of the case it really stands out.
